Removing Brake Rotors
Old May 10, 2007 | 03:08 PM
dmorales's Avatar
Spin Triangles! Spin!
There a couple of screws in the center of the rotor, which I assume I have to take off. My question is, how did you all get them off w/o stripping them. They boogers are in there tight! I tried a little last night, but I started to round it out. I quit trying. Any advice before I do any real damage.
btw I'm just replacing the front, because of a warped rotor.
Thanks for the help.
________
CALIFORNIA MEDICAL MARIJUANA DISPENSARIES
Old May 10, 2007 | 03:14 PM
expo1's Avatar
He's as bad as Can
Impact Screw Driver or drill them out. If you drill them they are not needed once you put the wheel back on.
Old May 10, 2007 | 03:26 PM
scsi's Avatar
i highly recommend an impact screwdriver. got one from sears for my rotor install, made life so easy, well worth the money
Old May 10, 2007 | 03:33 PM
Nemesis8's Avatar
Bigus Rotus
Did anybody say impact screwdriver yet?
Old May 10, 2007 | 04:40 PM
dmorales's Avatar
I get the feeling I will probably need...an..impact screwdriver? lol ok thanks. I'll give it a try.
________
Kemekohot cam
Old May 10, 2007 | 05:21 PM
Go48's Avatar
Get one of these.
Old May 10, 2007 | 09:49 PM
jeffe19007's Avatar
You need a impact screwdriver. Find some one who actually worked on their motorcycle. They should have one.
They might even give it to you!
That and a hammer.
Old May 10, 2007 | 10:35 PM
Napboy's Avatar
Sho'Nuff
I 32nd the impact driver. I had to buy one from Sears when I stripped 3 of the 4 screws trying to get them off. I had to buy new ones from the dealer (which are gold-plated and pretty expensive for tiny screws). I added a bit of lube when putting them back on.
Old May 14, 2007 | 08:10 AM
dmorales's Avatar
I worked on this Friday. Worked like a charm. It was tough getting the old one off. Lot's of rust. But some wd 40, and a rubber mallet, and we were all good.
Braking is smooth, and normal!
But I'm still getting this noise as if it isn't Just started noticing it Saturday night. I might jack the car up tongiht or tommorow, and see if I can't figure out witch wheel is dragging. I am guessing a warped one in the back. But we'll see I guess.
Thanks for the help on this one though.
________
Katerine
Old Jul 3, 2014 | 09:49 AM
black PL 8's Avatar
even my plates are tinted
What the heck are they made of? I thought it was that steel/aluminum welding phenomenon. Useless screws, you will die this weekend.
Old Apr 26, 2016 | 05:10 PM
RotaryMachineRx's Avatar
SPOOLN8
Reviving this from the dead.... but there is no reason a hammer drill wouldn't work instead of an impact screw driver correct?
Old Apr 26, 2016 | 05:24 PM
Hard to say, sometimes they come right off with a normal screw driver. Hell I have had them fall out when you remove the wheel,
Old Apr 26, 2016 | 05:30 PM
BigCajun's Avatar
A little heat from a little propane torch works wonders also.
I like to put them back on to hold the rotor steady while putting the calipers back on.
Old Apr 26, 2016 | 05:37 PM
Yeah I reuse them as well with a little loctite. Also an impact hammer is like $15.00 at HF. But he is in Canada so I'm not sure if they are as cheap up there.
Old Apr 26, 2016 | 07:17 PM
Steve Dallas's Avatar
Water Foul
Our brake parts are made by Sumitomo, and some parts are very common in the wild, as they are shared by many other cars. I bought a set of safety screws at O'Reilly that were marked for Ford Focus that fit for about $4.
I also use an impact driver with a #3 impact rated bit to remove mine. But, rather than Loctite, I use anti-seize!
Old Apr 27, 2016 | 08:50 AM
SPOOLN8
Well I guess I'll give the hammer drill a shot, if all else fails I run over to home depot and look for an impact screwdriver..... technically a hammer drill and impact screw driver do the same thing so I can't imagine it not working, other than my rotors are the originals from 2004, but my car has never seen winter so. Got some EBC slotted rotors and some green stuff brake pads going on this weekend; along with my Koni Yellows and new Sarx WG actuator.
Old Apr 27, 2016 | 09:11 AM
Water Foul
The hammer drill should work. Just make sure your bits and adapters are all impact rated, and use a #3 Phillips bit.
ÜberJumper
Canada Forum
21
Feb 20, 2025 11:57 AM
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
airlive
Sep 7, 2015 08:32 PM
