Official Will It Fit Thread
Old Mar 13, 2007 | 04:26 PM
dmc27's Avatar
doin' the bull dance
So I've looked through all the "will this work", "what offset", etc., ect. threads, as well as stickies and I still have some Q's. Maybe by naming the thread as I did anyone (noobish like me) with future Q's on wheel size/offset/etc. (general "will it fit") will just continue on here rather than starting another thread . . . or maybe I'm too idealistic.
So if you have a "will this size work" type of question - please feel compelled to add it here, rather than start a new thread.
*yes - I realize the irony of writing that & starting a new thread*
But that is the only way to title the thread accordingly.
So my Q is this: Most of the wheels I like are "tuner" wheels. Thus, 18 inch rims are likely only available in 7 or 7.5 inch widths. If I go w/a 18x7.5 I can just use the stock Potenza's (225/45/18) on that size wheel, correct? I plan on getting Tein S springs to drop it a bit (1.4 front & 0.7 rear) - will this cause any issues with fitment of above setup?
thanks all.
[zips_up_flamesuit]
Old Mar 13, 2007 | 04:53 PM
Dinhx8's Avatar
My Rex goes to 11!
i just bought a sweater, but it was XL and i'm usually M. But its from a different store.
will it fit?
Old Mar 13, 2007 | 05:06 PM
Aero8's Avatar
Originally Posted by dmc27
[zips_up_flamesuit]
does it fit?
sorry, I have so many comments/thoughts. I had to say at least one.
snipaz2420's Avatar
the bukkake master!
would someone be able to explain what offset means please? search only brings up people asking if their offset will fit. be gentle
Old Mar 13, 2007 | 05:29 PM
"Shanika"'s Avatar
#382
...waiting to see flames.
Old Mar 13, 2007 | 05:41 PM
snipaz2420's Avatar
the bukkake master!
im surprised it hasnt happened yet
Old Mar 13, 2007 | 05:54 PM
NotAPreppie's Avatar
What am I doing here?
Will 255/40/18 Falken Azenis RT-615 fit on the OEM 18x8 wheel?
Old Mar 13, 2007 | 05:59 PM
I don't see why it won't fit.
I fit 225/50/17 Falken ZE-512's on a 17x7 rim for my winter wheel/tire combo (albeit on the stock suspension). As long as you aren't significantly changing the outer diameter, I can't see how it would make a difference.
Old Mar 13, 2007 | 08:34 PM
dshiznit1489's Avatar
Formerly Polak Graphics
great thread
Old Mar 13, 2007 | 08:42 PM
N rider89's Avatar
^NieL
axis hiros
fronts
offset: 45
pcd:5/114.3
centerbore:73.1
offset:45
pcd:5/114.3
centerbore:73.1
what size tires do i need so that i dont rub with the stock setup?
Old Mar 13, 2007 | 10:22 PM
most of the info is here..
it explains a lot...
http://1010tires.com/tech.asp
Old Mar 13, 2007 | 10:33 PM
N rider89's Avatar
^NieL
^ thanks that really help to explain things
Old Mar 14, 2007 | 09:15 AM
dmc27's Avatar
Surpisingly gentle . . . so far.
In order to keep the first post at a reasonable size I tried to keep it simple. Swoope - I've gone through that site (and others) and this is how I understand it:
The stock tires will fit the 18x7.5 w/o any problem, and will actually protect the wheel lip better than the 18x8 b/c the protective rubber piece on the sidewall will snug up to the lip better instead of being 'pushed up' off the lip like the stock set up is.
Mostly, I'm just looking for confirmation of what I think I understand. And I prefer that confirmation here rather than worry about a salesman's answer being slightly biased towards getting more $$ out of me.
thx
Old Mar 14, 2007 | 09:34 AM
dmc27's Avatar
will it fit?
It will, but it'll prlly look really silly.
Originally Posted by Aero8
does it fit?
Yes, the flamesuit fits. But, frankly, it's getting sweaty in here and there's just not much in the way of flames on the outside.
I figured when I checked in today it'd be 50/50 at best. Not sure if I should take it as a compliment or an insult that I'm not in the fetal position crying right now.
Old Mar 14, 2007 | 10:26 AM
BigOLundh's Avatar
#1 Legend
THANK YOU SO MUCH...
for strating this thread. If someone as wise as you came along 3 years ago with this thread... this sub forum wouldnt be so cluttered, and i wouldnt be getting so many PMs.
Anyway.....
thanks all.
[zips_up_flamesuit]
1 - The stock tire will fit on your 7.5" rim just fine.
2 - The rim should fit with that drop... as long as you get the proper offset rim.
will it fit?
Probably not. If its slightly baggy... i would suggest trying some pushups and work your way up to the large size.
It'll fit, but might not be worth the extra money that a 245 tire will give you. At 255 your on the verge of too much tire and not anymore contact patch. You should still be fine... but i would suggest sticking to a 245
-hS
Old Mar 14, 2007 | 10:38 AM
dmc27's Avatar
Anyway.....
-hS
Trying to help w/the clutter. There's always gonna be someone like me who lacks the necessary experience & knowledge. Thanks for the direct answer.
The offset I was given was 35-40. My grasp of the info I found tells me that is fine, correct?
I really wanted to go 18x9, but that size just isn't readily available for most of the wheels I like. I'd have to go to 19s to get a width of 9. While I'd like 19s, I don't like the idea of not being able to get road hazard coverage (TireRack, DiscountTireDirect, etc. don't offer it on 19s )
Old Mar 14, 2007 | 11:29 AM
Tanaka826's Avatar
i know just tires does road hazard coverage for 19s
Old Mar 14, 2007 | 11:53 AM
dmc27's Avatar
Looking into to it - tkx Tanaka!
Old Mar 14, 2007 | 12:29 PM
MazdaManiac's Avatar
I'm 5'10" and about 160 lbs.
She is 5' and around 100 lbs.
Will it fit?
The sweater, I mean.
Old Mar 14, 2007 | 12:36 PM
dmc27's Avatar
Well, yes. But why the hell would you want her to put clothes on??
Old Mar 15, 2007 | 01:53 AM
the offset and tire calculator cover it all... it is not like you are going 285 on a 2 inch drop are you...
as i have said before the car and wheel well do not do what size rims you have, worry about the tire diamater and offset...
Old Mar 15, 2007 | 02:07 AM
Brettus's Avatar
Boosted Kiwi
I hear viagra makes it bigger
will it still fit ?
Old Mar 15, 2007 | 08:47 AM
dmc27's Avatar
Make it fit. She doesn't really need teeth anyway.
Old Mar 15, 2007 | 09:42 AM
BigOLundh's Avatar
#1 Legend
thats odd. discount tire gave me road hazard coverage on my 19s. I'm glad they did because i got a nail in the sidewall 1 month after buying the tire.
for a 18X7.5" rim.... 35-40 offset will work just fine. 30 to 35 would probably work as well.
-hS
Old Mar 15, 2007 | 10:10 AM
MrSuicideDoor's Avatar
clutch burner
will it fit?
that cracked me up
