Ultra High Performance VS Max Performance Summer Tires
Old Apr 18, 2007 | 09:06 AM
smaterblah's Avatar
RX-8 Newbie
Hi all,
I hate to sound like a noob (but I am, so I guess it's ok), but does anyone know what the differences are between Ultra High and Max Performance summer tires are? Which is better etc.
I would imagine Max, but maybe it's the other way around.
Old Apr 18, 2007 | 09:12 AM
Skythe's Avatar
Lascivious Post Whore
What brand and tire specs are you looking at??
Tire model line A & and line B from Manufactuer X, can have a great variance in performance qualities (i.e. softness/stickiness, road noise, wear, tread depth, speed rating)
More information would be helpful
Old Apr 18, 2007 | 09:18 AM
smaterblah's Avatar
RX-8 Newbie
Something along the lines of the S03 VS Kumho ECSTA SPT, or Yokohama AVS ES100... currently running with Dunlop SP Sport 8090 w/ 4/32 left, so i'll be needing new tires soon.
thanks!
Old Apr 18, 2007 | 09:29 AM
DarkBrew's Avatar
Extraordinary Engineering
I just went through this process and ended up with RE050A pole position
Explaination from tirerack.com
http://www.tirerack.com/tires/types/tiretype.jsp
Tire ratings
http://www.tirerack.com/tires/survey...ireSearch=true
Old Apr 18, 2007 | 09:34 AM
smaterblah's Avatar
RX-8 Newbie
Wow. That was awesome! Thanks for the info!
Old Apr 18, 2007 | 07:27 PM
RX26b's Avatar
Looking at the links DarkBrew posted I'd have to strongly disagree with some of the classifications. The Kumho 712 being in the same category as the Bridgestone RE010 (standard on NSX and ITRs)? No way! Sumitomo HTRZ in the same UHP category as the Yoko A022 (which was specifically designed for each corner of the '91 NSX)? Again, not a chance.
I would ignore the customers' responses in the surveys and, for the most part, the charts in the links, and just look at the individual tire tests (i.e. Yoko ES100 vs Kumho SPT vs. whoever) that they ran on their own track. That's more of a barometer than just lumping previous mentioned tires with Firestone SZ50 (discontinued, but was the sister tire to the Potenza S-02; which was top notch dry weather grip rubber) for example.
Old Apr 18, 2007 | 07:56 PM
DarkBrew's Avatar
+1
Be careful out there!
You really can't go wrong with any of the top 4 in the chart.
Old Apr 19, 2007 | 12:33 PM
Nemesis8's Avatar
Bigus Rotus
Doesn't that chart only show tires sold by Tire Rack?
Old Apr 19, 2007 | 01:26 PM
SouthFL's Avatar
Max>UHP
Old Apr 19, 2007 | 06:27 PM
Paul_in_DC's Avatar
Rotary Public
Customer comments can have an important bearing on your decision, depending on what's important to you. If there's a tire that grips like mad, but many people say it sounds like a banshee in heat after 5,000 miles, that may affect your decision.
Old Apr 19, 2007 | 07:29 PM
Nopstnz's Avatar
max-more grip in warmer dry weather/probably faster wear, worse in rain. ultra high-less grip than max in warm, dry weather/ better wear, better in rain. at least thats my guess.
go with yokohama avs es 100. great tires!
bulletproof21
Oct 20, 2015 08:53 PM
dweezil22
NE For Sale/Wanted
12
Sep 9, 2015 10:50 AM
Kim Jong Illest
Canada Forum
Jul 23, 2015 03:22 PM
