RP shifter problem
Old Jan 23, 2007 | 05:26 PM
devildog1679's Avatar
Unhappy RP shifter problem
I have had the shifter for about three months with no issues. Lately I notice that first gear requires more force than normal. The extra force is required not when I’m stopped but when I’m rolling. What can the issue be? I recently changed the transmission fluid but all other gears feel great. Any ideas?
Old Jan 27, 2007 | 11:38 AM
you're downshifting into 1st while moving? (that's not recommended)
Old Jan 27, 2007 | 11:41 AM
DarkBrew's Avatar
Extraordinary Engineering
If you need to catch first while rolling you'll need to master rev-matching and probably heel and toe technique.
Old Jan 27, 2007 | 11:49 AM
No reason to shift into first moving.....We have low torque..but it's not that bad :D
If you changed to Synthetic...the syncro's may be a bit slower to react, cause the oil is a bit sticky
Old Jan 27, 2007 | 07:46 PM
Whats wrong with shifting into first while moving, I only do it when Im going slow mainly bellwo 5mph. Mostly when I coast in N to a stoplight then it turns green, to slow for second so I use 1st. As for the rev matching I am starting to do that but it doesn't help much.
Old Jan 27, 2007 | 08:29 PM
Nothing if you can synch the gears....there just is a higher probability of there being a poor RPM match into first because of the ratios......
I haven't found a reason to do it....unless you are racing away from a light.......2nd will work well
Old Jan 27, 2007 | 09:23 PM
the shifter itself really cannot change the caracteristcs of the transmission.... if you are unsure put the stock shifter back in and see if it changes...
i am noticing the same thing, but my trans fluid is due for a change...
Old Jan 27, 2007 | 09:39 PM
BoosTED's Avatar
I have adopted not downshifting into first if moving but if I need to for some reason I blip the gas pedal as I am clutching.
I also have noticed it is a tougher if the fluid is cold.
The shifter isn't the problem with the stock shifter it just would feel like it was going more into gear because it is not as solid as the AF SS.
I am thinking of bleeding the clutch again is there a benefit of bleeding it when the fluid is hot vs cold? (I can see a downside being the engine is hot and to get back to the bleeder valve for the clutch a person is bound to bump the engine on the way back behind the oil filter). I have the Speedbleeders so it isn't as much of an issue, since I would only get burned at most twice. Once to loosen and once to tighten. I can live with that.
Old Jan 27, 2007 | 09:42 PM
ss line maybe?
Old Jan 27, 2007 | 09:47 PM
Try bleeding it...but usually due to the small cylinder size...you will really notice any air in the system.
It is really a lot to expect the syncros to work moving in first...a lot of tranny's don't even put syncro's on 1st gear....cause if you are moving second will usually be fine
Old Jan 27, 2007 | 09:51 PM
mysql101's Avatar
I can't see how the shifter would cause shifting into first to be more difficult..
Old Jan 28, 2007 | 02:41 AM
BoosTED's Avatar
Originally Posted by swoope
ss line maybe?
I have a braided stainless clutch line installed.
(that helped with consistancy)
With the speedbleeders is there a preferred way to press on the pedal? Like slowly and then holding on the bottom, medium paced or fast?
Old Jan 28, 2007 | 05:47 PM
funny you ask.. i dont know.. but the bike people swear by them..
i am debating on how to change the fluid. it needs to be done, and at the same time i am going to pull and repaint the calipers.
i am thinking about going to all stainless lines and that would be the time to do it..
i also have to change the rotors and pads (new toys)
let me know how it works out..
Old Jan 28, 2007 | 11:18 PM
I got my agency ss lines for brakes and clutch in yesterday I'll put them in next week. As for the shifter issue, I'll just leave it as is. Since there is no issue with the other gears and since there is no grinding going on I guess its just normal or me just being paranoid. Thank you all for your help
Old Jan 29, 2007 | 05:28 AM
BoosTED's Avatar
I found the answer: using the speedbleeders the pedal should be slowly pumped and it is better if the pedal doesn't go to the floor.
ÜberJumper
Canada Forum
21
Feb 20, 2025 11:57 AM
Prescription 8
Non-Rotary Swaps
117
Feb 14, 2018 12:07 PM
Vedivan1
Sep 20, 2015 04:39 PM
Vedivan1
Sep 18, 2015 12:39 PM
