View Full Version : What wheel dimensions to avoid tire rolling?
rb67
05-17-2007, 05:48 AM
Let me first say that I'm a newbie when it comes to aftermarket auto parts. This is the first care that I liked enough to want to improve it.
I'm considering getting new 18" wheels on a stock 2004 rx8. I've read around that some members needed to do some fender rolling to avoid rubbing. What type of tire dimensions should I look for in order to avoid having to roll the fenders?
Width? (7.5, 8, 8.5"....)
Offset? (38, 40, 45mm ... ) <--- This I don't really understand much.
I hope this isn't too silly of a question.
steve
Imidazole
05-17-2007, 06:18 AM
I think tire Rolling and Rubbing are two different things.
8is>enuff
05-17-2007, 09:39 AM
For starters - http://www.1010tires.com/tech.asp
You can get up to 9.5 without any rubbing if the offsets are correct. Check the Enkei RPF1 thread for the correct offset.
BigRed
05-17-2007, 11:29 AM
^^correct. from what i heard, tires are supposed to roll:)
TownDrunk
05-17-2007, 11:40 AM
You can go a bit wider than that even (well in the rear). I have 18x10 +50 in the rear, no rubbing, therefore no rolling required.
rb67
05-17-2007, 12:39 PM
oops, I meant fender rolling and tire rubbing.
Thanks for all the great info.
8is>enuff
05-17-2007, 02:38 PM
I meant non-staggered, but you are correct (obviously, as you have them on your car).
TownDrunk
05-17-2007, 02:46 PM
Werd :biggthump
