JABell
05-17-2007, 04:56 PM
I have removed the cat from my rx8, After 20 miles the ECU engine warning light has come on. which has restricted the power of my rx8. I was informed it may come back on, due to having the cat removed. Is there anyway i can permantly fix this problem, without reseting the ECU every time. would a super chip fix my problem!!! please help
Many thanks Jimmy.
maxxdamigz
05-17-2007, 05:10 PM
The stock ECU checks for the cat performance. You have none so the car thinks the cat is performing poorly. Maybe it is estricting performance to try and improve emmissions.........but I don't know that. You need a proper 02 sensor voltage signature to the ecu to tell your car that the cat is performing fine. You'll need a dummy O2 sensor unit or aftermarket engine management.
There are a lot of people on here with midpipes and I'm not sure if they all have issues with the ECU holding back performance.
Brettus
05-17-2007, 05:11 PM
suggest do a search here . This has been discussed many times
BTW - did they put the stock 02 sensor back in ?
Rootski
05-17-2007, 06:27 PM
This thread is too intense for just one exclamation point.
MazdaManiac
05-17-2007, 06:43 PM
Why do we continue to allow newbie unrestricted posting with zero post count?
At Thanksgiving, don't then normally seat the children at a separate table?
haha......sorry lol :icon_no2:
nycgps
05-19-2007, 11:49 PM
*sigh*
in short no. you removed a piece of emission control device. you expect the ECU to *let you go* ?
Put your CAT back on, stop destroying our planet.
This earth is where I store all my stuff !
And next time, do a search you FREAKING MORON !
StealthTL
05-20-2007, 12:59 AM
Removing the cat would not, by itself , restrict the performance of a US car (Your mileage may vary - you are in Lancs, the UK spec car MAY be programmed to go to 'limp-mode' when the cat is off.)
No chip or 'fooler' will trick the ECU into happiness, you WILL have to replace the cat.
S
PerformRX-8
05-20-2007, 04:11 PM
I have the B&B midpipe, with the o2 sensor, so my 8 hasn't had any problems.....but hope you get it fixed, whatever you do, don't ask or bring it into the dealer!
