willrotary
04-29-2007, 08:34 PM
Hi I have a 1000 watts mono class D amp i want to connect it just for bass, i did already the Aux input welded inside the head unit(works nice with my MP3 player). ill leave the factory system intact for mid and highs, but i want to know wich cables are the Mute outputs from the radio to the factory ampso i can get the inputs to the new amp. I have already the rest done, please any help on this one can any one tell me the color of the cables on the trunk, i know its the plug with many wires..., Thanks
RxJaye
05-01-2007, 10:26 PM
You can use a high to low convertor and splice into the rear speaker wires after the amp (if Bose). Thats what i did, I have 2 10s that sound great with the bose system.
willrotary
05-02-2007, 10:39 AM
Thanks man, i was thinking to do that but, does it sound good?? i remember back in the days i did it with a honda accord and sounded noisy, well ill try anyway thanks a lot.
RxJaye
05-02-2007, 08:23 PM
Mine sounds great, First time ive used a factory head unit in a system, but Im impressed.
imrtommy
05-04-2007, 02:25 PM
What you say works but is only part true. Sound depends on amp. And converter should be pretty good. I used a weak amp and cheap converter and after I turned ignition off it made a continuos bumping. I switched to a better converter and it stopped the problem, but when I upgraded to a jl 1000.1 amp it had that problem again. I had to buy audio line outputs from pac-audio.com to fix the problem. Well I didn't have to but it sounded way better than what it was which I thought was pretty damn good already. =)
RxJaye
05-14-2007, 05:32 PM
Do you know the part number from pac-audio?
