Jump Start or Trickle Charge?
Old Feb 12, 2007 | 10:05 AM
Nemesis8's Avatar
Bigus Rotus
This morning, unlocked the doors, turned the key over, and everything went black. No power at all. Funny, I did not remember leaving any lights on, so my question is:
What luck do you have with jumper cables verses trickle charging the battery? Any pros or cons?
Old Feb 12, 2007 | 11:59 AM
ken-x8's Avatar
Both work. Really just a matter of what's available and how soon you need to go.
If the battery is way down, you might need to leave the donor car running and cables connected for a few minutes before yours will start. But you'll be rolling in a few minutes, as opposed to many hours for a trickle charge. After a jump, of course, you need to either drive for some time or hook up a charger to refill the battery.
And you need to test the battery and charging system. And figure out why it went dead.
Ken
Old Feb 12, 2007 | 01:21 PM
Brettus's Avatar
Boosted Kiwi
move along , all taken care of , nothing to see here .
Old Feb 12, 2007 | 02:53 PM
using a regular battery charger for the OE or similar battery is better, trickle chargers are for racing batteries or for extended shutdowns
if you jump it and the battery is going out you may end up dead again at your destination
the car will die during idle if the battery is unable to hold a charge or DOA
Old Feb 12, 2007 | 03:14 PM
Nemesis8's Avatar
Bigus Rotus
^ Yep, normal charger should be better than trickle.
I have cables and a multi meter. It was odd that I lost complete 100% power. Not even a chirp or dim light anywhere, after turning the key.
Old Feb 13, 2007 | 08:13 AM
Mazda-Rati's Avatar
the WANKEL made me do it
^Did you get it running yet? Is there any chance it could it have been the immobilizer system and not the battery?
Old Feb 13, 2007 | 08:21 AM
Nemesis8's Avatar
Bigus Rotus
Weird - I got home and it fired right up!
Something caused a complete loss of juice, so I'll be inspecting things tonight.
Old Feb 13, 2007 | 10:26 AM
battery cable somehow got loose???
Old Feb 13, 2007 | 11:56 AM
Nemesis8's Avatar
Bigus Rotus
It was tight - maybe I have a loose fuse? Will check tonight.
Old Feb 13, 2007 | 06:21 PM
next time be sure to turn the key all the way over ...
j/k
Old Feb 14, 2007 | 05:18 PM
Nemesis8's Avatar
Bigus Rotus
LOL - it was my battery connection after all. All fixed.
Old Feb 14, 2007 | 06:35 PM
these are the cheapest POS battery connectors I've ever seen, just about to order another new pair because the original ones stretched and will not stay tight on my terminals. You can squeeze them and they'll stay tight for a while, but over time stretch and loosen again
Nisaja
Series II Interior, Audio, and Electronics
Nov 3, 2015 05:30 PM
atmd
Aug 19, 2015 12:43 PM
T_Mags
Jul 24, 2015 11:29 AM
Kangarhew
Jul 18, 2015 08:27 PM
