Quick Question
Old Mar 1, 2007 | 04:34 PM
u1cracka's Avatar
Quick Question
I am looking at buy some rims and tire form this guy tonight but wanted to make sure they would fit fist.
Here is the size 18x8 rims with a +42 offset
with 225/40/18 Tire's would i have a problem running this set up.
U1cracka
Old Mar 1, 2007 | 06:32 PM
TurboEight's Avatar
Booost.
need more info....are you planning to drop the car?
42 should going too low.....lowest i would go is 45...u might get some rubbing..
Old Mar 1, 2007 | 06:39 PM
O'Renesis's Avatar
You should have no issues with that size wheel/tire and offset. Even if you lower the car you will not rub on the fender etc.
Basically you are moving the outer and inner edge of the wheel 8mm further out than stock. This will close the gap to the fender by 8mm.
Old Mar 1, 2007 | 07:27 PM
u1cracka's Avatar
No i am not planing on droping the car.
U1cracka
Old Mar 1, 2007 | 07:34 PM
u1cracka's Avatar
How about with 4 people in the car would it rub then.
U1cracka
Old Mar 1, 2007 | 09:04 PM
u1cracka's Avatar
Also anyone know if the TPMS sensors will fit on 18" Chrome Zenetti's w/ 2inch lip.
U1cracka
Old Mar 1, 2007 | 10:21 PM
llzjayarzll's Avatar
meow
the lowest is 45.
and buy a 4" instead =/
Old Mar 2, 2007 | 03:23 AM
u1cracka's Avatar
Well i test fitted the rims and they fit with no problems. so I bought them will try to post pic's up later.
Thanks all that replied.
U1cracka
Old Mar 2, 2007 | 03:37 AM
c41250n's Avatar
there is no way that it will rub!!
it will fit no problem!
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Randolph Alvarez
Sep 14, 2015 04:25 AM
RXBae
Sep 14, 2015 03:54 AM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
Rupanrx
Sep 4, 2015 06:44 AM
