Sticking brakes
Old Apr 10, 2007 | 03:52 PM
Delaware8's Avatar
Unhappy Sticking brakes
Installed my Racing Brake 2 piece rotors over the weekend without a hitch. Today I installed a set of Porterfield pads that I used a few times last year in preparation for this weekend at Summit. Right side - no problem. Left side won't budge after everything is tightened down. Any ideas? Need them quick or I'll have to choose between new rotors + stock pads or Porterfield pads + old rotors.
Old Apr 10, 2007 | 05:32 PM
SouthFL's Avatar
If you can't resolve the issue in time, put the old rotors back on (if they're still within proper thickness) and use the Porterfield pads. Are they R4 pads?
Pad compound > two piece rotor for safe tracking.
Old Apr 10, 2007 | 08:06 PM
What is binding?? Is the rotor hitting the caliper...or the spindle? Or are the pads binding to the rotor??
Old Apr 10, 2007 | 08:24 PM
Delaware8's Avatar
Pads are binding to rotor. Can't turn wheel after installing pads. Rotor turns freely with stock pads.
Old Apr 10, 2007 | 08:29 PM
Did you retract the caliper piston?..Is it stuck?? If the rotors are the same thickness..( check) and the pads are the same ( worked before) then the caliper or the hat must be the variable.....
There are different sized rotor rings that fit on the 2 pc hat....if you have the wrong one on the left side it could bind. Also there are different hats. RB may have mixed up on the order??
so...check the ring thickness...hat offset, and rotor diameter......
Old Apr 11, 2007 | 04:52 AM
SouthFL's Avatar
Indeed. Check all thicknesses and diameters and compare to stock. I know that DBA 4000 and 5000 rotors run thicker than OEM, so perhaps RB rotors do also.
Are you reseating the pistons correctly as dannobre points out? Make sure to get that piston all the way back in.
Old Apr 11, 2007 | 01:45 PM
Delaware8's Avatar
Talking
Mystery solved!!!! After some (O.K. alot of) choice words, lots of measuring and taking apart and putting back together, I found the problem. It seems that there is supposed to be a couple of special washers on the caliper mounting bracket that were missing from the factory. I remember them being on the other side because they kept falling off the caliper. Since this was the first time these brackets were taken off, they just weren't put on at the factory. The new rotors are a little thicker and the washer made the difference. Went to Mazda dealer and they don't sell the washers separately - have to buy bracket for $200 to get washers. Went to local brake shop and bought some washers for $.04 and VOILA I'm in business. Thanks for all the suggestions though. Now if only it didn't rain this weekend at Summit everything would be good.
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
Digitz0070
Oct 7, 2015 12:43 PM
Oct 3, 2015 09:51 AM
D13
Oct 1, 2015 07:55 AM
