HID -> halogen?!?!?!?!?!
Old Apr 25, 2007 | 04:27 PM
james_bobby72's Avatar
If I found problem with the ballast and I don't have that much to spend recently, can I downgrade to halogen for a while?!?!?!?
What are the procedures?!?!?!
Unplug the ballast and connect that to a halogen bulb?!
Thanks again!
Old Apr 26, 2007 | 12:30 AM
Cam's Avatar
Cam
this space for rent
Why did you start another thread? It would be better if you kept the same problem in one thread.
But I dont think you can "downgrade" to halogen. Your HID is now working due to a wiring problem. You could swap, but the headlight would still not work.
And it would not be a straight swap. If 25 kV ran through a halogen headlight there would be big problems.
Old Apr 26, 2007 | 07:28 AM
VOODOO8's Avatar
Hermitage Holdout
...and what ever happened to Ricky Bobby??? Will he run Talledega again this year?
Old Apr 27, 2007 | 12:42 PM
Nubo's Avatar
Lubricious
One thing to keep in mind is that due to the efficiency of HID, the typical automotive HID only draws 35 watts or so. Halogen mains are usually 55 watts. So it is possible that the circuit and wiring may not be designed to handle the additional power needed for halogens. Or, it's equally plausible that the same basic wiring harness was used in both situations. But you'd need to verify.
Retrofitting with halogens would seem to be a fairly big project on its own. You can't just fit a halogen bulb into the HID housing. The optics and means of focusing are different. You'd need to replace the housings, etc., with the halogen-specific parts.
Old Apr 27, 2007 | 01:52 PM
StealthTL's Avatar
Metatron
Cool Diy....
Do It Yourself....or pay someone who can.
Don't mess with it, you can seriously kill yourself, and besides, if you cut wires to rig a halogen bulb in there, the eventual fix will be even more costly.
If you can't afford to fix a vital part like a headlight, you should be driving a "beater".
S
Old Jul 30, 2024 | 09:35 AM
My_daily-rx8's Avatar
that’s not good man. What kind of problems would I get if previous owner decided to rig up both?
james_bobby72
Sep 11, 2012 10:11 PM
q-tip
Jul 27, 2009 08:58 AM
Elak
11
Nov 30, 2005 04:42 PM
williamngRX8
Sep 25, 2005 03:29 PM
SiCkRx-8
21
Sep 28, 2004 12:56 PM
