AxialFlow Shifter, note to users
Old Apr 19, 2007 | 05:38 PM
Richard Paul's Avatar
We just had an interesting report from a user and need to pass it on.
One of our users had the Delrin pivot basket "melt" on him.
After reserching this we found his switching to Lucus oil in the transmission was the cause. Delrin doesn't melt until 347 degrees F and is happy to work at 200f all day. So the whole thing sounded wierd.
Turns out it was a chemical reaction. SO DON"T USE LUCUS OIL IN YOUR TRANSMISSION.
We do not intend to change to a different material because of this. We are happy with the Delrin it has served well in every other respect.
Old Apr 19, 2007 | 05:55 PM
DarkBrew's Avatar
Extraordinary Engineering
Thanks Richard.
Old Apr 19, 2007 | 06:02 PM
thanks RP
Old Apr 19, 2007 | 06:30 PM
staticlag's Avatar
The Professor
thanks!
Old Apr 19, 2007 | 06:36 PM
Nemesis8's Avatar
Bigus Rotus
Running Redline in mine - no probs to date.
Old Apr 19, 2007 | 06:42 PM
Moostafa29's Avatar
Storm Trooper
I'm a little unfamiliar with transmisions, but would a melted pivot basket cause someone to have an extremely hard time trying to shift into gear?
Old Apr 19, 2007 | 06:47 PM
Nopstnz's Avatar
thanks for the heads up.
Old Apr 19, 2007 | 06:50 PM
Just keep drinking that stuff, it'll all come to you someday when you wake up on the floor.
Old Apr 19, 2007 | 07:18 PM
devildog1679's Avatar
Richard,
Sent you a PM.
Old Apr 19, 2007 | 07:46 PM
SmokeyTheBalrog's Avatar
Thread Pirate, Ahhrrrrr
The funny thing is, I was absolutely sure RG posted that. Only when I was about to close the thread did the corner of my eye notice your avatar at the bottom of the thread. Took my three tries to spot your post cause I kept skipping over it sure that it was RG.
Old Apr 19, 2007 | 08:03 PM
Xantium's Avatar
Unregistered User
I had that happen to my axial flow shifter but I was using OE tranny fluid. Also, i wouldn't really call it melting, it looked like it cracked and seperated. I called them and he said that about 8 or so bad shifters went out. After it broke I put my OE shifter back in and about a week or so later the transmission literally blew up shifting into 2nd at 3krpm but the person I talked to assured me that the delrin falling into there couldn't cause a tranny to fail like that. Axial flow did send me the replacement shifter after I sent them my broken one in only a few days.
Old Apr 19, 2007 | 08:58 PM
8rotor8's Avatar
Back in the day...
Good to know. Is the stuff in Lucas in any other tranny fluids?
Old Apr 19, 2007 | 10:03 PM
elf's Avatar
elf
What pointy ears?
Thanx for alerting us, Richard.
Old Apr 19, 2007 | 10:11 PM
kartweb's Avatar
Lucas oil? Ever seen those little clear cranky things Lucas puts in the parts stores to show how their oil sticks to the gears? Try turning the crank. Lots of drag.
We did some dyno testing on our shifter karts using various oils. Mobil 1, Castrol Syntech did the best. 80/90 Gear oil cost almost 1 HP. Lucas cost almost 3 HP.
Old Apr 19, 2007 | 11:59 PM
I would never even consider Lucas based on my past english car experiences which I try my best to forget ...
Old Apr 20, 2007 | 02:01 PM
Don't worry about it, anything anyone drinks RG has already tried it.
So I can see why you thought that.
Old Apr 20, 2007 | 07:02 PM
deadphoenix52's Avatar
meh.
the white ring on my came loose, i dont know if thats related, its not melted, it just slides up. nothing big.
Old Apr 22, 2007 | 01:29 PM
Put a couple of drops of superglue on it. The only thing it does is take up the space between the shaft and the boot.
theblinkof
Oct 4, 2023 05:24 PM
Jst4fun
Apr 17, 2021 07:43 AM
He||hammer
Sep 29, 2015 09:40 PM
