Stalling
Stalling ALL the time now!!!!
I have an AT which keeps stalling on me when I'm at idle. New spark plugs, new coil packs, had the battery and alternator tested.... I just recently started getting a misfire on cylinder 1 CEL. Help please. I stalled 4 times within an hour.
What mods have you made to the car? What year car? How do you know you're getting a misfire? Is it a random occurance?
Probably time to head to a dealer for diagnosis. I hope you have a competent service department at a dealer near you. Make sure they check the engine compression and show you the results.
Originally Posted by precisi0n84
...I just recently started getting a misfire on cylinder 1CEL. Help please. I stalled 4 times within an hour.
^hmmm. he's using a generic scanner p0301 is cylinder 1(front rotor) p0302 is cylinder 2 (rear rotor) P0300 is a random/multiple cylinder misfire
PrecisiOn84, Do you have a flashing CEL that goes away or a solid one?
Did you reset your eccentric shaft position memory?
http://www.finishlineperformance.com...30-05-1544.pdf
Brooklynite
NE For Sale/Wanted
Nov 10, 2015 06:42 PM
