View Full Version : HELP: exhaust fumes in cabin
WarmFreedom
03-16-2007, 09:55 AM
i have a very distinctive smell of exhaust fumes in my cabin everytime after hard driving.
for normar driving , it wont happen.
I start to have this problem after i upgraded to MS Flywheel. at the same time i also changed gear oil to red line.
ive checked for the following;
-no leaks in gear oil
-no leaks in engie oil
-no exhaust leaks from the mid pipe or anywhere
-got out to sniffed around under the car, in the engine bay, in the a/c vents, still cant find the source of odour, but its definately in the cabin
this begining to really piss me off...
cant find the cause, except it definately started after i changed to MS flywheel, and only when i drive hard.....where? where? where?
*i always drive with the windows up
Transam kid 01
03-16-2007, 10:24 AM
are you sure its exhaust and not another gas smell. I just had my clutch replaced and it smells like gas coming from my vents, but its not an exhaust smell.
Im not sure what it is :(
StealthTL
03-16-2007, 10:30 AM
Check the rubber boot around the shifter is back in place - they would have to move it to do a clutch.
Check your trunk is shut.
S
WarmFreedom
03-16-2007, 10:44 AM
cant be sure its exhaust... its possible it is another smell (it acutally resembles, kitchen gas smell)
either way, it wasnt there before the flywheel swap, and it only comes round if i took the car for hard drive...
:sad:
*btw, before the time i upgrade f/w I dida midpipe swap and that did not cause any problems..
WarmFreedom
03-16-2007, 10:45 AM
S
trunk is shut. even took a sniff in the trunk... no such smell
Transam kid 01
03-16-2007, 11:02 AM
:sad:
yeah thats what mine smells like. They comin from your vents as well?
WarmFreedom
03-16-2007, 11:08 AM
thats the problem i donno where its commin from...
u talking about a/c vents? nope.. i sniffed it..
i also removed the gear knob and sniffed tru the shifter cloth, (the funnle shaped thingy), no smell comming from there either
04RX8man
03-16-2007, 11:34 AM
I had that smell right after I got mine and ran it hard like the first 3 times. I was worried it smelled like the oil stuff the dealers spray on the engines to make them shiny was getttin hot and burning off. after the 3rd time I don't get the smell any more. How often have you got this? Try running it hard again and see if its' still as strong or if its still even there as it was b4. Good luck
WarmFreedom
03-16-2007, 11:49 AM
my car has been running for 23,000 kms without smell issues, it was when i had my f/w replaced. then the smell came (whenever hard driving is done)
rotten42
03-16-2007, 12:05 PM
ever since my second engine change I get the smell of gear oil when the car is warmed up.
acc3d
03-16-2007, 01:16 PM
I have the EXACT same problem...right after my engine was replaced it started occurring. Funky smell coming throught the vents. Does the car have a cabin air filter? Maybe the dealership forgot to put it back in after the engine swap. In any case, the smell is pretty bad, and I really don't want to take it back to the dealer. I hope we can come up with a fix...
New engine seems to be running strong though.
Also, I get a violent rattle when launching from a stop very gently (when the RPMs are around 1000-1500).
Razz1
03-16-2007, 09:37 PM
Get your motor mount fixed.
rotten42
03-16-2007, 09:38 PM
I just had the cabin filter replaced and it makes no diffrerence.
WarmFreedom
03-16-2007, 11:41 PM
then let us re trace the common steps taken between the two process, replacing flywheel/clutch and engine
WarmFreedom
03-16-2007, 11:42 PM
u mean the smell only comes when u drive hard?
btw why did u change the engine?
Winfree
03-17-2007, 03:03 AM
This is not normal or at least my car hasn't done it yet -
If you can borrow or buy a cheap CO2 tester it will tell you if it is really exhaust getting into the cabin - if so you have a leak in your system and this means you need to check connections
If no CO2 it's not exhaust but something getting warm and off gasing - make sure fuel line is competent.
Put down a big sheet or two of butcher paper and park on it overnight - look for oil and gas spots -
Change filters that are behind the glove box - pinch the sides and glove box can pull out - two flat filters are behind it
Clean engine
Look under car make sure nothing is stuck to the cat - like a plastic bag
Vacumn the area at base of wipers - stuff can slide in and off gas especially when hot.
Please post if you figure it out
