Electrical advice.
Old Mar 16, 2007 | 06:15 PM
funspork's Avatar
Electrical advice.
When I plug in a solar battery charger, the RX8 turns on the ignition. It must detect a positive charge and turns on the power.
Does anyone know how to disable this?
thanks
Old Mar 16, 2007 | 06:19 PM
StealthTL's Avatar
Metatron
Cool New to me....
I didn't know that....
Are you using the console cig lighter socket?
S
Old Mar 16, 2007 | 06:22 PM
AdRoCK3217's Avatar
Rotary Superstar
Most solar panel's I've seen/used hook up just like a battery charger, right to the posts.
Old Mar 16, 2007 | 06:35 PM
j67345's Avatar
That could be a problem if you're not ready for it, and the car is in gear when you plug it in!
Old Mar 16, 2007 | 06:45 PM
StealthTL's Avatar
Metatron
Cool Backfeed.....
I checked the wiring diagrams, the socket is normally isolated from the rest of the vehicle by the Accessory relay - when you put power into it you are just "backfeeding" all the accessories, the radio, display and trunk opener.
S
Old Mar 16, 2007 | 08:15 PM
funspork's Avatar
S
Yes, but they turn on, and are using much more power than the solar panel is putting out. ( thru the cig lighters ) Direct to the car battery I didn't try, but that would be inconvenient.
Old Mar 16, 2007 | 08:53 PM
Georgia8er's Avatar
Same thing happens when you use some inverters. Residual in the capacitors make my radio run for about 30 seconds after I turn the key off.
yurcivicsux
192
Sep 12, 2017 10:54 PM
Evan Gray
Nov 24, 2015 01:00 AM
zoom44
General Automotive
10
Sep 29, 2015 09:56 PM
1.3_LittersOfFurry
Sep 22, 2015 01:54 AM
yapakanichi
Sep 17, 2015 04:23 AM
