what am I doing wrong with my MP3 install??
Old Mar 24, 2007 | 01:59 PM
dillsrotary's Avatar
jersey fresh
ok, the whole deal is hooked up. MP3 adapter installed in the back of the radio, rca adapter from mazdaparts connected to the adapter, firmware is 9.55, mp3 player connected and pressed play, nothing. I press and hold cd and nothing, says no disc. I reset the pcm, disconnected the battery, did the brake reset, held the odometer reset, still nothing. Am i missing something really really simple????
Old Mar 24, 2007 | 02:00 PM
DarkBrew's Avatar
Extraordinary Engineering
Does your display on the HU say EX?
Old Mar 24, 2007 | 02:01 PM
WikkedOne's Avatar
Deals on wheels
if it anything like the AUXmod the radio has to be on the "Tape" input.
Old Mar 24, 2007 | 02:02 PM
jersey fresh
i have the Pie maz/pc alp aux input converter and the pie alp/m-rca
Old Mar 24, 2007 | 02:03 PM
jersey fresh
disp does not say EX
Old Mar 24, 2007 | 02:05 PM
DarkBrew's Avatar
So which port did you plug into?
If you plugged into the CD changer port then you need to press the CD button to toggle the display to EX
Old Mar 24, 2007 | 02:10 PM
jersey fresh
darkbrew i think you just jogged my memory, if it works i owe you a beer, i'll update shortly
DarkBrew's Avatar
Old Mar 24, 2007 | 02:43 PM
jersey fresh
the culprit was a bend input connecter, from what i could see it was the ground wire too, bent it back to where it should be, plugged everything back and know its working just fine, thanks everyone for the memory jog.
Old Mar 24, 2007 | 03:01 PM
DarkBrew's Avatar
You pulled out your HU, fixed the cable and put it back in in 30 min.?
Or was this some other cable?
JimmyBlack
273
Feb 10, 2020 10:23 PM
yurcivicsux
192
Sep 12, 2017 10:54 PM
LMURailsplitter02
Sep 6, 2015 10:56 PM
