Zeroshift Automated Manual Transmission
Old Feb 25, 2007 | 12:16 PM
altspace's Avatar
Eccentric Shafting
UK-based technology company Zeroshift has developed the killer app for automobiles – an ingeniously simple way of replacing synchromesh in a manual gearbox with a reliable, cheap-to-manufacture mechanism that allows completely seamless gearchanges. Whatsmore, the Zeroshift Automated Manual Transmission (AMT) changes gear faster than any other gearbox (gearchange time is, as the name suggests, zero) and provides improved acceleration, economy and emissions in any vehicle to which it is applied, be front wheel drive cars, rear wheel drive cars, four wheel drive, motorcycles or trucks.
For road vehicles, extra refinement is available by combining gear shift actuation with a clutch, and the resultant system is claimed to be more efficient than Audi/VW’s DSG and a cost effective alternative to the traditional torque converter based automatic transmission. Viewed from a performance basis, the Zeroshift has another compelling attribute – it makes the same vehicle faster – when accelerating with a normal transmission, each up-shift requires the driver to cut the torque momentarily by lifting the gas pedal and dipping the clutch. Good drivers can do this very quickly but not as quick as the Zeroshift which enables the gas pedal to remain pressed firmly against the floor, without any torque interruption. Accordingly, if it takes 30ms for each gearchange, and you have 30 gear changes per lap for 60 laps, Zeroshift offers a 54 second advantage if all other factors are equal.
http://www.zeroshift.com
Old Feb 25, 2007 | 02:02 PM
saturn's Avatar
i pwn therefore i am
Put it in a car that I can buy then we'll talk. Otherwise it's just a pipe dream.
Old Feb 25, 2007 | 02:08 PM
therm8's Avatar
Bummed, but bring on OU!
^I agree. But it is a pretty cool concept. 'Bout time someone upgraded ye olde synchro-mesh.
Old Feb 25, 2007 | 02:09 PM
NotAPreppie's Avatar
What am I doing here?
I thought I read something about that in Sport Compact Car magazine a year or two ago.
Old Feb 27, 2007 | 12:28 PM
MikeW's Avatar
Zeroshift still hasn't figured out how to handle the torque impulse when changing gears.
When you upshift the engine speed has to drop, so that large impulse is enough to brake traction on a street car, then traction/ESP has to intervene, so you are slower than a regular stick.
The VW DSG doesn't shift gears, it transitions between gears. The quoted time is the time when the engine is cut, but that doesn't necessarily mean there is any time when there is zero power applied.
Zeroshift would best be suited to motorcycles, preferably 8 speeds. Most top end sport bikes have a back torque limiting clutch, that would help with downshifts. Motorcycles with chain/belt drive can have a cush drive sprocket, that would help with shifting (and also the straight cut gears)
Shankapotamus3
Mar 14, 2021 03:53 PM
airlive
Jun 28, 2020 07:46 AM
JCTaylor
Sep 30, 2015 07:31 PM
Stubbs
Sep 27, 2015 04:06 PM
