View Full Version : DIY: Fog Light Rewire
18bsTiRX8 04-06-2006, 10:55 AM Here is a bad picture of where to put the other end of the extension. You will want to use a non-insulated blade connector to push in next to the wire terminal. The wire that the extension needs to be connected to is the larger green/white wire which attaches to the underside of the Tail relay.
Hope this helps.
I want to have the fog lights on with the parking lights and headlights (not the ignition on option).
I read this post and the one from Maniac to accomplish this.....this one says connect to a green/white wire of the Tail relay, and Maniac's post says connect to a Black/Red wire of the tail relay. Whats the difference????
BTW I know this is a revisit of an old post....I assume the wires are the same in my 2005.
Aipex8 04-14-2006, 12:14 AM I just did the mod tonight following Maniac's instructions, except I used a tap-in connector. Works perfectly!
These do the same thing in theory, one is connected to the tail relay, the other (Maniacs) to the tail fuse. I tried the green/white first, and while it worked, I didn't like the fact that the connector was just wedged in there. I didn't have a tap-in connector for the larger green/white wire, so I pulled it out and connected it to the red/black.
You guys that figured out these different variations of this mod have heard it all before, but you rock! :rock: Thanks a lot!
tejon 04-26-2006, 09:59 PM Thanks for the info. It was an even simpler mod than I thought it would be, especially with the excellent pictures.
As others have noted, the foglights do not have an impressive output by themselves. I think that they are most useful as daytime running lights. I would like to make them function more as fog lights (greater light output). Has anyone tried replacing the H11 bulbs with H9s? This site, Daniel Stern Lighting Consultancy and Supply (http://www.danielsternlighting.com/products/products.html), suggests that it is possible, and that there would be a significant gain in light output if the foglight fixture itself can handle the increased light from the H9 without causing excessive glare.
EyeBall Fixer...(o)(x) 04-26-2006, 11:23 PM Thanks for the info. It was an even simpler mod than I thought it would be, especially with the excellent pictures.
Looks like it would work. The H9 is inexpensive and I may have to give this mod a try.The difference in light output between these two designs is enormous (1350 lumens from the H11, 2100 from the H9), so putting an H9 in place of an H11 will obviously cause the lamp to produce a lot more light. Some lamps are designed such that the optics will handle the extra light well, without creating excessive glare for other road users.
tejon 04-27-2006, 07:44 PM I tried to find some H9s today. No luck. No one in town stocks them. I am going to order them.
HCTR154 04-28-2006, 05:05 PM I tried to find some H9s today. No luck. No one in town stocks them. I am going to order them.
I have been thinking of h9's as well. I was looking at the fog lights today and was wondering....how the heck do you get to the bulbs? :spank:
Tamas 04-28-2006, 05:24 PM It's pretty easy - you can do it from below, unscrew the plastic undertray, and you can reach in to remove the bulb, turning the socket counterclockwise a 1/4 turn.
chr1s 04-29-2006, 09:16 PM I just replaced my bulbs today, I just removed the 3 screw/bolts from the diffuser (the plastic undertray tamas is referring to). I them opened the diffuser enough to get my hand in there and removed/replaced the bulbs.
zenmoused 05-01-2006, 08:55 AM I did this mod yesterday (finally) with some bulbs I bought from Autolumination.com. I just want to thank the pioneers who figured this out. Magnesium and Omicron- you guys rock! I decided to do the Omicron variation, because I wanted the functionality of turning them on whenever the key was in the on position. Now I'm rockin it with white/blue front marker led's and bright yellow fogs! (By the way, if any of you guys need to get lights, check out autolumination. I got all four bulbs I needed for under $20, including shipping. I can't speak to the longevity of the bulbs... but they are very nice looking.)
tejon 05-10-2006, 09:45 PM I repaced the original forlight H11s with H9s. They are much brighter (they are the same bulbs that are used for the highbeams).
The H9s fit into the fog light housings. However, there is one hitch to the installation, the H9 and H11 bulbs have different contact alignment tab configurations and the foglight wiring connector will not fit onto the H9 bulb. I will not dwell on how long it took me to realize this :Eyecrazy: . The most elegant mod would be to replace the H11 wiring connectors with ones that fit H9s. But I was impatient, so I just modified the bulbs.
The H11 bulbs have a single plactic alignment tab between the contacts. The H9 bulbs have two of these tabs. They are between the contacts also but one on each side. I just removed the alignment tab from the H9 bulb that is not on the H11 bulb. The wiring connector then went right on.
The easest way to remove the tab would be to use a dremel tool, but I did not have one. I used a drill bit and "routed" it out. I secured the bulb base in a vise while I did this. I bent the contacts doing this, but they were easy to straighten.
I am comfortable driving up to 40-45 mph on a dark country road with only the foglights on (had to try them). Maybe they will work as real fogs now - they have to be better than they were.
Hotsauce 05-10-2006, 11:52 PM I repaced the original forlight H11s with H9s. They are much brighter (they are the same bulbs that are used for the highbeams).
What is the wattage of a H9 bulb? I replaced my stock 55w H11s with 80w bulbs. The bulbs started to bulge out from the heat. I put the stock bulbs back in. Inside the fog housing their is another housing that seems to block direct light from the bulb. This will contain heat, I wonder if its possible to remove this internal housing.
tejon 05-11-2006, 07:20 PM H9 - 65 W
H11 - 55 W
The following is from the Daniel Stern web site:
"the H9 has different base keys than its H11 low-beam counterpart. Somebody goofed on the spec, though, for the difference between H11 and H9 base keys are insufficient; it's too easy to install an H9 bulb where an H11 belongs. The difference in light output between these two designs is enormous (1350 lumens from the H11, 2100 from the H9), so putting an H9 in place of an H11 will obviously cause the lamp to produce a lot more light. Some lamps are designed such that the optics will handle the extra light well, without creating excessive glare for other road users."
Was it the outer lens that deformed with the 80W?
tejon 05-11-2006, 07:24 PM Hey, sorry about that font, I didn't realize it had changed.
Hotsauce 05-11-2006, 09:12 PM H9 - 65 W
H11 - 55 W
I don't think it wsa the outer lens the deformed the 80w bulb, but the internal housing. Its a gray housing that the bulb slips into, it looks like it can be removed. I also read a thread here that someone's outer lens cracked due to using a higher wattage bulb 100w. Keep us updated on the H9s let us know if you have any problems.
Stavesacre21 05-16-2006, 02:58 AM feel like I'm resurrecting this thread from the grave, but I HAD to send a shout out...
Sounds like a nice mod...kudos to the founders :ylsuper:
I've did this same mod to my 97 Cobra and Probe, and I know first hand the hours and time it takes to locate the wires and know that understanding which wires go to which relays can be aggravating.
From the pics, the fuse box location is TOO convient too! Not to onset a pity-party, but in BOTH my Cobra and Probe, you had to pull switches out of the (Probe) center console, and (Cobra) center column. You think you have short wiring to work with here? HA...I can tell you first hand that we should be so lucky to have THIS much wire play as the 8 does. Mazda got one part right for sure... :worship:
Much thanx goes out to the pioneers of the mod, including Magnesium, Omicron and Bobclevenger. You guys saved hours of time for anyone whos up on this mod
NOTE FOR CANADIAN CARS.....
To bypass the DRL module (behind the glovebox) you need to connect the 'fog in'(light green&black) and 'fog out'(yellow&red) at the big DRL connector. They are side by side at the lower left of the connector. Also, the 'brown' wire on US cars is 'brown&white' striped for DRL models, but it IS the same wire as in the Omicron instructions.
S
I can't find this module... behind the globe box? Which one?
That part is there to make sure that you get a well-defined output pattern. If light were allowed to come directly from the front of the bulb, it would produce a lot of "spill" light in all directions, which is not something you want in a fog light -- you want most of the light being formed by the reflector, into a desirable pattern. Most bulbs will have the top of the bulb masked already, but that little piece of metal is cheap insurance.
Much love to Omnicron, Magnesium, and Bobclevanger! The directions for the fog light mod we perfect, only took 10 minutes and now I can run the fogs when and how I want.
Very cool.
-Rate
dwynne 07-06-2006, 07:08 PM Be sure to switch the fog switch off if you take the car in for service. I had the gas tank recall done last week and forgot to switch off my "always on when switch is on" fogs off. When I picked up the car I noticed that someone had turned off the fog switch - I guess they wondered why they were always on when the key was on. I am lucky they were not concerned enough to try to "fix" the problem.
I will remember to switch them off next time :D
Dennis
Terrance26 08-12-2006, 04:07 PM This was by far the easiest DIY I have ever done with great results. Appreciate the leg work magnesium.
2maxxx 10-12-2006, 04:19 PM My Sincere Thanks and appreciation to all who contributued to make this such a popular, and what I consider significant modification.
2Maxxx
nAVEL 10-20-2006, 09:53 AM Has anyone figured out the variation of this mod that will keep the fog lights on ALL the time - bypassing the foglight switch all together?
This would be an excellent solution for those who want to turn the foglights into "true" DRLs - for insurance discounts or to make US spec cars compliant in Canada.
Anyone know the wiring modification to bypass the switch all together? It would be most appreciated!
-nAV
StealthTL 10-20-2006, 11:05 AM To turn the lights on whenever the ignition is on is fairly simple.
The fog relay gets it's power from the headlight relay, so no headlights = no fogs.
The switch just grounds the relay coil.
So you would need to disconnect the W/B wire on the fog relay, and get switched power to the relay from the W/R terminal of the "acc" relay (close to the fog relay).
Then you would disconnect the LG/B wire on the relay, and wire it to a ground, this bypasses the switch.
S
nAVEL 10-20-2006, 12:17 PM Right on StealthTL! Thanks !
It worked great. I rewired my fog lights as outlined by Omicron.. Then I grounded the light-green/black wire from the fog light relay to a ground (I used the bolt in front of the fuse box - I needed to add extra wire on to the LG/B wire to extend it that far) and it works!
My fogs are now always on whenever the ignition key is in the 'On' position, regardless of where the fog light switch is. (And that makes the car compliant with Canadian DRL laws - excellent!). :mdrmed:
New Yorker 10-31-2006, 03:23 PM There are 274 posts in this thread, talking about everything from wiring the fog lights as daytime running lights, to changing bulbs, to wiring side marker lights as "repeaters", etc, etc, etc.
All I want is to have my fog lights work independently of the headlights, so I can actually use them as fog lights in an actual fog.
I don't have time to read each of the 274 posts—can anyone refer me to exactly what I need to do?
Thanks so much!
glassetcher 10-31-2006, 03:34 PM Go to post #34 of this thread by Magnesium with pics. That's the technique I used and it works great. He also gives a text only description in post #24
Zoom, Zoom!
dwynne 10-31-2006, 03:35 PM So you want US to read the 275 posts and tell you which one to follow? Sorry, *I* don't have that kind of time :Eyecrazy:
I have mine wired where they are connected to the accessory power as is described here someplace. The foglight switch controls them so I can have fogs only, fogs w/parking lights, fogs w/low beams, fogs w/high beams (makes no sense) if I want. Just read along until you find the proper post - you connect the same wire from the fog light relay it just depends on where you connect the other end - I sure don't remember the details, but it is all here with pictures.
Dennis
1145climber 10-31-2006, 03:36 PM hahaha, i feel your pain bro... someone should post the actual DIY clearly at the beginning...
here's some highlights:
1. http://koczarski.com/RX8/Mods/FogLight/ReWire.htm
2. Page 12, post 170
3. Page 7, posts 100, 101
4. Page 6, post 76
5. Page 5, post 62 (looks really helpful)
6. Page 4, post 52
7. Page 3, post 34
New Yorker 10-31-2006, 04:02 PM Thanks for pointing me to the right posts, everyone—I really appreciate it!
dwynne 10-31-2006, 04:19 PM Be sure to switch the fog light switch OFF if/when you take your 8 into the dealer for service. Having the log lights on w/o the low beams could make them think something was WRONG with your car and then open the fuse/relay box and "find" your mod.
Dennis
screamindean 11-19-2006, 06:22 PM Great mod. Simple and effective. I liked the pictures from http://koczarski.com/RX8/Mods/FogLight/ReWire.htm best. They are very clear.
93rdcurrent 11-19-2006, 07:26 PM Be sure to switch the fog light switch OFF if/when you take your 8 into the dealer for service. Having the log lights on w/o the low beams could make them think something was WRONG with your car (#) and then open the fuse/relay box and "find" your mod.
DennisThey did it to me once I made them change it back. :spank:
Archie_second 11-24-2006, 04:57 PM One head is good but two is better... Thanks for the mod... Молодцы!
aznboyga 11-24-2006, 06:44 PM Great thread. I plan on doing the mod this weekend along w/ marker lights. Thanks to everyone espcially Magnesium.
Mad Pole 12-12-2006, 05:29 PM I just completed the fog light rewire mod in about five minutes. Super easy, works like a charm.
Thanks to everyone that contributed.
Thack 01-07-2007, 09:08 AM Took five minutes. Hardest part was unclipping the fuse box. lol. thanks all
NotAPreppie 01-14-2007, 10:36 AM Wouldn't it be simpler and more reversable to remove the relay and jumper the power pins for the fogs?
18bsTiRX8 01-29-2007, 02:15 PM No, at least I don't think so.
The 'Brown' wire is the trigger for the Fog Light Relay and goes "hot" when the headlights are receiving power. If you jumper the Fog Light Relay switching terminal to the Tail Light relay or Accessory relay, you will give power to the Fog Light Relay and allow them to turn on early, BUT you will also be putting power into the 'Brown' wire to which is connected to the headlight circuit.
Without looking at the wiring diagrams, I am not sure what adverse affect (if any) this may create. But I imagine you will still have to cut the 'Brown' wire.
It is definately another way of solving the same problem, but if you still must cut the 'Brown' wire, I think the soldering to the Tail Light relay trigger wire ('Black/Red') would make a more solid connection with less risk of fire or blown fuses.
Just my 2cents....
PS I organized the DIY from "Maniac" for using the 'Brown' and 'Black/Red' wires in order to have an OEM-like function, with fogs coming on with parking lights. I put the pictures and instructions into a more printer friendly format in a Word doc. Unfortunately, it appears to be too large to attach on here. Anybody willing to host it and post up a link? Leave me a PM with an email addy so I can send the file.
Credit goes to Maniac, Post #62 for the best and most professional method, in my opinion.
Jedi54 01-29-2007, 03:24 PM this is a great mod but I just soldered the wires instead of tapping into the green wire like the instructions say to.
18bsTiRX8 01-30-2007, 11:19 AM green wire? I must have missed that set of instructions!
I know of 2 methods (but I didn't spend hours sifting through this thread):
1 - Brown wire into Black/Red wire --> fog lights go on with parking (running) lights
2 - Brown wire into small White/Red wire --> fog lights can go on anytime you turn on the fog light switch independent of headlights AND parking lights.
I have no clue about a green wire????
Jedi54 01-30-2007, 01:27 PM it's pouring rain right now but I"ll take a pic when I get home of what I did.
NotAPreppie 02-04-2007, 05:04 PM No, at least I don't think so.
Hmm, I think we might be on different wavelengths here. That or I'm completely talking out of my ass.
The relay (and it's socket) should have four terminals that we are concerned with. Two for signal/switching (headlight) and two for providing power to the switched circuit (fogs). There may be more, depending on whether or not it's more than just an SPST relay. My idea is to just short the switched terminals on the relay (or it's socket) so that it doesn't matter if the relay is open, closed or not even present, power will still flow to the fog lights.
Unless I'm way off here and the power for the fog lights comes from the same circuit that triggers the relay (which I don't see as very likely as the fogs have their own switch).
I'm probably being a little noobish here as my electrical knowledge is somewhere just below beginner.
dwynne 02-04-2007, 05:36 PM If you bypass the relay, the fogs will always be on as long as the log switch inside the car is on. So if you forget to turn that switch off, you will drain your battery.
The various ideas here tie the control line of the fog relay into something like a parking/running light or to the switched +12v. Then the fogs come on when the switch on when the parking or headlights or on or when you turn the key on. In both cases, turning off the key and the lights will result in the fogs goinf off automatically even if the switch is left on.
I wired mine to the switched accessory source and use them as DRLs - the come on and off with the key (unless I turn off the fog switch). I did a similar mod on my new "snow day" car, a Scion xB and again use them as DRLs.
Dennis
18bsTiRX8 02-07-2007, 12:26 PM Hmm, I think we might be on different wavelengths here. That or I'm completely talking out of my ass.
Yea, I think we might be a different wavelengths here :)
I think the mod you are suggesting is to create a DRL situation; in other words, fogs come on with ignition.
My understanding of the relay switching circuit is that yes, there is generally 4 terminals. Two of the terminals can be thought of as the high current input/output...essentially a break in the main power wire. This "break" in the main power cable becomes connected by the internal switch which is triggered by power to the "switching" circuit. This is made up of the other two terminals, one of which provides + power to the relay switch itself, and the other is - ground.
Once again, I am not sure I followed you correctly, but when you said you are not concerned with whether the relay is open/closed, you are suggesting jumping the input/output terminals together.
Generally speaking, high current lighting applications require the use of a relay to isolate the switching system from the high current wire, mainly to protect the switch itself. The high current wire (on the input/output terminals of the relay) is usually connected directly to a main power distribution point on the battery.
If you short the two main wires together, you are by-passing the switch and I believe the result will be fogs that are on until your batter dies regardless of any relay (or interior headlight switch).
I still believe this entire long thread can be summed up with two high quality/reliable DIYs:
1) For a DRL effect, where the fogs come on with ignition (unless you turn off the fog light switch on the stalk): cut the "Brown" wire and connect the fuseblock side of the cut wire to the small white/red-stripe wire (ACC)
2) For the same OEM-like function where the fog light switch on the stock can be left on, but the lights only come on with a lighting circuit (modded to the parking light circuit instead of the OEM method of the headlight circuit): Cut "Brown" wire and connect fuseblock side of cut wire to the black/red-stripe wire on the parking light circuit.
dwynne 02-07-2007, 12:45 PM I will add to your summary:
If you do the mod, but sure to turn off the fogs (at the stalk) when you take the car into the dealer for service. If they notice any difference from normal behavior they may investigate or try to "fix" it. If you turn them off at the stalk the odds are very slim they will even look at them at all.
Dennis
type59 02-25-2007, 02:12 AM i read through all the post...well skimmed. do i use the black/red or green/white? i want the fogs to go on when i use the DRL or headlights, not anytime i want.
the fogs also go off when i turn off the DRLs right?
Detrich 02-25-2007, 06:54 PM Hi Jeff,
Thanks for the step-by-step + detailed photos. It's much more easy to follow for a newbie like myself. If you don't mind, I have quick follow-up questions as well..
What do u do to protect the other side of the cut brown wire? (ie the side no longer connected to the relay.) do u just use electrical tape to cover the tip or is it safe to just leave it dangling?
Also, is it true that your flavor of this mod is actually "safer" than Omicron's ACC one? It sounds safer to me, because it doesn't mess w/ the ACC wire (ignition) at all, which could potentially mean your car won't start if you mis-wire or do something incorrectly.
Thanks in advance for clarifying these points for me.
Detrich
Attach the BROWN wire to the stripped section of the BLACK and RED wire, solder the connection and cover the junction with the shrink tubing. Shrink the two sections of tubing with the heat from the solder gun:[/b][/i][/COLOR] [/SIZE]
Krasnog 03-31-2007, 12:24 PM Argh - why can't I do something so simple.......
Brown Wire goes from blackbox to thin white w/ red strip wire two blackboxes down.
Right??
At one point the lights were all flickering crazy. Then I rewired and got lights working normally (except fogs would never come on). I've reversed all changes out, but now the car won't start.
Krasnog 03-31-2007, 09:35 PM Well, this wasn't exactly a quick mod for me. My first mistake was trying to wiretap using the the brown wire leading away from the box. My second mistake was using cheap connectors/wiretap. My third mistake was not recoginizing a blown fuse.
Those 3 led to all sorts of confusion. A very easy Mod, if you take your time. I tried to rush it and screwed stuff up. =)
But - the car is okay now, AND i can turn on my fogs whenever I want now (did Omicron method)
Krasnog 04-02-2007, 07:45 AM If you disconnect the battery you will need to follow the procedure on 5-22 of the owners manual to re-enable the DSC (if installed) after re-connecting the battery.
Thank you! I about had a heart-attack when it was flashing....
redstar1 04-04-2007, 01:46 PM Does anybody know a way to wire it so the fog lights come on with the ignition whether or not the switch is turned on, but then turn off when the high beams are activated. This it the requirement to pass a provincial inspection for DRL's on a Canadian automobile.
416to212 05-29-2007, 01:33 PM Did the Omicron mod over the weekend. I didn't get fancy though - just used tape to wrap everything...
I'll be moving on to modify an H9 bulb to fit the H11 foglight socket so I can get more light...
lamho 08-27-2007, 12:01 PM any detailed instructions or pics of how to do this on a canadian model???
He||hammer 08-27-2007, 12:12 PM Should be the same, I don't think the wiring is going to be any different
StealthTL 08-27-2007, 12:36 PM lamho - see post #214 in this thread for the canada instructions, wire colours are different, and an extra wire to connect to bypass DRL module.......
S
flomulgator 09-03-2007, 06:33 PM Don't know if this had been posted before but I just did this mod, had no soldering experience or equipment. Used a 22-18 gauge Quick Splice that you can pick up at any auto store. Worked great, and is secure (better than electrical tape).
Maniac, thanks for the instructions, couldn't have penetrated that forest of wires w/out.
infamousdesi06 10-14-2007, 07:55 PM question jus to clear things up for me - you cut the brown wire first and you have to connect that wire with what other wire.. i think the small black and red wire? am i right? this is to use the fogs when the parking lights are on and also.. if i want.. when the headlights are on
This is still one of the coolest mods. It even helps me protect the life of my HID lamps. I park in a parking garage and I like to turn on some lights for visibility. Turning on HID is very hard on them -- you only get so many starts so it's bad to waste them on 5 minute runs. With the fog light rewire I can use the fogs instead. Brilliant!
TRAVASS 10-15-2007, 04:48 PM I just did my mod the way that Omicron suggested several pages ago in this thread. Only thing i did different was this:
My brown wire was long enough to just reach over to the ACC realy and connect dirrectly in without splicing or using the addtional red wire that was previously suggested. Works great thanks!
BigRed 10-15-2007, 04:51 PM i probably should do this soon...
Speedy400 10-20-2007, 12:33 PM Nice mod. Took about 10 mins. Did this to my MX5 as well.
Next - put in LEDs all around.
Socket7 10-20-2007, 01:37 PM Brilliant mod! Just did it in 15 minutes. half of which was finding a pair of pliers to clip the vampire tap onto the wires completely. Used maniacs method so they come on with the parking lights. folded over the remaining brown wire and heatshrinked it to itself to prevent a short.
http://isomerica.net/~fluffy/Ren/renfog.jpg
Spinning Sushi 11-20-2007, 05:33 PM Anyone want to do this for me? I'll buy you a brew :)
WAR CRUNK 11-20-2007, 06:23 PM im still confiused...all i want to do is the reagualt without messing with the balck and red wire...so all i want to do is basickly snip the bronw..correct?
yenphi 11-29-2007, 12:51 PM did this mod, like it alot,using brown taped into small white/red wire, but problem is when I park and listen to music, the light is also on, is there a way to re-wire so only light is on when you turn the car on? did I miss a thing? thanks.
New Yorker 11-29-2007, 02:22 PM I forgot if this has been discussed somewhere in this thread, but if I rewire so that the fog lights can be on by themselves—without headlights—will they be effective as "real" fog lights in a dense, pea soup, 34-car pile-up kind of fog?
chancejat 12-01-2007, 09:30 PM just did this today and blew a fuse.....car wouldnt start.....it took me 2 hrs to figure out witch one.........it was a 15 for the ignition..........just in case it happens to anyone else.............but the car looks sweet now.......thanks everyone
Speedy400 12-01-2007, 10:12 PM My guess is that you tried to do this without disconecting the battery? Why did the fuse blow!
Myardor 12-01-2007, 11:06 PM Did it yesterday. Easy
Cut brown wire
spliced it into small red/white wire from ACC relay
Did not disconnect battery
no blown fuse.
works great
thanks
chancejat 12-01-2007, 11:09 PM My guess is that you tried to do this without disconecting the battery? Why did the fuse blow!
yep...........and to think i am helacopter electrician for the coast guard.......
Myardor 12-01-2007, 11:14 PM did this mod, like it alot,using brown taped into small white/red wire, but problem is when I park and listen to music, the light is also on, is there a way to re-wire so only light is on when you turn the car on? did I miss a thing? thanks.
If you spliced into the smaller of the 2 wires from the ACC relay, then you can turn the fog light off by turning the fog light switch off. Located next to where u turn on the headlights.
Myardor 12-01-2007, 11:20 PM My next question:
Can now I install a second set of Fog lights?
Run wires to a different switch?
I did get the switch/dsc that has a fog light switch on it. Wonder how hard it is to use that one?
Is it legal to have 2 sets of fog lights?
Would want a yellow set but not sure if LEDs or not.
any comments on that?
Thumper3322 12-03-2007, 01:05 PM I just did this on the weekend to hopefully pass DRL here in Canada, will find out tonight if it passes. It is so simple thx to Magnesium and Omicron you guys rock!
The whole thing took 10 min. if that. I attached it to the ACC using a 22-18 gauge Quick Splice and caped the other end of the brown wire so it wouldn't short on anything. I think it is even easier doing it this way and don't have to waste time splicing wires or anything. Worked like a charm!!
Hope I pass the inspection tonight :)
Thx again guys!
Thumper3322 12-04-2007, 08:24 AM **UPDATE**
Had the inspection last night for Canadian DRL and passed with no problems :) Mazda quoted me $204.99+tax to put in a DRL module. HAHA what a joke!
Thx again to everyone that contributed to this thread!
Spinning Sushi 12-04-2007, 08:27 AM My next question:
That's way too much in my pinion. You can run wires from the ACC to your switch, that way you can turn on and off your fogs whenever you wanted to.
Omicron 12-19-2007, 08:23 AM I just did this on the weekend to hopefully pass DRL here in Canada, will find out tonight if it passes. It is so simple thx to Magnesium and Omicron you guys rock!
Thx again guys!
**UPDATE**
VERY cool. Glad this helped. :)
ScreaminRX8 01-01-2008, 09:32 PM I just wanted to thank Magnesium and Omicron for this thread, well for that matter everyone that has contributed to it! I finnally got around to doing this mod the other day and it took all of 10 minutes and works great! I done mine like Magnesium's and also fixed it where I could change it back quickly. Thanks agian guys!
White 8 01-05-2008, 08:04 PM PROBLEM! i clipped my brown wire and tapped into the small white/red acc wire.. my car will not start now! please help!
White 8 01-05-2008, 08:09 PM apparently i may have blown a fuse.. which one is it and where can i get it?
White 8 01-05-2008, 09:04 PM the fuse is fixed and the car is running but now my foglights do not come on at all.. can anybody help me?
ghermangsr 01-08-2008, 12:06 AM I just bought a set of fog lights for my 05 rx-8... it did not come with any wires.... does the base model already have the wiring set up for me to just plug in the new foglights?
Speedy400 01-08-2008, 05:18 AM the fuse is fixed and the car is running but now my foglights do not come on at all.. can anybody help me?
You probably didn't disconnect your battery before you did the mod or you hooked up the wrong wire. Either way, I would double check your wiring or put it back to stock and start over before you turn your fogs back on. It may blow the fuse again if you hooked it up wrong.
Let us know how you make out.
White 8 01-08-2008, 10:43 AM so just to double check.. i cut my brown wire and am tapping it into the little red/white wire. do i tap the brown wire that is still attacked to the fuse or the wire that is running down to the fog lights?
ScreaminRX8 01-08-2008, 07:35 PM so just to double check.. i cut my brown wire and am tapping it into the little red/white wire. do i tap the brown wire that is still attacked to the fuse or the wire that is running down to the fog lights?
You should tap to the end coming from the fuse box.
You must be doing a different mod than I did. I attached the jumper wire to the larger green/white wire. This wire lets me use fog lights with parking light, lowbeams, and high beams but they do not work with lights in the off position. which is how I wanted it. There are a couple of different variations.
ScreaminRX8 01-08-2008, 07:45 PM I just bought a set of fog lights for my 05 rx-8... it did not come with any wires.... does the base model already have the wiring set up for me to just plug in the new foglights?
I done the same thing and mine already had the wires run.. When I bought my foglights the dealership told me that they are already wired just install and plug in..Other than that I don't know because I had the dealership install them for me. I am good friends with one of the guys and they didn't charge me much to install. So, I let them so I would not have to fool with pulling the nose piece off.
White 8 01-09-2008, 09:38 PM ok.. do i do anything with the other end?
Yellow888 01-10-2008, 05:27 AM I'm followed this instruction. Done less than ten minutes. :lol:
p.s. Thanks, Koczarski big help
New Yorker 01-10-2008, 02:01 PM Magnesium vs Omicrom: I'm confused, what's the advantage of each method, exactly??
ghermangsr 01-10-2008, 08:39 PM when installing fog lights is it really necessary to take off the whole nose piece?
White 8 01-12-2008, 05:32 PM went out and got a smaller gauge quick splice to try and it did the trip. looks great and thanks to everyone who helped me
MPG > HP 01-12-2008, 09:00 PM when installing fog lights is it really necessary to take off the whole nose piece?I have the same question, as my right side just burned out. Any DIYs already in here?
rowteree 02-05-2008, 09:33 PM i just attempted this mod and to be honest at first i thought i would screw up, but i re-read the directions carefully and it took me less than 30 minutes! Great mod for those of you who are trying to save $$, but yet still improve the vehicle
TRAVASS 02-06-2008, 06:17 PM I have the same question, as my right side just burned out. Any DIYs already in here?
I have taken my psgr. side fog off and put it back on without removing the bumper, but I am not sure to answer your question. An install could be different. and the driver side has the oil cooler right behind it. crank the wheels both directions and take a look.
Isn't there a bracket or something that needs installed also?
slimjimrx8 03-29-2008, 01:28 AM sorry for this but there is alot of posts to read.
but if i want to just be able to run my foglights with my parking lights or by itself only (no headlights)
what should i do? step by step, pictures are a big pluss
thank you in advance.
slimjimrx8 03-29-2008, 01:45 AM also i forgot... is there a way i can do all this with high beams able to go on at same time without goin under the hood everytime
glassetcher 03-29-2008, 06:48 AM Just read the first 3 or 4 pages of posts. You'll get your answer. See post #196 for my input.
Zoom, Zoom!
Batman&TheBatmobile 03-31-2008, 06:01 PM just did it Omicron-style. took like 10 minutes. simplicity is a virtue.
Just did the Omicron method exactly as AdamK did with the self stripping tap connector.
Like Thumper, I did this on a car I'm importing into Canada so hopefully it passes inspection like his did when I take it in the next couple days.
FinallyRearDrive 04-22-2008, 01:08 AM Thank you so much guys. it took me about 8 minutes, and I couldn't be happier with it. The lights being wired to the ignition is a nice little touch, too!
RE-Jo 05-06-2008, 01:23 PM Will the DSC light for sure come on when doing this mod? How do I fix it, I don't have a manual so I can't refer to page 5-22... (I haven't actually done the mod yet)
Thanks in advance~
StealthTL 05-06-2008, 01:26 PM Anytime you disconnect the battery, the DSC will show a problem.
Turn the steering wheel full left, full right and it should reset.
S
RXallan 05-25-2008, 12:14 AM just finished rewiring my fogs.
they are now on when ever the ignition is on, regardless of the turn stalk position.
i connected the brown wire to the red/white wire as outlined by Omicron, then grounded the green/black wire .
markryan22 06-05-2008, 04:11 PM fuck. i did it but forsome reason the brown wire is my head lights... any reason why? lol
Farrellrm 07-06-2008, 06:41 PM just did this
took about 10 min
was incredibly easy
Ryan2008 07-24-2008, 07:44 AM Nice DIY! However, is there anyway to rewire them like you guys had it with the fogs coming on whenever the stock switch is turned, but instead of coming on with the ACC, switching it so it turns on WHENEVER I turn the switch? (Key or no key in).
dondo 08-12-2008, 01:29 PM thanks omicron! this took like 3 minutes since i had everything on hand already.
good mod.
AKAFC 09-09-2008, 09:38 PM Awesome, did it in 6 minutes flat. thnx mag!
Someone please help me on this. I must have missed something. I read through this whole thread and could seem to fine an answer. I follow instruction and want to wire my fog light as a DRL when the key is in ACC position - connect the small brown wire going to the fog relay to a small white/red wire on the ACC relay. When the key is on ACC or engine on, my Head light and High beem is on but no fog light what so ever!!! I have 05 GT live in US.
Thumper3322 09-14-2008, 02:34 PM Someone please help me on this. I must have missed something. I read through this whole thread and could seem to fine an answer. I follow instruction and want to wire my fog light as a DRL when the key is in ACC position - connect the small brown wire going to the fog relay to a small white/red wire on the ACC relay. When the key is on ACC or engine on, my Head light and High beem is on but no fog light what so ever!!! I have 05 GT live in US.
Dumb question - but you turned the Fog light switch to the on position right?
Footman 10-02-2008, 04:06 PM FYI, I am doing mine right now, and I don't know if it's a matter of country or year, but the 2007 Canadian model is NOT a brown wire... I'll try to get some pictures and post later, I don't know if anyone bothered to know.
Footman 10-02-2008, 06:59 PM Nevermind... I found the post #214 by Stealth which lead me to a search for "Canadian fog light rewire" and I found all the info I needed. It works now.
One needs to do the OMICRON method + STEALTH method to make it work for Canadian cars.
I also cleaned the air cabin filters too while I was at it hehehehe.
You actually don't need to remove the glovebox to access the DRL module connector. It's within reach if you look under the footwell of the passenger side as I realized. When I removed the glove box, there is a BLACK BOX MODULE in front of the DRL. To gain access to the DRL, one would actually have to remove the black module first if you were going through the glovebox. I looked underneath, and realized that the DRL module connectors are accessible just from the bottom. No need to remove glove box.
This maybe only applicable to Canadian models? I'm not sure what that black box module is.
Footman 10-02-2008, 07:18 PM http://img523.imageshack.us/img523/2498/pa029130mt7.jpg
BBQdDude 11-29-2008, 04:35 PM Did mine just now. Took a few more than most as I was hooking the wrong end of the brown wire up :banghead:
Things you will remember until the day you die :lol: .
Take care,
Brian
bobkat181 12-12-2008, 06:58 PM i did the brown to the small red/white. worked like a charm. thanks to all.
Lord ET 01-10-2009, 11:00 AM Man this was easy, snipped the brown wire, vampire clipped to the red/white and that's it... took 1 minute once the fuse block was up. (it's freezing out so the wires were stubbornly stiff)
Props to all who contributed!
HockeyRX-8 02-05-2009, 07:26 PM I kept putting this off and I was finally able to do this last monday. Took about 10 minutes to do and the end result came out great. I also did it as per Maniac's instructions.
yenphi 02-11-2009, 03:35 PM For some reason, my fog light is off some times ago i did not aware. I check the fuse (15 a) and it is still ok. To be safe, I return the wiring to original and the fog light still off, any idea? thanks
Jedi54 02-11-2009, 03:56 PM both lights are out?
maybe the bulb is bad?
yenphi 02-11-2009, 08:50 PM yes both, but how rare is it for both bulbs to go bad at the same time? is there any way to test w/out going to dealer?
dirtybirk 02-18-2009, 07:32 PM I found some of the connectors discussed earlier in this thread. However, they come in three different sizes and was wondering if anyone knows what size the wireing is?
James
yenphi 03-07-2009, 09:01 AM it is warm today, so i took off the fog bulb, and it looks ok, so the fuse is ok, the relay is ok and the bulb still ok, what happen ? please anybody have any idea?
jsjjr 04-07-2009, 07:08 PM Done. It actually took about an hour to do this.. 40 mins of it was chasing my dang dog around the freaking neighborhood!:rant:
always.anthony 04-19-2009, 12:06 AM how would i rewire my license plate to only light up when the lights (not parking) go on? i want to have a creeper setting, fogs + parking lights only :D
always.anthony 04-21-2009, 08:36 PM cough cough
peterlemonjello 04-22-2009, 07:25 AM I bet u haven't gotten any replies because everyone's worried who ur creepin up on.
always.anthony 04-23-2009, 01:52 AM I bet u haven't gotten any replies because everyone's worried who ur creepin up on.
hah not creepin on anyone, just love the way my 8 looks in pictures with the parkings :)
klovec 05-01-2009, 12:38 AM Easy job well worth it. Took 5 mins
RxMadness 05-02-2009, 07:23 PM Awesome, been wanting to do this since my last car. Went with Maniac's method and finished about 10 minutes ago, took a little over an hour to do thanks to poorly timed distractions from my neighbors, dogs, and phone. And of course this being my first time soldering anything I burned my thumb, but it was totally worth it :cool:.
edit: please excuse the poor cell phone night shot, no idea where my camera is.
Force 8 05-06-2009, 09:26 PM I chose to perform the Omicron version for maximum flexibility and it worked perfectly. The clear pictures give confidence but it's still a bit scary when you're about to cut that first wire though.
yokohamaboi 05-17-2009, 10:33 PM im so glad i can bypass my aftermarket HID so i can have my fog lights on by it self :D
mat128 05-19-2009, 07:51 PM Check the trunk. Mine stopped working at one point, too - turned out the trunk lid was ajar. The lights will only flash if all doors, trunk and hood are secured.
same thing happened to me.
its good to see if all doors are shut!
mat128 05-19-2009, 07:52 PM Blame the regulators in the USA and Canada.
They mandate that any front lights ( other than marker lights) must only come on IF the low beams are on too. They are lumped together sa "driving lights".
Yes, this totally defeats the purpose of fog lights.
If anybody wants the appropriate pages from the Mazda RX-8 2004 Wiring Manual faxed to them, send $5 to my Paypal account..
I will fax anywhere in N.America for that..
If you need this email me at:
maurice@harddata.com
Even seen a Dodge SX2.0 (new name for the Neon)? They have their fog lights as DRL here in Canada!!
Im not sure if its a "stock only or illegal" thing, but whatever.
ddtran46 08-11-2009, 04:33 AM Yeah....Anyone In Elk Grove/ Sacramento, CA that wants to help out a fellow member? lol Kinda scared doing it
RxMadness 10-01-2009, 11:13 PM Yeah....Anyone In Elk Grove/ Sacramento, CA that wants to help out a fellow member? lol Kinda scared doing itif you haven't done it yet it's pretty easy.
Also figured I'd update my rewire pic
michaelsk8er 10-05-2009, 11:24 AM I went to do this with my 09. Seems I have the same wire colors, same fuse box and everything but it would not work. I cut the brown wire and tried the ACC method first, but the fogs only came on when the headlights still.
Then I tried MMs method and tried the tail light relay and fuse. neither worked. Any reason why it would not work on an 09? Like I said, seems like I have the same fuse box and wiring. Only thing I can think of is it might not be the brown wire on mine, but. I used the first wire on the right side of the relay, out of the four available.
The wire was a different gauge than the ACC wire so maybe that indicates a change.
SayNoToPistons 11-15-2009, 03:58 PM Just did the MM way. Loving it but makes me want to consider LED parking lights and HID fogs now. One mod leads to more temptations :(
Bigbacon 11-15-2009, 05:56 PM someone should consolidate these different approaches into a single thread. Very confusing to find the information. I need to try this though. I hate that you can't have the fogs on unless the lights are on.
realBlackSunshine 11-23-2009, 05:50 AM This one works too http://www.rx8club.com/showthread.php?t=173919
goose guy 01-20-2010, 08:52 PM I went to do this with my 09. Seems I have the same wire colors, same fuse box and everything but it would not work. I cut the brown wire and tried the ACC method first, but the fogs only came on when the headlights still.
I have an 09 also. Tried omnicron's method to a tee (brown wire cut, connected to white with red stripe ACC wire with tap in) and it didn't work. The lights functioned like I didn't do anything at all. I rewired back to original. Any successful intalls out there on S2 models?
sE7ENs 01-31-2010, 12:18 PM done. it took me under 10 mins, but i was being very cautious. thanks guys!!!!
rodjonathan 02-04-2010, 09:36 AM thread bump i havent gone through the whole thread but i was wondering if someone could figure out how to wire em to be on when you unlock the car so i guess like wire em to the interior lights AS WELL AS to the acc or sth if thats possible
Alterego667 02-13-2010, 02:16 AM This is it pretty simply put after reading this thread for years...
http://www.rx8blog.com/rewiring-the-rx8-fog-lights/
It worked like a champ for me....
If you want a different signal source you will havce to find one that fits your needs...
The Brown wire is like a remote wire on an amp for your subs...
kingaaron 02-16-2010, 05:57 PM I finally did this and it took 10 minutes, thanks a lot for the instructions.
fd3s777 03-03-2010, 02:47 AM Great DIY, hook up with my new Day time running Super bright LED lights on my autoexe bumper.
ddtran46 03-28-2010, 02:54 PM Thanks alot to Alterego667 for helping me rewire my fogs!!
Alterego667 03-29-2010, 11:26 PM ddtran46
Anytime man...
Good luck with all your mods and stuff that you want to do in the future...
Myriad 06-12-2010, 06:07 PM need help.
I tried to do this, and I think I really fucked something out (shorted out something). The only electric that works in my car are the lights. No radio or starter (chimes and all interior lights still work). Checked starter fuse and it is okay. Any ideas?
Edit: Didn't check the 15a fuse. It was blown. Now all the interior jazz works again but still no starter.
Edit2: Figured it out. Put the fuse for the engine in the wrong spot. Stupid me.
Myriad 06-12-2010, 07:38 PM Okay, so I'm hoping that some of you who are more talented than I am can help me figure this out.
Basically, I attempted to do this mod all day today. Every time I would try and test the fog lights my ignition fuse would blow out. I made extra sure both sides were taped with tons of electrical tape, and I triple checked I had spliced the right wires. After the third blown ignition fuse, I restored everything to normal and everything works fine, with the exception of my fogs because I have the wire detached and taped (I bought some taps in case I have to put it back together). Any ideas what I could be doing wrong? I know this is useless without pics, but I didn't have time to take any when I had the mod installed. because I needed to get my windows up before the thunderstorm rolled in. I used the vampire clip method.
Thanks guys
EDIT: I think I figured it out. I cut the right wire, and was splicing to the right wire, but I think I was splicing in the wrong end of the fog wire (the one from the harness) into the ACC wire. This would probably explain all of the blown fuses, because although i don't know what that mistake would do, it probably wouldn't do anything nice to the fuse box. Lesson learned, always double check. My stupidity knows no bounds.
Edit2: Fixed it this morning first thing, mod works great, thanks for the great DIY (Even if I did a piss poor job at following it)
silverkillrx8 06-17-2010, 04:26 AM anyone going to post a diy with pictures
Myriad 06-17-2010, 05:27 AM anyone going to post a diy with pictures
Check the first 6 pages as well as http://koczarski.com/RX8/Mods/FogLight/ReWire.htm
silverkillrx8 06-17-2010, 02:00 PM yes thats much easier lol but last question i checked out autozone and couldnt find the tap that he used for the mod
Myriad 07-07-2010, 08:34 PM yes thats much easier lol but last question i checked out autozone and couldnt find the tap that he used for the mod
They sell them at radioshack for sure (where I got mine) in the little drawers.
kailua_chaos 07-11-2010, 12:42 AM sick, always wanted to do that to my fogs too... looks like i'ma have some fun tomorrow!
RX8inSTL 07-20-2010, 05:25 PM Simple mod once i figured out i was suppose to connect the brown wire coming from the fuse to the small red/white wire. Only blew out one ignition fuse.
Rotary-RX8 08-12-2010, 10:08 PM I wanna do this so bad. But meee scared :(. I dont wanna mess up my baby.
^^^^ there is nothing to be scared of... it is so simple. It took me 2min to do it, simple as one, two, three... let me know if you need very simple directions with pictures.
Spin9k 08-13-2010, 05:40 AM ^ +1 did it last weekend. Lol, I studied the pictures posted longer than it took me to do the snip and click. Way easy....
Rotary-RX8 08-14-2010, 08:58 PM ^^^^ there is nothing to be scared of... it is so simple. It took me 2min to do it, simple as one, two, three... let me know if you need very simple directions with pictures.
Yea if you could thatd be great. I tried reading some of the first few pages and i got kinda confused. BTW im trying to make them turn on with the switch not as DRL. So basically i want to be able to turn them on with the switch even if my HIDS arent on.
^^^I got ya... either tonight or tomorrow I will post some very simple directions and pictures, you will see how simple and easy it is.
Rotary-RX8 08-14-2010, 10:53 PM Thanks so much brother. I feel bad cause people already posted the directions but honestly im not EXACTLY sure what to do. Thanks i appreciate it.
no problem, hope it helps you
This has already been covered earlier, I am not trying to take all the credit for this. I'm just trying to make it simple in only few steps with pictures.
This set up will let you use the fogs independently through the fog switch. You could have the fogs by their self, with the parking and side lights or with the headlights. You control them by the switch. Also you could leave the switch ON and turn off the car, fogs will have no power.
So, here it goes... Five steps....
1. Disconnect the negative terminal off of your battery.
2. Remove the fuse box cover, turn it around and locate the FOG Relay and ACC Relay.
http://i290.photobucket.com/albums/ll248/ivothegreat/PIC1.jpg
3. There are 4 tabs on top of the fuse panel, undo the 4 tabs shown on the picture to get access underneath the fuse panel.
http://i290.photobucket.com/albums/ll248/ivothegreat/PIC2.jpg
4. Cut the brown wire coming out of the FOG's Relay enough to rich the thicker White with Red stripe wire.
http://i290.photobucket.com/albums/ll248/ivothegreat/PIC3.jpg
5. Locate the Thicker White with Red stripe wire from the ACC Relay and connect the brown wire coming from the FOG Reray with a wiretap. Make sure to cap the other end of the brown wire as we don't need it any more.
http://i290.photobucket.com/albums/ll248/ivothegreat/PIC5.jpg
http://i290.photobucket.com/albums/ll248/ivothegreat/PIC4.jpg
I tried to make it as simple as I could to understand, but once you open the fuse box you will understand everything.
Rotary-RX8 08-15-2010, 08:32 PM Thanks !! Im gonna this tomorrow. I dont have a wiretap at the moment. I appreciate it.
let us know how it goes...
Rotary-RX8 08-16-2010, 07:59 AM Sorry do I also need to cap off the other end of the red/white wire ? And also I noticed if Iturn off my car but leave my hids and fogs on, they stay on even if my car is off. If I do this and leave all lights on and. Shut off my car, will only the hids stay on ?
Spin9k 08-16-2010, 08:02 AM Sorry do I also need to cap off the other end of the red/white wire ? And also I noticed if Iturn off my car but leave my hids and fogs on, they stay on even if my car is off. If I do this and leave all lights on and. Shut off my car, will only the hids stay on ?
....you dont CUT that one "connect the brown wire coming from the FOG Relay with a wiretap"
Rotary-RX8 08-16-2010, 08:09 AM Kk good thing I asked lol.
Rotary-RX8 08-16-2010, 09:47 AM Sorry one last question. IM having trouble disconnecting my battery. I dont know which nut to unscrew. I tried searching for other DIY but they dont mention how to disconnect them. Sorry im just trying not to kill myself lol.
The Reverend 08-16-2010, 09:57 AM ...the little nut on the side of the negative battery connector is a 10mm i think
just look at it and youll be able to figure out which one will loosen the part that wraps around the terminal
Rotary-RX8 08-16-2010, 09:59 AM Kk thanks !! I wasnt sure if it was the one on top or the one of the side.
The Reverend 08-16-2010, 10:00 AM be careful where you rest it...maybe wrap it with electrical tape while it is disconnected
Rotary-RX8 08-16-2010, 10:21 AM I just did it !!!! Its so easy LOL. I dont know why i was stressing so mcuh. Ye i rested it on the cover of the air filter. But one thing i noticed is i cant turn them on when the cars off liek i used to be able too :( Oh well !!!
I fucked up at first cause the brown wire wasnt fully in the tap and i went ahead and use pliers. Then i had to retake the tap off then add a new one in .
Thanks for the help guys
Rotary-RX8 08-16-2010, 11:35 AM One problem since my ecu got reset everything (clock etc etc) got erased. And at one point my tsc light stayed on but when I shut off the car and restarted .. The light went off .. No biggy
RX8Carnage 08-16-2010, 11:42 AM now im confused does any wires get cut. or is it just a tap from brown to thicker red and white
Rotary-RX8 08-16-2010, 12:39 PM You cut ONLY the brown wire
sorry, looks like I missed the party...
THE ONLY WIRE THAT GETS CUT IN TWO IS THE BROWN
REMOVE ONLY SOME OF THE WIRE RUBBER INSULATION OF THE THICKER WHITE/RED STRIPE (DO NOT CUT IT IN TWO PIECES) TO MAKE GOOD CONNECTION BETWEEN THE BROWN AND WHITE/RED STRIPE WIRES IN THE WIRETAP.
The Reverend 08-16-2010, 03:32 PM just cut the brown
Rotary-RX8 08-16-2010, 04:40 PM Question ... I used to be able to turn on my hids and fogs even if the cars off. Now I'm only able to turn on my hids but not my fogs when the car iis off. is there any way to fix this ? I know this is stupid but I like everything to be "perfect" and I hate being able to turn on only my hids when the car is off.
OK... the Fogs are wired to the ACC Relay. Which means you could only have power/electricity to the fog lights when you turn the key to ACC (turn the key once). You could wire the fogs differently so you have power all the time, even if the car is off, but there will be no beeper to warn you so you don't leave them ON (like the one for the headlights).
In my opinion, the best way is through the ACC Relay. Why would you need to turn them ON when the car is OFF? Plus you could still turn them ON if the car is OFF, just turn the key once to ACC and Voila... ;)
Rotary-RX8 08-16-2010, 07:21 PM Yea but I wanted to be able to turn them on without the key veing turned at all. Oh well !! If you guys have it that way then I guess ill leave it.
Rotary-RX8 08-16-2010, 08:57 PM Just noticed something else. Before when my hids and fogs were on, and i use my high beams. The fogs would shut off everytime i flash my high beams. Now they stay on LOL. Just an observation.
RX8Carnage 08-16-2010, 11:30 PM Done earlier and very easy thanks guys.
RotaryMachineRx 08-18-2010, 06:59 PM So I went to do this mod and I don't have a brown wire going to my fogs relay or the Black and red wire going to the tail relay.... only difference I can think of is I'm in canada and DRL's are mandatory. Can anyone comment on this? I want my fogs to come on when I have the park lights on.
RotaryMachineRx 08-18-2010, 07:27 PM Okay took a closer look, found the red/black wire going to the Tail FUSE not relay and I have a black/white wire going where the brown wire is located in MM's pictures but it is jumpered to the Head Low R fuse ... will the white/black wire be the same as the brown one (just cut it betweem the head fuse and fog relay) or do I need to do something different here? Here are some pictures....
RotaryMachineRx 08-18-2010, 07:47 PM Well I'm gonna go ahead and try this out... I also couldnt find my heat shrink wrap so I'm gonna have to use good ole fashioned electrical tape until tomorrow when the stores are open again.
Edit: Found my shrink wrap!
RotaryMachineRx 08-18-2010, 09:03 PM So I did this mod by soldering the black/white wire that was jumpered between the fog relay and Head Low R fuse to the black/red tail fuse wire. After reattaching everything the verdict is.... Nothing Happened. Does anyone have any insight on this? My fogs still turn on only with my headlights.
Footman 08-19-2010, 02:00 PM You Canadians are all forgetting an extra step that needs to be done in the DRL module. Doing that step will enable you to turn your fog lights on even when your engine is off. It will only require the key be in the ACC position to turn on fogs.
Footman 08-19-2010, 02:02 PM RotaryMachineRX, you pm'ed me about this...
http://www.rx8club.com/showthread.php?t=90749&highlight=canadian+fog+light
Here it is.. read it.
Footman 08-19-2010, 02:04 PM Guys... read my posts: http://www.rx8club.com/showthread.php?t=11737&highlight=canadian+fog+light&page=13
RotaryMachineRx 08-19-2010, 02:05 PM RotaryMachineRX, you pm'ed me about this...
Thanks a ton Footman
yenphi 09-22-2010, 10:40 AM Hi, I don't have fog light for awhile now for some reason, today I replace new fog bulbs, re-connect the wire to original, check the relay fuse, fog fuse they are all good but, there still no light. Anybody has any idea why? with the car on running, I turn all lights and try to touch the bare BROWN wire to other wire and still no luck, thanks for any helpful hint.
04blkRX8 12-03-2010, 01:26 PM I was doing it Omicron's way.....ran the brown wire from the fogs to the thin red and white wire from ACC. When i crimped together with blue connector nothing happened. I tried just wrapping it, thinking I wasn't getting a good connection. Negative. The headlights appeared to be strobbing though. Any ideas. Thanks in advanced!!!
OK, I finally did this using the Omicron method (using the thing red and white wire). The only variation was that I used a T-tap on the white/red wire and male and female disconnects on the two ends of the brown wire, so that if I want to go back the way it was, I just have to unplug and plug.
RogueTadhg 01-23-2011, 04:19 PM Did it Omicron's way. Mostly because it had what I wanted - the ability to have the fog lights on (or off) whenever I wanted.
Xero Ryuu 01-27-2011, 11:56 AM just did this via omicrons method, works perfect! thanks!
Rotary-RX8 06-08-2011, 08:44 PM Sorry quick question. Im going to help my buddy do his foglight rewire. His 8 is Canadian. I was wondering if its the same wires you need to split ?? Or are they different colours. ??
thanks
syntrix 06-08-2011, 09:04 PM Sorry quick question. Im going to help my buddy do his foglight rewire. His 8 is Canadian. I was wondering if its the same wires you need to split ?? Or are they different colours. ??
thanks
Woah, stop right there! Get a fluke or a test light first!!!!!!!!!!
Check the voltages and go from there. A DIY is good for a lot of info, but maybe a canook can chime in. You never stated a year/options, etc, could be some unknown variations in the mix, never know.
Better safe than sorry!
Rotary-RX8 06-08-2011, 09:25 PM I didnt check my voltages when i did mine and ive done it like a year and a half ago. Everything is perfectly fine.
I just want to know if the wires that need to be tapped are the same colour or not. The car is a 04 but i dont think that makes a difference.
RotaryMachineRx 06-09-2011, 07:51 AM Canadians Read Here: http://www.rx8club.com/showthread.php?t=90749
Our Wire colors are not the same.... I believe ours is black/white rather than brown or something like that
Go Canucks
Rotary-RX8 06-09-2011, 08:38 AM So basically you connect the black/white wire (brown on US cars) to the red/black wire.
The black/white is the wire that gets cut correct?
RotaryMachineRx 06-09-2011, 08:57 AM Scroll up and look at my posts from before... with pictures
I still havent gotten around to changing the wires in the DRL module yet though haha.... the turbo kit had priority
Rotary-RX8 06-09-2011, 09:27 AM I did. I went to the link you posted but its completely diferent compared to how mazdamaniac did it. I did it the way mazdamaniac posted lol.
Isnt there a way to do it the way i did it but just use the different wires i said ?? Will it work ?
RotaryMachineRx 06-09-2011, 09:31 AM no clue man I did the black/white wire way I showed and I havent even touched the DRL module so technically I havent even done this mod. But all I know is the way I did it should turn the fogs on with the parking lights and I believe once I mess with the DRL's they will no longer be on as soon as the car is started.
Rotary-RX8 06-09-2011, 09:38 AM haha alright no worries brother.
acherry370 11-13-2011, 11:53 PM omicron's way was very east too 2 minutes max probablly gonna toy around with it tho idk why but i feel bad cuttin up wires hah
Globetrahter 12-14-2011, 12:10 AM Ok, so I did this mod tonight, I did mess up and it probably took way longer than it should. But After I cut the brown wire, I taped off the wire closest to the relay and then started using the other half of the brown wire to the (first) the black/red wire and my fogs would not turn on. 2nd I used the wire and connected it to the white/red wire and still no fog lights.
I then untaped the brown wire closest to the relay. Since I made a mistake and made the wire to short, I had to come up with a different way to make it work, so I cut the ACC relay (thin white/red wire and connected it to my brown wire and voila it worked, now my fogs turn on intedependently of the headlights and the parking lights which is awesome.
OK Now! I also was installing my HID Fogs from VVME. I got all the way to hooking up the Ballast and they are the 35w Kit. When I turn on my Fogs I hear a sound like its getting power but no lights come on. I plug back in my original fog light bulbs and they work fine. Could this be because I have the Fog Wire connected to the ACC relay and its too much power? If so How can I fix that?
:dunno:
GK1707 01-29-2012, 07:18 PM Did this today with the quick splice connector and it works great so far. But i plan on putting HIDs in the fogs soon. Will the HIDs work with the rewire mod?
RotaryMachineRx 01-30-2012, 11:10 AM ^Yes, all your modding is when power is supplied to the fogs
kennewbike 02-17-2012, 10:33 PM I am hoping someone can help me with this mod. I am new to this site, and have read everything I can about it. My car is a 2004 and is a Canadian version. I have the daytime running lights on mine.
Under my fuse box relay, the wire is NOT brown. It is also NOT the brown with white stripe that is mentioned on here by another Canadian member (I think because the wire color changed again in 2006). Can anyone help me do this mod? I have also un-plugged my daytime running light relay that is behind the glovebox, but have not cut any wires on it yet.
Any help would be greatly appreciated.
