View Full Version : Will AudioPilot work with sub?
Bulldog6670
09-16-2003, 07:20 PM
I'm happy enough with the BOSE system where I just want to add a sub for a bit more bottom end.
Question is, will added sound from a subwoofer cause the AudioPilot to compensate for what it thinks is outside noise? Has anyone tested this with their added subs?
mikeb
09-17-2003, 01:30 AM
my subs are not running off headunit so it is not affecting audiopilot
Kev
09-17-2003, 06:35 AM
The Audiopilot uses a microphone doesn't it!?!
Anyway - I just turn if off. The buttons on the steering wheel are like second nature to me after only a couple of weeks, to the point that I only use the acc pedal if I'm changing gear. I change volume because of a particular song - if I open the windows, I turn it Uu!!!
If the car was auto and there was a brake button on the steering I could sit with my legs crossed :D
Pretend there's no Audio Pilot, leave it switched off, and add all of the speakers and amps that make you happy ... life's too short.
mikeb
09-17-2003, 12:09 PM
I agree
the buttons on the sterling wheel are like my favorite feature
jtimbck2
09-17-2003, 12:29 PM
Originally posted by mikeb
I agree
I had them on my BMW 328i, but I never used them very much -- I use them ALL THE TIME on my 8 though! So much that when I drive my pickup truck, I keep trying to adjust the radio volume using the (nonexistent) steering wheel buttons :p
Sputnik
09-17-2003, 12:40 PM
my subs are not running off headunit so it is not affecting audiopilot Your subs will affect the audiopilot, and since the source of the music comes from the head unit, the audiopilot affects your subs. It's still in the loop.
---jps
Bulldog6670
09-17-2003, 10:10 PM
---jps
That's what I'm thinking from reading the blurb below on the AudioPilot.
I was wondering if anyone had installed subs with the AudioPilot and their experience with having it on.
