staticlag
04-21-2007, 03:16 PM
Is it okay to use anti-seize with sparkplugs?
Or, is the metallic goodness going to work its way into my engine?
View Full Version : Spark Plugs and Anti-Seize staticlag 04-21-2007, 03:16 PM Is it okay to use anti-seize with sparkplugs? Or, is the metallic goodness going to work its way into my engine? Wilson 04-21-2007, 03:19 PM Always use an anti-seize compound on your plugs. It doesn't take a whole lot. Just enough to coat the threads. Wipe off any excess before insertion. Cam 04-21-2007, 03:53 PM I was told by a Master tech not to use anti seize on NGK plugs. Easy_E1 04-21-2007, 04:04 PM iI was working on Mazdas before that master tech was born and I say use anti-seize. Nothing like getting a sparkplug stuck in a rotor housing. dannobre 04-21-2007, 04:23 PM Use it...it won't hurt anything......you don't need to goop it on though. A little bit goes a long way. Doesn't hurt to put it on a lot of other bolts that you remove either...makes life simpler down the road Mazurfer 04-21-2007, 05:24 PM Use it...it won't hurt anything......you don't need to goop it on though. A little bit goes a long way. Doesn't hurt to put it on a lot of other bolts that you remove either...makes life simpler down the road +1 TeamRX8 04-21-2007, 06:04 PM always have, always will nycgps 04-21-2007, 07:59 PM I did for both my car and my father s mini van. the tech who did my plugs 13 ~ k miles ago didnt apply shit, and it was really a bitch for me to try to get it off .... I was actually afraid that I might break something then my engine will fuck .... lucky nothing happen. Nubo 04-23-2007, 06:32 PM Is it okay to use anti-seize with sparkplugs? Or, is the metallic goodness going to work its way into my engine? Highly recommended. The only problem would be if you gooped on so much that it got onto the center insulator. Use a small amount; about the size of a small pea, and work it into the sparkplug threads. I usually leave the last couple of threads dry at the end of the plug to make sure I'm keeping the stuff clear of the business end. I learned my lesson on my Miata when I got a plug stuck in the #1 cylinder. I accumulated about 50,000 miles while thinking about what I wanted to do about it. In the end I sold the car :yelrotflm Anti-seize from now on. (I did warn the buyer though.) The other useful salve for sparkplugs is dialectric grease. Apply between the outside insulator and the ignition wire boot. Helps seal against moisture and aids in removal. |
