RP Short shifter experiment
Old Apr 22, 2007 | 10:05 PM
dontfeedthenerd's Avatar
Not banned
Hey, so I just got the awesome SS from Richard. He was nice enough to install it for me.
I get this strange buzz in my SS in 1st and 2nd gear. It's almost like a whirling sound.
I'm also using a Voodoo Shift ****, so that may be the issue, but I also have the green fuzz cone out.
So i thought I'd try out an experiment to try to help out the community and myself.
I'm ordering some materials now but I thought I'd outline the plan.
I'll be comparing sounds made by my new SS in a couple different situations:
(Everything with stock **** and voodoo ****)
Without Green Triangle:
With Packing foam under my shift ****
With teflon tape around SS threads
With stock Green cone:
With Packing foam under my shift **** (varying thicknesses from .5-4 inches)
With teflon tape wrapped around SS threads
With trimmed Green cone:
With Packing foam under my shift **** (varying thicknesses)
I'm going to try to get some sort of sound metering device to get the noise levels.
All that being said, does anyone have a stock green cone they'd be willing to donate?
Old Apr 23, 2007 | 01:20 AM
Richard Paul's Avatar
I told you if that happened put the stock **** back on.
Plus it will be the right height, your vodoo is countersunk and lowers the ****.
But if yoy get a decibel meter then it might all be interesting.
Old Apr 23, 2007 | 01:31 AM
Not banned
Oh I'm not complaining (too much)
I just thought it'd be neat to try to figure out a way around it and maybe dampen it a little.
I could always go back to stock **** I suppose.
Old Apr 23, 2007 | 02:01 AM
Phantom Menace's Avatar
II SOCIETY
Yo nerd...click here: https://www.rx8club.com/series-i-aftermarket-performance-modifications-23/short-shifter-noise-real-solution-107310/
BTW, you go to Cal?
Old Apr 23, 2007 | 02:13 AM
Not banned
Originally Posted by Phantom Menace
Yo nerd...click here: https://www.rx8club.com/showthread.php?t=107310
BTW, you go to Cal?
Yea I go to cal. I was going to try to "borrow" a decibel meter from a lab.
I saw your fix, the thing is I really don't want to dremel the basket, I just need to dampen the noise in 1st and 2nd gear.
Old Apr 23, 2007 | 10:05 AM
DarkBrew's Avatar
Extraordinary Engineering
I have the AFE SS and Voodoo ****. I don't get any weird sounds but I have a suspicion why. I you look at the attached photo you'll see that I've installed a Redline leather boot. The Redline boot didn't come with the plastic ring at the top of the boot; It had four leather tabs. I forced the four tabs up into the countersink of the Voodoo **** and tightened it down effectively using the leather to dampen any vibrations...
Old Apr 23, 2007 | 07:59 PM
II SOCIETY
Bro, you don't need to dremel it. I found later on, that mine was just abnoormally thin. PM Richard Paul.
--Go Bears!
Old Apr 25, 2007 | 10:32 AM
Rhythmic's Avatar
Laid back in the pocket
My Voodoo **** was not a good fit with the AFE SS. Same problems your describing, whirling, etc. I put the stock **** back on, 100% better. I think being countersunk it changed the dynamics or the leverage point and actually was worse than the stock ****. Now I've got a quite SS and great shift action. Try this and report back.
theblinkof
Oct 4, 2023 05:24 PM
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
Evan Gray
Nov 24, 2015 01:00 AM
Michael Bryant
Oct 12, 2015 03:07 PM
JCTaylor
Sep 30, 2015 07:31 PM
