Where should i start?
Old Jan 16, 2007 | 11:13 PM
ChaseRX8's Avatar
right now my 8 is stock but i have a little extra money so i can do something to it what is a good way to add some hp but still keeping it drivable and affordable looking to spend around 300-400. And also with Air intakes what are some good ones
Old Jan 16, 2007 | 11:23 PM
jzrx8's Avatar
Drive Like You Stole It
Racing Beat intake is $335 + $135 for the air duct. And your already over your limit. Things in your range Agency Power Pulley $160, Mazsport Cooling mod $160, Axial Flow Short Throw Shifter $259, Flywheels $360 - $500+ depending on which one you go with, Racing Performance Supercat $395, that about all i can think of. Everything for this car is very expensive, myself I just spent almost $700 tonight on the SuperCat and Axial Flow Shifter.
Hope this helps,
Jay
Old Jan 16, 2007 | 11:53 PM
the stickys,
then the search bar.
pm me if you need help with that..
Old Jan 17, 2007 | 10:20 PM
ChaseRX8's Avatar
ok thanks
i have narrowed it down to an intake (Revi or Mazdaspeed) or the supercat
but my question is will the supercat even help much if i use it with the stock exhaust
will i gain any hp or create a deeper louder noise
Old Jan 17, 2007 | 10:23 PM
ok thanks
a bit,
and not so much..
nothing is earthshattering in these mods... and the stock exhaust quiets everything down a whole lot..
Old Jan 17, 2007 | 11:18 PM
peterisurhero's Avatar
peterisurhero
if you want an intake, i would recommend the aem because it is the cheapest out of all of them and will get you just about the same power as the other ones(the only bad side is that the dealership wil void your warranty) as for the supercat, i think its quite expensive ( around $350 from wat im aware of) and you can just get the B&B test pipe and you can get it for about $250. as for the sound, you'll need a catback to make the sound deeper.
Old Jan 18, 2007 | 07:09 AM
CKay's Avatar
I put on the RP Supercat yesterday, w stock exhaust, it sounds nice and u can realy feel it up top, this and a k&n drop in are my first mods and u can due both under $500
Old Jan 18, 2007 | 12:34 PM
kartweb's Avatar
Buy an XBOX 360 or rent a shifter kart for a day. Otherwise the RX8 will turn into a money pit.
Old Jan 18, 2007 | 12:39 PM
Neon underglow kit. Tirefly's, glowing fuba antenna. just to name a few
Old Jan 18, 2007 | 01:29 PM
94MR2-T's Avatar
https://www.rx8club.com/series-i-aftermarket-performance-modifications-23/important-information-all-modders-104756/
Audio Concepts ATL
Sep 26, 2021 01:59 PM
wanted797
Aug 26, 2015 11:24 PM
harithac
Aug 26, 2015 09:24 AM
poppinparker
Aug 10, 2015 09:20 AM
T_Mags
Jul 24, 2015 11:29 AM
