oil pressure gauge
Old May 4, 2007 | 04:08 PM
delhi's Avatar
Grand Chancellor
oil pressure gauge
I did a search and to my shock that it seems that the pressure gauge doesn't work?! Is that true?
My question is at what level is considered normal pressure? The needle is around 2/3rd towards H a week ago but now hovers slightly over half.
Old May 4, 2007 | 05:22 PM
Raptor75's Avatar
The gauge is a dummy the equivalent of a idiot light.
While we are at it the temperature gauge is not much better. It has a large dead spot in the center. The temperature has to be really out of the norm for it to move after warm up.
The oil pressure will always hover a little over half way while the temp will always hover just under half. Both are are almost useless except for a major problem.
This is such b$llsh#t to put into a sports car.
Old May 4, 2007 | 09:07 PM
jskup1's Avatar
The Chief
The oil pressure shouldn't stay in a constant position. My oil pressure goes from about 17-20 psi at idle to 70-75 psi WOT.
Old May 4, 2007 | 09:35 PM
two rotors's Avatar
That may well be,but you don't see that on the factory needle in the car.There is no oil pressure transducer on the RX-8,merely a pressure SWITCH.
Old May 4, 2007 | 10:36 PM
delhi's Avatar
Grand Chancellor
so what does it do then? If I top up the oil will it show H? And when it's low will it show L? Hmm...
Old May 4, 2007 | 10:43 PM
j9fd3s's Avatar
the "gauge" is for pressue not level
Old May 4, 2007 | 10:45 PM
Its pretty much like an on/off switch, since its just a switch, not a regulator. It will not be able to tell you how much pressure it has.
Solution : Install a REAL gauge
RevMeHarder
Jun 1, 2026 02:30 PM
WranglerFan
May 31, 2022 07:51 AM
RXFEVER
Sep 11, 2016 02:51 PM
RX8mzda
Oct 14, 2015 05:12 PM
