I think i messud up my car, HELP
Old Feb 4, 2007 | 11:48 AM
SpyderX,Inc.'s Avatar
FedExman04
hey yall. i need some help. i accidently hooked up the wrong teriminals to my battery and it started to melt the post and realized i hooked it up wrong. i went to start my car and nothing.he relay to the ignition clicks but the starter doesnt do anything. the raio and heater and the keyfob and parking lites doesnt work also. i kno yall may think i fu*ked up but im only human. so any suggestion bout wat happen to my ride. anything will help. thanks
Old Feb 4, 2007 | 11:51 AM
d j's Avatar
d j
hukbong himpapawid
check your fuses... new battery maybe
Old Feb 4, 2007 | 12:09 PM
DarkBrew's Avatar
Extraordinary Engineering
+1 on fuses.
Start with the basics. Get the Acc position working again first (display, basic accessory power) before you try to start it. That way you know that the electronics are powered up. If you're luck the fuses will have protected eveything.
Old Feb 4, 2007 | 12:12 PM
StealthTL's Avatar
Metatron
Check, mate.....
Check every fuse in the box, if the ECU has no power you ain't moving.
Don't forget the fusebox in the drivers side footwell.
S
Old Feb 4, 2007 | 12:14 PM
KkKAZzZ's Avatar
Sky Blue
You need to check all the fuse and i think your going to need a new battery for sure.
Old Feb 4, 2007 | 12:19 PM
Easy_E1's Avatar
Your lucky the battery didn't blow up in your face. Still amazes me how someone can do this.
Check all the fuses as was already said . Hopefuly you haven't burned up any of the wire harness. Take a good look at it around the fuse panel.
Old Feb 4, 2007 | 12:27 PM
NgoRX8's Avatar
damn that sounds scary.
Old Feb 4, 2007 | 01:16 PM
FedExman04
the battery is only 3 months old. i have a optima. all the fuses isnt popped. just found out my power windows and locks doesnt work. i justed happened to open my ecm to see if it was fried but its still looks good. so im still buged out. im still tryin to find out wats wrong
Old Feb 4, 2007 | 01:29 PM
Nopstnz's Avatar
Call the dealer or autoparts store.
Old Feb 4, 2007 | 04:35 PM
FedExman04
nevermind guys. i finally fixed it. i took apart the fuse box and found 1 more fuse on the side and it was 120 amps. that thing was popped and smelled really awful. i guess it just way overloaded. so if any of u have similar problems i hope this will help.
Old Feb 4, 2007 | 04:41 PM
DarkBrew's Avatar
So everything works or you just found the blown fuse?
Old Feb 4, 2007 | 04:45 PM
tony_673's Avatar
...is it over yet?
If that statement is any indication of his mental status ( ), I think we all know why things happened the way they did.
Old Feb 4, 2007 | 06:01 PM
FedExman04
car works fine now
Old Feb 4, 2007 | 06:11 PM
d j's Avatar
d j
hukbong himpapawid
...Im glad it is, now what's your "take-away" from this incident? what are the steps that you should've taken to avoid the situation? And what actions are you gonna take, in order to prevent this from happening again? LOL!
Old Feb 5, 2007 | 01:03 AM
FedExman04
look at the damn terminals before i start hookin it up..lol
Old Feb 5, 2007 | 01:14 AM
tar dooob de do , clap...
you are lucky x 2...
Old Feb 5, 2007 | 02:18 AM
that's the main power fuse and that's why it's there, count your lucky stars
Old Mar 2, 2007 | 09:22 AM
spraycola's Avatar
try using butter.
Old Mar 8, 2007 | 01:43 PM
smrx8's Avatar
**** happens that how you learn
Old Mar 8, 2007 | 02:14 PM
Its hard to find anybody to be as *smart* as you.
Old Mar 8, 2007 | 05:22 PM
ucleadguitar's Avatar
6 spd Newbie
this coming from somebody that lives in the city of garbage
Skyl3r
Dec 2, 2019 04:51 PM
Peanutbuttertruffle
Jul 24, 2015 07:49 AM
Bamaham
Jul 23, 2015 08:08 AM
AussieGray
Jul 16, 2015 03:58 AM
