Anybody runs MSR?
Old Feb 24, 2007 | 07:25 AM
TX91MX5's Avatar
Anybody runs MSR?
Think about going to a RX-8 for the next track.
Anybody runs theirs at MSR Cresson?
Old Feb 24, 2007 | 08:53 AM
kartweb's Avatar
That sounds like fun. I've turned a few laps there before in mine but not pushing it hard, mostly in the 1:40's.
I've turned laps in the Formula Mazda there in the 1:20's and my best laps were in the 125 shifter at 1:17.
At the end of the front straight coming up the hill stay wide to the left and brake late to set up for rattlesnake. The last left hander is pretty tight so you'll want to set up for that from the end of the straight. Little bend leads up a hill and it takes a late apex to carry the most speed. If you have less then half a tank of fuel the pump will starve through little bend. The exit to the back straight is very crucial for speed, but the "speed" line takes all the fun out of that turn. You'll see what I mean. Big bend has a bump that will upset the inside tires and give a little pucker factor as you begin to get it right.
As long as you're going to spend the big bucks on a track day I would recommend dropping by Motorsports Sales in Richardson and getting a tankful of TT105, and carry another 10-15 gallons to the track. You'll burn 6 gallons just getting to the track. Between the oxygenation and the higher energy content it will feel like it's had about 2-3 lbs of boost added, and there will be zero detonation on the extended WOT.
Old Feb 24, 2007 | 10:21 AM
RevURGT3's Avatar
I go there quite regularly and have ran it in different configurations, very very fun track. I usually run with the Driver's Edge. Excellent organization and safe group to run with... next event is March 31st.
http://www.thedriversedge.net/02_tracks.htm
Old Feb 24, 2007 | 10:48 PM
TX91MX5's Avatar
What type of lap times are you seeing with the RX-8?
Old Feb 24, 2007 | 11:01 PM
I almost bought a condo there ...
Old Feb 25, 2007 | 09:50 AM
TX91MX5's Avatar
OK...
I am a member there and know the courses very, very well, both backward and forward. Even instruct there.
I know what lap times Shannon MacMasters is running. Shannon is telling me he is running faster then a Miata Spec., more alone the lines of a fast JP car.
So what lap times are other folks running in their RX-8's?
I am trying to figure if the car is worth getting to track with.
RevMeHarder
Jun 1, 2026 02:30 PM
JimmyBlack
273
Feb 10, 2020 10:23 PM
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
yapakanichi
20
Sep 10, 2015 07:17 AM
