Max Zone GT on RX8s....
Old Jan 23, 2007 | 09:19 PM
DT8's Avatar
DT8
Hi mates,
I'm new here in the club.
Has anyone used Max Zone GT? Does it work the way it claims on our 8s?
Appreciate your replys.
Old Jan 24, 2007 | 10:39 PM
gfoo's Avatar
pian lang one, just ground your car properly can liao
Old Jan 25, 2007 | 12:02 AM
DT8's Avatar
DT8
Thanks gfoo. I used to have a Raizin Volt Stabilizer but the plastic casing melted after some time in the hot hood. Kena con to have that installed and cost so many times more....NB!
Is there a better Volt Stab to recommend? and whats the average price of a decent one?
Thanks.
Old Jan 25, 2007 | 03:08 AM
gfoo's Avatar
Any volt stabiliser will do, Pivot raisin lowest i think can get for about $80. There's this guy called jason that does freelance grounding - 8 points for $80. Did many of the guys cars here. will send you his contact if i can find it.
Old Jan 26, 2007 | 08:17 AM
Emperor's Avatar
aka Spectre
Thanks.
It melted? Installed on the exhaust?
Old Jan 28, 2007 | 09:04 PM
DT8's Avatar
DT8
Haha..that's a good one.
No, just on top of the battery cover. It was a "made in Taiwan" yellow coloured VS.
No doubts on its performance as a VS but just the durability of the material in our engine bay.
I have switched to a blue Pivot Raizin liao. Hope it hangs on this time.
Old May 1, 2007 | 04:54 PM
dgrx8's Avatar
FN GR8
pivot
hey, can you post on your impressions w/ the pivot raizing unit. i'm thinking of getting the raizin spark earth (red, type s)
thanks
Old May 1, 2007 | 09:28 PM
DT8's Avatar
DT8
dg,
My Pivot Raizin is a Voltage Stabilizer with 13mm silver grounding cables, diff function from the spark ignition red one.
So far so good with the Japan blue colour model and I think most of us using this or the more expensive Hot Iznama(not sure if I spelt it correctly).
You will notice an immediate improvement on your headlights beam being concentrated (can see the edge of a stronger beam at dim places) instead of dispersing beam... not so much on the rest.
But I don't think there is much difference if yours is a new car tho....
You need to check with the bros who are using the Raizin (Red) Spark.
Or best still, you try first and let us know. Cheers
jgsnake
General Automotive
Jul 30, 2023 10:26 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
projectr13b
RX-8 Racing
20
May 14, 2016 06:25 PM
Learners_Permit
Sep 27, 2015 07:38 PM
mattymack
Sep 6, 2015 10:33 PM
