Should I get an alignment with a new set of tires?
Old Mar 19, 2007 | 06:31 AM
staticlag's Avatar
The Professor
I just got RT615s in 245/40-18 on the stock 18s. Should I get an alignment?
Old Mar 19, 2007 | 09:30 AM
Jax_RX8's Avatar
Got Another Rotary
Tires will not change an alignment.
If your old tires were wearing evenly, then you should be fine. If not, then I would get an alignment.
Old Mar 19, 2007 | 01:48 PM
Cam's Avatar
Cam
this space for rent
Jax is correct. No alignment needed since the rolling radius is basically the same.
Old Mar 19, 2007 | 07:23 PM
You just spent $800-900 on a set of tires......if you haven't had an alignment in the last year....get one......It doesn't take much to chew through a set of new tires if the alignment is out...
Old Mar 19, 2007 | 07:31 PM
nofxp506's Avatar
[]D [] []\/[] []D
I dont know how much it helps, but im probably getting an alignment with my new tires. Im getting them once i can decide on a set. geez.
Old Mar 19, 2007 | 07:55 PM
DarkBrew's Avatar
Extraordinary Engineering
Get an alignment once a year.
gwailo
May 14, 2024 06:57 AM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
fireishot34
Sep 5, 2015 06:45 PM
20b-3rotor
Sep 2, 2015 08:54 AM
