Gearshift moving all over the place with the engine throw...
Old Apr 19, 2007 | 06:32 AM
Rx8ing's Avatar
Hi guys i'm new here and was wondering if someone can help me out. I recently bought my Rx8 and since i've had it it's always done this.. is it normal?
While driving around, when changing gears, the whole gearshift area seems to move with the engine movement. If the engine is thrown back, while holding the gearshift, i can really feel the engine movement through the gearshift. If for example i brake hard, and wedge my hand between the gearshift and the front dash, i can feel the gearshift pushing on my hand while braking... isn't it meant to be 100% totally still? Also when i take hard left and right turns, i feel the gearshift fighting to stay still and instead is forced slightly to the opposite direction to the turn. Basically it feels like there's a transmission mount about to go but that's how it's felt since day 1.
When i complained to my dealership they said that all rotary engines do this but then i came across an article on-line (which i cant seem to find anymore) and someone who's driven a lot of Rx8s was told the same thing by the dealer but unlike me since he knew better he was able to put them right.
If anyone knows anything please help me out since car is still on warantee and dont want to pay for any oem factory damage
Thanx
p.s. a 'better' description would be "i've got a belly dancin gearshift!!!"
Old Apr 19, 2007 | 07:31 AM
DarkBrew's Avatar
Extraordinary Engineering
The engine and transmission sit on isolation mounts and will move around relative to the car interior. The only issue that can cause excessive vibration and movement is a bad motor mount. So some questions.
What year is your car?
Did you buy it new?
How is your idle?
Old Apr 19, 2007 | 08:57 AM
Rx8ing's Avatar
I bought it new and its 2005 modle. The gearshift vibrates at idle.
Old Apr 19, 2007 | 09:06 AM
DarkBrew's Avatar
So far it sounds very normal.
When I was installing my AFE short shifter I had to remove all of the plastic covers and rubber seals in the centre console. At that point what you see is the transmission with the pavement below. The shifter literally bolts into the top of the transmission so you don't get the isolation typical in other cars, especially FWD cars. Don't worry, be happy.
Old Apr 19, 2007 | 09:39 AM
Rx8ing's Avatar
phew... that's reassuring. Just to be on the safe side, i'll try to take a short video of it and double check.
Thanx
Old Apr 19, 2007 | 10:24 AM
Rx8ing's Avatar
out of curiosity, what are the symptoms of a worn motor mount? while moving and at idle?
Old Apr 19, 2007 | 04:18 PM
Rx8ing's Avatar
Originally Posted by abbid
If you put it in gear and slam the gas, does the shifter move UP at all? or just forward or backward[depending on which gear]
It only moves forwards and backwards, not up (towards the roof). I'm guessing that means it's normal, right?
Old Apr 19, 2007 | 04:19 PM
mysql101's Avatar
normal
Old Apr 19, 2007 | 04:21 PM
Rx8ing's Avatar
When driving the car hard on second gear (while it's in its sweet spot), when i let go of the gas the engine movement is nuts! it jerks the car forwards and back. Is this how the normal mounts react? should I mention it to my dealer or is it a matter of upgrading the mounts to aftermarket ones?
Old Apr 19, 2007 | 10:46 PM
Its normal, unless its shaking so badly that it starting to look like a snake.
Old Apr 20, 2007 | 05:45 AM
Rx8ing's Avatar
Thanx. My friend's got a modified 4wd VW with engine mounts, bushes, ARBs coils... and basically all bells and whistles that go into tightening up a car's handling. He drove my car and told me if i upgrade my engine mounts i'd enjoy driving the car much more cause id comfortable be able to hold it in a certain rpm band in gear on turns without having to make up or even think about the engine throw.
Anyone done this upgrade? is it really worth it? and where can i get good engine mounts (sorry still a novice with my car as far as tuning parts)?
Old Apr 23, 2007 | 07:28 AM
Rx8ing's Avatar
Old Apr 24, 2007 | 05:53 PM
shaunv74's Avatar
Power!!
There is a TSB on worn motor mounts. If you're still in warranty bring it in and ask them to check out your mounts. Second thought it to make sure your Power Plant Frame is on properly and tightened. It connects the back of the transmission to the differential.
Again if you're in warranty bring it to the dealer with the TSB for the motor mounts and see what they say.
You can search on it and find them on this forum.
Old Apr 24, 2007 | 06:29 PM
mine doesn't do that, and I have one of the highest output NA engines here ...
and FWIW, the entire drivetrain is suspended on the chassis by only the two motor mounts at the front and two differential mounts at the rear. There are no trans mounts on an RX-8. The trans bolts to the motor and is then bolted to the differential via the PPF (power plant frame) to form one rigid assembly.
Old Apr 25, 2007 | 03:05 AM
Rx8ing's Avatar
Thanx buddy, I'll do a search on them.
Old Apr 25, 2007 | 03:07 AM
Rx8ing's Avatar
I think i do have a problem with a mount somewhere. Car on warantee so i'll be going to mazda soon. Would anyone happen to have a good pic of how the RX8 is put together?
Old Apr 25, 2007 | 03:42 AM
Rx8ing's Avatar
http://www.finishlineperformance.com...ins_index.html
Interesting
Old Apr 25, 2007 | 01:17 PM
shaunv74's Avatar
Power!!
^^Yup. There's a sticky with a link to that site to get all our TSBs. It's a good read. I would take a look at all of them and see if you car does any of those things. Then bring it in with a stack of TSBs and get them all fixed...under warranty.
Old Apr 25, 2007 | 01:18 PM
shaunv74's Avatar
Power!!
Yeah that's what made me think maybe the PPF might not be bolted on properly...
Jesus Martinez
44
May 6, 2025 08:09 AM
vapor2
Nov 3, 2020 03:38 PM
jay_tibo
22
Sep 13, 2016 08:10 PM
WingleBeast
22
May 23, 2016 09:22 PM
thedragonrotar
Jul 22, 2015 08:46 PM
