Oil pressure gauge range
Old May 21, 2007 | 02:47 PM
Georgia8er's Avatar
Any of you that have installed an aftermarket oil pressure gauge, what range did you use and or what range do you normally see?
Old May 21, 2007 | 03:18 PM
jskup1's Avatar
The Chief
15-20 idle, 60 cruising, 70 WOT
Old May 21, 2007 | 10:20 PM
olddragger's Avatar
depends on your oil viscosity.
olddragger
Old May 21, 2007 | 11:08 PM
chickenwafer's Avatar
Nope
18 or so at idle, 55-60 on the highway, 70 WOT. My oil press also drops with the A/C on
Old May 22, 2007 | 10:13 AM
Raptor75's Avatar
Plus the lighter the oil the more efficiently it ferries heat from the engine to the coolers.
Speaking of oil viscosities; since I am rebuilding my engine I had a chance to check all of my oil clearances. After finding what I did I am leaning HEAVILY, no pun intended, on staying with 5-20 or 5-30 oil. The specs call for clearances in the range of .0022"-.0029" for the e-shaft bearings and .0024"-.0030" for the rotor bearings. Those are pretty tight specs and my mains range from .0021-.0028 with my rotors ranging from .0021-.0025. I also used 5-20 99% of the time and even with 49K miles I have no bearing wear or scuffing and all of the other wear parts are still at 90%. Remember, I have hammered this car pretty good over the past three years with most of the abuse coming in the first year. The last two I babied it a bit too much.
RevMeHarder
Jun 1, 2026 02:30 PM
RX8mzda
Oct 14, 2015 05:12 PM
Slack
Sep 5, 2015 06:42 PM
Cookingislife1226
Sep 5, 2015 03:38 PM
