AFR's at speed - open loop
Old Feb 2, 2007 | 07:15 PM
Brettus's Avatar
Boosted Kiwi
Just for fun I did a log of a high speed run today & thought it may be of interest .
First part of run is in 6th gear then I stopped & turned around giving it full throttle in 1st & 2nd before holding in second while waiting to pass a car .
Note how closely related to throttle posn. the AFRs are . I have about 10% fuel trimmed through my piggyback in most load points you see here.
Old Feb 2, 2007 | 07:47 PM
Brettus's Avatar
Boosted Kiwi
Also got my post count to 1000 with this thread - where's my tee shirt ?
Old Feb 2, 2007 | 08:05 PM
9291150's Avatar
Don't mean no disrespect but...huh?
Old Feb 2, 2007 | 08:46 PM
DarkBrew's Avatar
Extraordinary Engineering
It's a cool chart but I'm not sure what 10% fuel trimmed means relative to a stock '8
Old Feb 3, 2007 | 06:33 AM
Xyntax's Avatar
THREAD KILLER
throttle release causes less fuel injected = lean AFR
Look up NA tuning experiments on this site. It really helped me during my tuning days.
So you're doing 10% reduction all the way? Even below 5800 rpm? I wouldn't touch fuel trims below that range unless you want your car to start injecting more fuel than you need in cruising speeds (in the long term)
Old Feb 4, 2007 | 06:16 PM
Brettus's Avatar
Boosted Kiwi
I'm pretty confident I have only taken fuel out in open loop which by my tests is at 4000 rpm+ & 30%+ throttle . It is possible to be in closed loop over 4000 & under 30% but only very rarely. EG when going down hill .
Long term fuel Trims shouldn't be affected by these rare occurances .
Old Feb 5, 2007 | 09:43 PM
which version of the scanilizer are you using? i cant seem to get the fuel open closed to work.. maybe that i am using the dig gauge option..
Old Feb 5, 2007 | 10:42 PM
Brettus's Avatar
Boosted Kiwi
version 1 - you'll find it on the 'fuel system status' gauge option .
Old Feb 5, 2007 | 10:44 PM
what dial option are you using?
JimmyBlack
273
Feb 10, 2020 10:23 PM
vapor2
Sep 21, 2015 01:36 AM
titaneum_grey
Sep 6, 2015 10:21 PM
