Chirping Noise
Old Mar 19, 2007 | 07:07 PM
nbymissy's Avatar
Unhappy Chirping Noise
My newest problem with my RX-8 is a chirping noise that it is making. I've only had the car for 4 months and its been at the dealership more than I've actually had it, I think (7 times).
It seems to start making this noise around 1500 RPM and it only chirps at lower speeds. After driving a while, the chirping turns into more of a knocking noise. If I stop, the car bounces around and feels like it is about to die. I also noticed it being underpowered (more than usual) when trying to merge onto the highway yesterday. Here is a video with the chirping noise. Any guesses?
Chirping
Old Mar 19, 2007 | 07:20 PM
otherside's Avatar
I dont care...
I see from the wheels it is an automatic correct? What year is the car? How many miles on it? It really doesnt sound good. Possible engine failure.
Old Mar 19, 2007 | 07:28 PM
nbymissy's Avatar
Its a 2004 Automatic with 32,000 miles on it. The video is actually pretty mild to compared to what you really hear when inside or beside the car.
Old Mar 23, 2007 | 09:40 AM
nbymissy's Avatar
Took the car in today. Their answer was that I am not red lining it enough so we'll see.
Old Mar 23, 2007 | 09:44 AM
peterlemonjello's Avatar
You using premium gas?
Old Mar 23, 2007 | 10:40 AM
nbymissy's Avatar
Always.
Old Mar 23, 2007 | 09:29 PM
Do a search.. Someone just had the same issue and it was the alernator belt.
Another chirp comes from the intake. Do a search.
Old Mar 25, 2007 | 05:32 AM
matis's Avatar
Do you have any CEL while car is doing that sound, and does the car vibrate?
Sounds like one of the spark plugs does not work correctly, but if it so, then your car should vibrate....
Old Mar 25, 2007 | 07:50 AM
mysql101's Avatar
I used to get that exact same sound in the mornings driving to work before the car was warmed up. It happened around 2k rpm. No ill effects came from it.
I don't get it anymore though - I think it went away when I replaced my coils.
Old May 22, 2007 | 06:24 PM
nbymissy's Avatar
Update on my car and it's pretty little chirping noise - I'm getting a new engine.
The chirping/knocking noise started getting louder in the past couple of weeks and I had it die twice at redlights (people are NOT nice when that happens, btw). I took it in last week and it actually cut off in their parking lot behind the line of the new 8s The salesman had to push me to the service dept. They called the next morning to let me know that they had talked to Mazda and a new engine would be on its way.
They put me in a rental for the week - 07 Mazda 3 - I really miss my car.
They said "new" engine. Does that really mean new or are they going to give me a remanufactured one that will die again in 3000 miles?
Missy
Old May 22, 2007 | 06:37 PM
Old Rotor's Avatar
It more then likely will be a Re-Man engine. Please give us all the history on your car, Oil&change intervals, gas, Flooding, TSB's, type of driving, easy or aggresive, comuter, when did you first notice this, symtoms. Anything you can think of.
Old May 22, 2007 | 06:48 PM
nbymissy's Avatar
Well, like I said - I have only had the car for 6 months (04 automatic). From the service records, the previous owner had all of the recalls done and timely oil changes (they dealt with the same dealer that I use). They had a problem with the radio and one listing that just says "engine work". I don't know anything about their driving patterns.
I've driven the car around 4000 miles since I've had it. 2 oil changes, never flooded it. I've had the heater, the throttle body (CEL came on), and the engine mounts replaced.
I'm not really an aggressive driver on the car - my boyfriend is a little worse. I try to redline it at least once a day. Most of the time I only drive it back and forth to work (less than a mile from my house).
The car has seemed sketchy since I first bought it. It will lose power, vibrate, and randomly cut off. Other times - it runs perfectly. I think the dealer was beginning to think I was crazy until they actually experienced it cutting off in their parking lot.
Missy
Old May 22, 2007 | 06:52 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Missy
Damn.......sorry about that kiddo. Hopefully the "new?" engine will do you right.
Dave
Old May 22, 2007 | 07:16 PM
shaunv74's Avatar
Power!!
When you get your new engine be sure to specifically ask if they replaced the ignition coils and visually looked inside the catalytic converter to see if it was plugged. It seems like this is a common coincidence that these items go bad at the same time.
Old May 22, 2007 | 07:29 PM
MazdaManiac's Avatar
Wow. I just listened to that MOV and that motor sounded like crap!
Old May 22, 2007 | 08:17 PM
nbymissy's Avatar
Thanks for the tip! I will do that.
nbymissy's Avatar
And that's been 2 months ago! It has gotten worse.
Old May 24, 2007 | 12:45 AM
Old Rotor's Avatar
It is extremly hard on a car that does very short drives like yours. Go with the shorter interval for your service needs. It will have more carbon build up and moisture in the engine.
Old Jun 12, 2007 | 09:39 AM
timbervolt's Avatar
Melbourne, Oztralia
Wow, does the engine even warm up to operating temp in less than a mile's journey to work?
I get the same sounds but at idle. My engine mounts have just been replaced but the chriping persists.
Old Jul 4, 2007 | 06:25 PM
nbymissy's Avatar
Grrr....900 miles on the new engine and the "check engine" light comes on today. No weird noises or anything, but who knows what this is about.
Mane
Nov 20, 2015 12:16 PM
nowakm99
Oct 9, 2015 07:10 AM
tommy26Germany
Sep 29, 2015 10:33 AM
Jb4ker96
Sep 27, 2015 10:06 PM
neoksk
Sep 21, 2015 12:31 PM
