If i want to install new flywheel, should i change clutch disc as well?
Old May 25, 2007 | 10:44 AM
katana4eva's Avatar
Hello,
for those who remember me.. i've imported parts and they are sitting infront of me..lol...
waiting till my exams to finish. ( still uni student )
If i want to install flywheel, should i change my clutch disc as well?
Car only ran 21000kms now. Clutch disc should still be fine...
but i heard that i should change the clutch disc at same time, when i change flywheel. but my disc seems alright... i don't think it has weared out that much.
if i should change clutch disc, who is exedy supplier in sydney?
Old May 25, 2007 | 11:54 AM
icyur2's Avatar
Shonen
I recently changed my stock flywheel to MazdaSpeed. I did not change out my clutch, since I only had roughly 11K miles on it. I don't see it being changed out until roughly 50K or so: at the rate I drive. So..depends on if this car is a single owner (if it was used, might be a good idea to have it looked at) AND driving isn't abusive to the clutch. Flywheel install only cost me $370....worth every penny, since by the time I need to replace my clutch, it will be at least 5 more yrs. away!
Old May 25, 2007 | 07:20 PM
takahashi's Avatar
Do you want a half job done or a job done well.
Change both, a matching set, it is a no brainer.
Old May 26, 2007 | 12:03 AM
DrewMan's Avatar
Culpam Poena Premit Comes
What parts did you get?
get some piccies!
If you change the clutch, it will change the feel of the pedal.
usually heavy duty ones are used for drag/turbo/race applications or people who abuse the clutch.
Its up to you but I would change it since you have the tranny down
Old May 27, 2007 | 12:50 AM
rotarenvy's Avatar
I changed my clutch at 32000km with the flywheel. it wasn't necessary as the clutch had little or no wear. I think have bad clutch control so it made me think, WTF do the people with pictures of purple burnt-out clutches you see posted on the forums do?
if there are heavy score marks on the clutch you should replace it or get it re-surfaced.
Old May 27, 2007 | 01:43 AM
DrewMan's Avatar
what flywheel did you get rotarenvy?
Old May 27, 2007 | 01:49 AM
takahashi's Avatar
Do a search man where have you been?.... **** I forgot too. Did you have an EXEDY flywheel?
Jarl, did you say you regret your decision not to change or you realise you want one too?
I opted for a set so I only take the tranny out once, it is not funny to do it two times ... especially what I went though (..... )
Old May 27, 2007 | 02:18 AM
rotarenvy's Avatar
I have the exedy flywheel. in my case I didn't need a new clutch and could have reused the std one for another 60,000Km or more.
I did replace the stand clutch with a genuine Mazda replacement. I didn't think I would need a heavy-duty one as I wasn't intending to use forced induction.
since I have a spare clutch now and intend to fit some form of forced induction, I will be having the std clutch modified to mazdaspeed spec's and go through the operation again.
Old May 27, 2007 | 03:53 AM
takahashi's Avatar
I don't think the MazdaSpeed version is rated well enough for FI use. Unless you are not talking about the JDM spec, then I dunno.
Get a matching Exedy single carbon.
Old May 27, 2007 | 04:34 PM
rotarenvy's Avatar
maybe the mazdaspeed isn't enough clamping force for forced induction. I'll have to discuss that with the shop when I get round to it.
I did eye off the carbon clutches but since the std clutch is fine for NA power the cost wasn't justified at the time. Also I would need a new flywheel with a carbon clutch and I haven't seen any weight figures for them.
Old May 27, 2007 | 06:43 PM
DrewMan's Avatar
what are the benefits of a carbon clutch over a normal metal one (besides being lighter of course). Some of those clutches are in the 1K range and over!
Old May 27, 2007 | 07:19 PM
takahashi's Avatar
Stronger, clamps better, more direct power to the drivetrain, more resistant to heat on extreme operation.
Wears quicker.
Old May 27, 2007 | 08:44 PM
DrewMan's Avatar
in other words... good if you have lots of $$$
Old May 27, 2007 | 09:03 PM
auzoom's Avatar
Hmmmmmm.........
These guys are worth checking out http://www.xtremeclutch.com.au/
Old May 27, 2007 | 10:11 PM
Cromax's Avatar
Buzz Buzz Buzz
Does Exedy sell a heavy duty kit for our cars yet?
Old May 27, 2007 | 10:53 PM
takahashi's Avatar
Both single metal and single carbon plate are available from Exedy Japan. I confirmed with Exedy Australia long time ago that they can get the same.
Old May 28, 2007 | 02:10 AM
rotarenvy's Avatar
I was under the impression carbon takes more load with less pressure plate force and less nasty side effects than ceramic and metal friction materials making them more forgiving for street driving.
Old May 28, 2007 | 02:38 AM
Cromax's Avatar
Buzz Buzz Buzz
Know of any brands who sell SiC replacement clutch kits?
Old May 28, 2007 | 03:00 AM
DrewMan's Avatar
I went with the ACT HD clutch and prolite flywheel combo.
about 500 all up
Old May 28, 2007 | 03:43 AM
rotarenvy's Avatar
have you guys read the broken clutch pedal thread in the tech forum? seems like heavy clutches are causing mechanical failures.
xAgyex
Jun 3, 2026 03:47 PM
blainezoomzoomrx8
Sep 9, 2017 08:29 PM
Zank300
Aug 26, 2015 07:40 PM
RXeckless
Aug 16, 2015 12:51 PM
