squeaking sound when braking
Old Apr 14, 2007 | 01:14 PM
thane's Avatar
hey bros, just encountered a problem and wanted the expertise of you guys, recently i changed my rims from 16' to a 18', and when that happened my brakes started to squeak really loudly. so i thought it was the pads, went to get it changed, and the noise went off, but 2 days later im still hearing it. is there a problem with the rotors or something?
Old Apr 14, 2007 | 02:40 PM
gfoo's Avatar
normal
Old Apr 14, 2007 | 03:04 PM
blackjack's Avatar
Kei-Office
depands wat type of brake pads u using, some performance brake pads is very noisy some dont, importantly is your current braking still good.
Old Apr 14, 2007 | 04:43 PM
hellangel's Avatar
aiya.. its normal... i used to have that sound till i change to 4pot... so change ur brakes... the whole kit...
Old Apr 14, 2007 | 09:15 PM
toxin440's Avatar
if you are REALLY worried about it get some brake cleaner and give everything a good shot. If you want to go crazy with it, take your wheel off - take your pads out and give them a little treatment with an SOS pad to smooth them out and clean all the **** off them. Worked for me.
Old Apr 14, 2007 | 10:01 PM
makimaki's Avatar
Do you get it only when the rotors are cold as in usually after you stop your ride for a long time...............I get that usually after a car wash or after parking my ride overnight........
Am running on 19" and if your situation is according to above-mentioned, it is absolutely normal mate........ Like wat the other bro mentioned, as long as your brakes works perfect that is most important......
Cheers
Old Apr 15, 2007 | 12:43 AM
Swerve76's Avatar
Had the same issue myself. MM gave my brakes a full service and the squeak was gone. Might wanna try the same?
Old Apr 17, 2007 | 04:10 PM
Rumboo's Avatar
Lurker
Some people find that this works:
http://www.zeckhausen.com/bedding_in_brakes.htm
Old Apr 17, 2007 | 11:00 PM
lennon's Avatar
Perhaps it's becos you're brake disc is taking more braking power...... MT has bigger brake than AT, than's why your brake squeek.......
Old Apr 18, 2007 | 01:47 AM
lawreo's Avatar
*** Lover
when i changed my stock rims from 4AT to the 6MT MM ones, i starts having the squeaking sounds too. until now still not solved, sian.
Road Cone
Nov 6, 2015 01:52 PM
Danield97
Oct 10, 2015 05:58 PM
TheRedRotor
Sep 22, 2015 05:30 AM
TheRedRotor
Sep 12, 2015 07:42 AM
