Lol, New member of the RX-8 club, and the failed Power steering club!
Old Jan 25, 2007 | 05:58 PM
rx8dentist's Avatar
Well, Finally Got my snow tires on and it was like night and day. Then today i turn my car on, and the Power steering has gone. Yes, I've read all the threads about similar problems with other people's RX-8's. Just wanted to let you know, I have 239 KM on the Odom. That didnt take long! Off to the dealer.
Old Jan 25, 2007 | 10:33 PM
rx8dentist's Avatar
The Power steering did completely fail. Once it went, it went, It didnt come back after a restart. Also, it was complete, not like Those cases I've read about where they get some power when turning left or after the engine warms up. There was no other stalling or glitching that I can think of. Ill be taking it to the dealer on Saturday and I'll definitely update you. The only other thing of note was that when I first brought it home, the engine light came on, but called the dealer and he said its probably nothing, it would run self diagnostics and probably turn off after a couple of runs and it did.
Ill definitely keep you posted on it though.
Old Jan 27, 2007 | 10:17 PM
rx8dentist's Avatar
Well, I got up to go to the dealer today, and of course the power steering was fine! So I drove there anyway, and he told me that when the temp drops below -20 C, the power steering will shut off to protect itself. IT makes sense i guess, the last few days were ridiculously cold. Anyway, drove all day today and no problems. Ill keep you guys updated if it goes out again.
Old Feb 1, 2007 | 07:11 PM
Rx8black's Avatar
Let me know in a couple of month Where I `m from the temp are in the 80`s.
Old Feb 18, 2007 | 12:02 PM
Goober8's Avatar
RE雨&
Mine just gve up today. I was changing to a new battery and after that the EPS warning light appeared on my dash. I've checked the 60A fuze and wiring and all seems fine. Any gurus here can give a pointer? Someone said to check the plug on the shroud of the Radiator on the right side of the battery. Which plug is this?
Old Feb 18, 2007 | 01:52 PM
^^ it's actually both of them. The big ones are the power connectors...and the smaller one is the bus connector that talks to the control module and the CAN Bus
Old Feb 18, 2007 | 01:55 PM
DarkBrew's Avatar
Extraordinary Engineering
I was driving mine at -23C the other day with no problems.... What temp were you reading when it failed?
Old Feb 18, 2007 | 09:40 PM
Goober8's Avatar
RE雨&
Hi,
Left the car overnight. Went straight to start-up the car again this morning. Everything is fine now. I think the EPS Controller took awhile before it stabilised after I reconnected the battery. Thanks again.
Old Nov 11, 2007 | 11:17 PM
StefYVR's Avatar
Guys If you change the battery or disconnect the battery, you will get a EPS light to come on, The proper procedure is to start the car and turn the steering full lock to lock in both directions and then back to center. Shut the car of and restart it.
READ YOUR MANUAL ! Its a calibration procedure. Had it happen to me every time I disconnected the batrtery when trying different Intake systems. It reset fine using that procedure and have never had a glitch with it.
Old Nov 11, 2007 | 11:20 PM
I will check the power steering connector around the fan Area. if you leave the stock coolant hose where it is. overtime its gonna spill coolant out, jam the connectors, and finally one day it might *short* or *block* it, giving you the error.
Tyblat
9
Aug 6, 2015 10:43 AM
SIllver
Aug 1, 2015 07:34 PM
