Anybody change JUST a pulley on a 4AT?
Old Mar 23, 2007 | 01:49 AM
mdw1000's Avatar
I'll snap his neck.
Just wondering what difference people notice with the pulley change on a 4AT. I seem to find posts about pulleys on MTs, but I haven't found one where the person had a 4AT and only changed to underdrive pulleys. By only changed I mean didn't do other mods at the same time.
Old Apr 5, 2007 | 03:58 AM
Need2Speed's Avatar
i've ordered a set of Trust Aluminium Pulleys (Water Pump/Alternator/Idler) for my JDM 4AT. Will let you know how it drives when installed.......
Old Apr 5, 2007 | 11:28 AM
mdw1000's Avatar
I'll snap his neck.
Thanks! It would be good to get some feedback on this. I think it would be very helpful for a lot of AT owners.
Old Apr 5, 2007 | 05:47 PM
tajabaho1's Avatar
Destroying Threads
I wanted to get one too......but tell me this......do they ruin your warranty?
Old Apr 6, 2007 | 08:15 PM
theboy's Avatar
RX8 newbie!
pulley kit is great for Automatic. i am using greddy one. it doesn't harm your car, but the aircond fan noice will be more noticable when driving.
Old Apr 6, 2007 | 08:30 PM
R888's Avatar
WedsSport Member
Pulley will shorten engine life!
Use inter-X!! gained 20whp with 1600USD!
Buy Racing beat intake and exhaust +10HP!
Change header +5HP!
Buy High flow cat +5HP!
Thats total of 45mixed WHP!
Stock dyno 145-150 whp for automatic! add those together = 180-190WHP!
I can see this close to 200WHP!
Any more mods? lets give some more .......
Old Apr 6, 2007 | 08:33 PM
Easy_E1's Avatar
How is the pulley going to "shorten your engine life"?
Old Apr 7, 2007 | 12:13 AM
tajabaho1's Avatar
Destroying Threads
by pulling the engine.......thats why its called a pulley
Old Apr 7, 2007 | 12:54 AM
N rider89's Avatar
^NieL
Change header +5HP!
that seems much too high
and for that much cost you could put most of it towards a SC
Old Apr 7, 2007 | 01:16 AM
Brettus's Avatar
Boosted Kiwi
Change header +5HP!
please show me one person that has got more than 25hp total from all mods to an auto 8 (dyno proven) .
Until then I call BS !
Old Apr 30, 2007 | 12:07 AM
Endgame's Avatar
Sorry if I missed this in my searches, but can someone comment specifically of the effects (positive or negative) of the Agencey Pulley on either a 4AT or 6AT??
Old Apr 30, 2007 | 12:17 AM
very minimal..
Old Apr 30, 2007 | 08:32 AM
Endgame's Avatar
Originally Posted by swoope
very minimal..
Even in engine response?? I am not looking for 5-9 HP or anything like that, just quicker revving and better engine response. Your thoughts?
Endgame's Avatar
Also, it seems that the AC is not affected TOO MUCH with this pulley, but just looking for experiences from AT users as I asked a MT member...
Old Apr 30, 2007 | 02:06 PM
Endgame's Avatar
nevermind
Old Apr 30, 2007 | 09:04 PM
RX82's Avatar
Change header +5HP!
How do you know it will shorten engine life? Has someone installed a pulley and drove there 8 untill it stopped working? If it does shorten engine life by how much?
Old May 3, 2007 | 03:54 PM
DoubleS69's Avatar
I haven't owned an 8 for long but I did some research and learned that the Agency Pulley is widely suggested as it is also pretty cheap. It hardly increases your horsepower (maybe 1-2 HP, although I believe they claim 5) but what it does do is increase your acceleration through first gear.
Our cars are pretty quick on the top end, but I know that I've personally never been happy with the immediate off-the-line jump. I definitely think its worth the money.
I'm in the process of ordering one. Once it gets here, I'll report back.
Old May 3, 2007 | 03:59 PM
therm8's Avatar
Bummed, but bring on OU!
That's common talk for piston engines. Rotaries don't have the balancing issues that their piston counterparts have. If a pulley does shorten your engine life, it'll be negligable, imo.
Old May 3, 2007 | 05:55 PM
Endgame's Avatar
Thanks Double S69! Can't wait for your results!!!
Old May 3, 2007 | 08:53 PM
RX82's Avatar
how hard is it to replace a pulley?
Old May 12, 2007 | 12:12 PM
mdw1000's Avatar
I'll snap his neck.
Anybody that installed one recently have some results/impressions?
Old May 14, 2007 | 04:25 AM
DMRH's Avatar
Guys, have any of you considered swaping over to a JDM ECU. The JDM 4AT version gets 154kw if memory serves me. the export versions got 141kw.
Very simple to simply plug in & play
I know I will on my 4AT.
As for pulleys changing the life of you engine.........Well, I wont even grace that stupidity with a reply.
However, if the gearing on your alternator is changed via a smaller diameter pulley, it may wear out quicker than usual. Just something to think about
REgards
Old May 14, 2007 | 11:49 AM
mdw1000's Avatar
I'll snap his neck.
Let us know how the JDM ECU works out, and the cost. If it is not too high of a cost, might be a good mod. Although it might make warranty service a pain...
Old May 14, 2007 | 04:51 PM
therm8's Avatar
The CAN bus makes oem ecu swaps virtually impossible, as far as I know. I don't know if it can be reprogrammed to accept the new bus or vice versa.
Old May 16, 2007 | 02:42 AM
DMRH's Avatar
I will investigate this further.
Even if the CAN bus prevents it. It still would be possible, just knowing "how" will be the issue.
REgards
