emu not communicating
Old Feb 19, 2007 | 04:22 PM
Motr T's Avatar
I cant get my E-manage Ultimate and E01 to communicate,,, Ive got the usb cable to connect the two and the E01 tells me communication error. Why? how do you get past this?
Old Feb 19, 2007 | 06:16 PM
tdiddy's Avatar
Finally Boosted!!!!!!!
They are not compatible.
https://www.rx8club.com/showpost.php...78&postcount=1
Old Feb 20, 2007 | 05:42 PM
Motr T's Avatar
OKay, dont i feel dumb. how or can i get the E01 to display my afr with just the LC-1 kit? or do i have to get one of the Innovate gauges?
Old Feb 20, 2007 | 06:20 PM
MazdaManiac's Avatar
Connect one of the analog outputs of the LC-1 to one of the analog inputs of the E-01.
Then, you need to setup the output using Innovate's software and setup the input channel to expect (and translate) that signal into something you understand.
Old Feb 20, 2007 | 06:42 PM
Motr T's Avatar
okay, so now ive got the E01 set up to control boost, w/out the emu, and the car wont idle. ??? im lost. it had a hard time idleing before the e01, but now it just sputters a second or two and dies... Ive been dropping alot of money into this car, and so far it hasnt fixed anything... WTF?
Old Feb 20, 2007 | 06:57 PM
1stgen8's Avatar
Threads like these are slowly changing my mind about adding a turbo.
Old Feb 20, 2007 | 07:12 PM
The E-01 has NOTHING to do with the way the car runs.
Dropping money into the car does nothing.
Perhaps they should.
I always state that if you can't do it yourself and implicitly understand the process and all of its details, you are better off not bothering.
I'm sorry to be so crass, but threads like this only go to prove that most people should not be doing this kind of work to their own car.
Hell, I know a dozen "professionals" that can't figure this stuff out.
Old Feb 20, 2007 | 07:34 PM
Motr T's Avatar
i dont have a choice i have to do the work myself, none of the shops in my area know anything about the rx8 except the dealership. I understand alot about the set-up, its just that everything ive tried has failed. the reason i think its the e01 is cause w/out it, there was alot more vaccum pressure, now the e01 is holding it at -1.0 or near it. and now it's not idleing. 1+1=2 right
Old Feb 20, 2007 | 07:53 PM
Sounds like you installed the boost control solenoid incorrectly.
Make sure you have the lines hooked up in the right order and that you pulled all of the plastic plugs out.
Old Feb 22, 2007 | 03:21 PM
Motr T's Avatar
OKay, went out after work today and started it. It idled better than i have heard it idle for a long time. drove it around the block a few times, and it idled great, no dieing at stoplights as long as i didnt start just rolling too soon ( i have this problem with pushing the clutch and letting my already gained speed carry me to the light then stop.) as long as i carried speed and left it in first till just before i stopped, it idled... about an hour later or so, it wont idle again... heat? i dunno, it ran great till it got hot...
Old Feb 22, 2007 | 05:59 PM
Motr T's Avatar
thinking about trying the idle adj. map. i think it's idleing too low, while i was in iraq, the guy that had the car said one of the cel's was because it was idleing too low... could someone help me out with an idle adj. setting
Old Feb 22, 2007 | 09:19 PM
rAte's Avatar
You might need to recirculate your BOV. I think the Greddy stuff still uses a MAF sensor. If you are stalling when you de-clutch comming to a stop your ecu is reading WAY too rich rightr after the BOV opens and causes the motor to stumble or stall. If you BOV has a leak or is set too soft you can have a rough idle as well.
I had the exact same problem on my previous Evo8 until I recirculated the BOV back into the intake. I am not a big fan of the SSQV...Good luck
Old Feb 22, 2007 | 10:53 PM
rotorocks's Avatar
RotoRocks Powered
LOL
Real Out loud
Old Feb 22, 2007 | 11:18 PM
Idle adjustment MAP doesn't do anything in the way the EMU is configured for the RX-8.
You can try the engine "anti-stall" feature, but it is tricky since the MAF is so sensitive.
True, though the "anti-stall" feature will address this. Adjusting the BOV so that it doesn't leak is important.
It is quite possibly the best BOV money can buy, bar none.
However, there are quite a few Chinese counterfeit versions on the market, so you have to be careful where you buy it from.
Nothing from TurboXS, Apexi, GReddy or Tial beats the SSQBOV.
Old Feb 23, 2007 | 12:23 PM
Motr T's Avatar
hey sorry my questions seem stupid. im not very familiar with this particular setup. everyone has to start somewhere right? I learn more and more about this car and setup daily. At least i come out and ask the questions rather than just trying to blow my engine... if you dont know, how do you learn?
Old Feb 23, 2007 | 12:25 PM
Motr T's Avatar
mm thank you for the help
Old Feb 23, 2007 | 12:54 PM
NP.
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
drebbrnator
Dec 27, 2018 07:02 PM
TotalAutoPerformance
RX-8 Racing
Sep 21, 2015 08:05 PM
ndamix
Sep 18, 2015 03:04 PM
