View Full Version : GB: KW Variant 3 Coilover Suspension
jstkilntim 02-17-2008, 12:37 PM I used the recommended specs also but found that the ride comfort was almost exactly the same when i had just stock suspension but upgraded Racing Beat Sway bars and endlinks.
I haven't adjusted the ride height since i've been out of town but the roads here in vegas are really nice so i'll probably be dropping it 1/2" more and making the bump a bit stiffer.
*Warning to those who do or dont have upgraded swaybars*
With the upgraded RB endlinks you have the mount the Front coilovers with the oil reservoirs facing towards the front of the car but this leaves only about an 1" of clearece from the top of the resvoiver and the upper A Arm which makes me nervous. Other members say that the new version of the coilovers dont the have the resevoir so this might not be a problem.
In the end i might not lower it at all and just adjust the bump enough to be sure that they wont clank into each other.
Is there any more feedback on this post. Avital, have you expereienced any problems w/ the resevoir hitting the a-arm? Does anyone know if the current version eliminated the reservoir or not.
Thanks,
jst
takahashi j 02-17-2008, 12:48 PM Is there any more feedback on this post. Avital, have you expereienced any problems w/ the resevoir hitting the a-arm? Does anyone know if the current version eliminated the reservoir or not.
Thanks,
jst
Checked mine out last week after rotating my tires. Got mine in January 08 and I have reservoirs on all four corners. They clear.
TeamRX8 02-17-2008, 01:11 PM The a-arms and lower shock bodies move together over bumps or during body roll. As long as there is clearance (1" noted) you will not have an issue
jstkilntim 02-17-2008, 06:19 PM Thanks guys. I figured as much, but it doesn't hurt to ask. I think my RB springs have given up the fight. They are so low the most I can get is -2.3 camber on both sides. I can't think of anything else to cause it. I have read how to fix the excess height, but no real answers for too low. Plus, the drivers side being lower than the passenger has been driving me crazy for years, so I guess I will pull the trigger.
jstkilntim 02-19-2008, 08:06 PM PoLaK,
Is this price still valid? If so, how long is estimated shipping now?
jstkilntim 02-24-2008, 09:40 AM You all should be kissing my ass for a long time for organizing this.
I may if you check back into the forum so I can order them!!
a-spec fd 03-05-2008, 03:40 AM I want to get in on it too!:lol2:
HiTMaNN 03-05-2008, 03:54 AM Guys he doesn't have time to check this thread but I have PMd you guys with his info. He said this GB is indefinate just give him a call and tell him your info.
Nopstnz8 03-19-2008, 12:23 AM Will this special price be still valid through the summer because I will have the money to buy these by then. I definately want to get these, but I have some other things I need to get first. I just hope this deal is still valid by then because these are the best coilovers out there in my opinion.
Has anyone found an aftermarket way to make these coilovers adjustable inside the car? Thanks.
Razz1 03-19-2008, 12:27 AM Not me, but I love mine!
HiTMaNN 03-19-2008, 12:36 AM Guys he doesn't have time to check this thread but I have PMd you guys with his info. He said this GB is indefinate just give him a call and tell him your info.
Come on Fanatic lets read a little
Nopstnz8 03-19-2008, 02:30 AM Yeah I know, but I just wanted to make sure. Who knows, the time for the GB could of changed since thread was make so lon ago. Also, it hasn't been updated for a while.
jstkilntim 03-27-2008, 12:20 PM Payment Sent!!:us4allswi :us4allswi
illsuspect 04-15-2008, 11:32 PM my tax relief cant get here fast enough ...
headofdog 04-23-2008, 09:21 AM I'd like to grab a set. Can't send a PM however, b/c PoLak's inbox is full.
jstkilntim 04-26-2008, 08:16 AM Try his e-mail. He usually gets back to me pretty quick.
PoLaK 05-07-2008, 06:10 PM Seems prices have been raised since the New Year, I found out when i called for an update on jskilntim's order; GB price has to be hiked up to $1800 shipped.
Jsklintim don't worry I took care of any difference in $ for you.
jstkilntim 05-08-2008, 04:25 PM Many thanks!! You are the man. I received them today. Now I just need a free weekend.
AvitalBlue8 05-15-2008, 02:32 AM The a-arms and lower shock bodies move together over bumps or during body roll. As long as there is clearance (1" noted) you will not have an issue
Yeah no clearance problems at all, love the suspension, although if you do live somewhere that has mediocre road it will be a hit harsh.
rx8dorifto 06-04-2008, 05:12 AM Any notes on what sort of rebound and compression to be set for street and track?
what are the benefits and differences for setting them separately?
PoLaK 07-22-2008, 12:39 AM After dialing in the suspension for a very long while; I think I've found the ideal set up for my car. Razz what are you running?
275/35 9.5'' wheel/tires and progress auto sways front bar on the middle hole rear bar on soft.
I'm using:
1.5 turns of Rebound in the front
3 turns of Rebound in the rear
1.25 turns of Compression in the front
2 turns of Compression in the rear
I think KWs recommendations are perfectly adequate for the street, and very comfortable. But if you can tolerate a bit stiffer of a ride, give these a shot. Though I would expect that without a stiffer front sway and wide rear tires I would have alot of trouble keeping the rear planted with these settings.
Nopstnz8 07-22-2008, 05:00 AM He sold his 8. :uhh:
Can anyone post KW's recomended settings please?
rickeo 11-10-2008, 03:28 PM Can anyone post KW's recomended settings please?
http://i89.photobucket.com/albums/k215/criccio102286/Untitled-8.jpg
Zelse 11-11-2008, 03:08 PM Just wondering, how would these compare to say...the coilovers from Stance? Anyone shine some light on that? Interested in getting coilovers in Feb but I want to make sure I'm getting good stuff for autocross/track.
SiLVeRE8 11-18-2008, 02:23 AM these are one of the best you can have
rx8dorifto 11-27-2008, 10:10 AM just got this KW installed.
the rear reservoirs were touching one of the bolt. Will this hurt?
another pain in the arse is, no way to adjust the rear compression from the top without taking out the coilover :(
rx8dorifto 12-02-2008, 01:59 AM Anyone has the adjustment cable with coupler installed and work with this KW V3?
Please let me know where can I get one, thanks.
DOMINION 12-20-2008, 01:05 AM ^Yea the guy that started this thread had them on his 8 and started a thread about how they work & install blah blah blah. But I dont know if he still has his 8 or even post on here anymore.
DOMINION 12-20-2008, 01:09 AM Ok so if its $1800 shipped, whats it go for new? thanks!
PoLaK 12-20-2008, 01:48 AM i lurk.
rx8dorifto 12-22-2008, 09:58 AM i lurk.
Polak, help!!!
Please share hows the coupler for Tokico adjustment cable looks like for adjusting the KW?
Highway8 03-16-2009, 03:55 PM Polak, help!!!
Anyone get an answer to this question? I have the cables but I need the coupler.
