TPMS fix
TPMS fix
this should work? For everyone that has a spare tire, if you put all the sensors inside the spare tire or lets say a wheel barrel tire. the system would not trigger, and you would also know when your spare is getting low. LOL!!!
sensors activate when the tire spins... a better idea that yours was tried, and failed..
You could take the wheel barrel tire and mount it on a wheel chair motor in your trunk, powered through a solid-state motor controller tied to the wheel speed sensor.
That'll give you the inertial component as well as the pressure component.
Or, you could just ignore the light.
Small piece of electrical tape over the light.
I think you coould just attach the wheel barrow tire to the back of the car with the 4 TPMS' duct taped to it so they rotate . Like a little wheelie bar.
U-Stink-But-I-♥-U
Originally Posted by Phantom Menace
Or...you could buy TPMS compatible rims? Why lose the function? I think its cool that it warns you of low pressure. Especially since most of us do not have spares.
You stop seeing the light after about 6 months.
Originally Posted by Asmoran
Okay, so if it only activates when rotating, why does mine come on before I even move the car? (I have a leaky valve, and need to add air every couple weeks)
if over 24 hrs... i have to get up to 10mph before it happens, and then i get a chime..
Shankapotamus3
Mar 14, 2021 03:53 PM
Danield97
Sep 30, 2015 05:59 PM
drlubell
Sep 26, 2015 11:58 PM
