Help !Coils wont get power! Checked Coils ALL coils ok...confused..!!
Old Feb 20, 2007 | 01:59 AM
snkpkp's Avatar
my car is at the shop now ...and we DONT have a MAZDA dealer in Bangladesh. can you guys help me out here.... two of the rear ignition coils are not getting power...switched the coils with the first two and they work so the port of the coils are not working. Any idea why? Anyone? pls help checked vehicle with scanalyzer and no CEL or DTC ...really confused....
Old Feb 20, 2007 | 12:05 PM
Check your wires see if anything melt. also check your fuse see if anything popped.
Old Feb 20, 2007 | 12:13 PM
make sure you don't have any small burn marks on the middle of the coils. Even the part (cant think of the name of it) that the coil connects to
Old Feb 20, 2007 | 01:31 PM
Mazda-Rati's Avatar
the WANKEL made me do it
His coils are fine. He put the 2 rear coils up to the front with the known good connector and they worked fine (I did read that right?, I hope). The problem seems to be with the the pcm not suppling the connector with the ?12v? it needs to fire the coil
Old Feb 20, 2007 | 06:06 PM
snkpkp's Avatar
Exactly. why does not the PCM give any DTC ? Could it be that the PCM is broken ?
Old Feb 20, 2007 | 06:33 PM
Mazda-Rati's Avatar
Since there is no code I would check the wiring from the PCM to the coil harness. Seems like you PCM is bad. Are you getting voltage to the connector?
Old Feb 20, 2007 | 08:18 PM
Thats exactly what I've told him, check the wires. The PCM we got has **** loads of self-check (a bit too much imo) there is almost NO WAY that it will not throw a CEL for something like this .... unless its really on its last leg...
So just check the wire first.
Old Feb 21, 2007 | 06:06 AM
Mazda-Rati's Avatar
sorry nycgps, I thought you meant spark plug wires.....It all makes sense to me now
Old Feb 21, 2007 | 07:02 AM
VOODOO8's Avatar
Hermitage Holdout
Seems to me that I remember a thread running around here a while back on intermittent issues with coil packs due to poor grounding as well. Could be something tied to the mounting points for the rears that is causing the issue no matter which coil packs are used there. I've also read here that the new coil packs that came out in the USA a while back were designed to improve grounding. Other guys have posted some DIY info about taking the coil grounding right to the battery itself.
Old Feb 22, 2007 | 09:12 PM
this is for US spec, yours likely is similar in concept
you either have a wiring/connector/ground issue or there's a remote chance that your PCM partially fried
uZu
Dec 30, 2015 12:35 PM
RXeckless
Aug 16, 2015 12:51 PM
CMRine04
Jul 29, 2015 02:07 PM
