Heads-up on lug-bolt torque
Old Jan 13, 2007 | 11:54 PM
N10S's Avatar
I just recently bought a new 2006 RX8 a couple of months ago. After driving it several thousand miles in a short period (1 month) of time, I swapped out the stock wheels and tires for a set of winter tires/wheels. I was shocked when I went to remove the stock wheels and tires as the lugs were barely tight!! I am always **** about keeping my wheel lugs torqued when changing them, but had assumed the stock wheels would have been ok from the factory. This was "not" the case with my car and it may be worth it to double check and re-torque just in case.
JR
Old Jan 14, 2007 | 12:07 AM
JR
do you know what the stock tq is, or what the tsb says to make it?
Old Jan 14, 2007 | 12:13 AM
Easy_E1's Avatar
It is always recommended to retorque the wheels after the first 25 miles.
The owner's manual recomends between 65 - 87 ft/lbs of torque. I would suggest 85ftlbs.
Old Jan 14, 2007 | 12:15 AM
not correct.
Old Jan 14, 2007 | 12:18 AM
what is 108 ft lbs. for 500 mm
Old Jan 14, 2007 | 01:03 AM
MazdaManiac's Avatar
Yeah, they upped the torque numbers after the "snapping noise" TSB.
Old Jan 14, 2007 | 01:19 AM
avenger's Avatar
likes to do drawerings
WHAT?! 108ft-lbs???? I'd be doing mine at 85ft-lbs. Are you guys serious?
Old Jan 14, 2007 | 02:39 AM
and get rid of the OE lugnuts unless you like dealing with galled threads and broken studs ...
Old Jan 14, 2007 | 03:27 AM
Old Jan 14, 2007 | 08:25 AM
Easy_E1's Avatar
OK fine didn't know about the update.
You can stop spanking me now.
Old Jan 14, 2007 | 08:41 AM
RX8Maine's Avatar
Are you referring to the fact that the bezel angles for the lug nut and wheel to not match? I am not sure what you mean by "galled". I thought for sure my car (purchased used) had the wrong lug nuts on it, but the dealer confirmed that they are the right part.
What do you recommend for replacement?
Old Jan 14, 2007 | 08:45 AM
Easy_E1's Avatar
Galled just means the threads are chewed up. As in so much friction between the nut and stud threads when turning that it tries to weld itself together.
Old Jan 14, 2007 | 09:26 AM
carbonRX8's Avatar
U-Stink-But-I-♥-U
Mcgard Spline drive lugs are nice (though pricey.) http://www.good-win-racing.com/mazda/miata/21-1058.html There are a number of reasons to get them (security, deep threads) but you can look them up and read.
Old Jan 14, 2007 | 10:15 AM
El Kabong's Avatar
Any other suggestions for lug nuts for stock rims that would also be usable for aftermarket rims when I upgrade?
Thanks,
Kabong
Old Jan 14, 2007 | 10:46 AM
RX8Maine's Avatar
Thanks,
Kabong
Aftermarket wheels should come with appropriate lugs.
Old Jan 14, 2007 | 10:59 AM
VarneyMazda's Avatar
Northeast Pimpin'
any aftermarket lug with the right thread pitch would work, they are mostly all similar, i personally went with greddy ones.
Old Jan 14, 2007 | 05:24 PM
Brice-RX8's Avatar
I have rotated my tires probably 5 times or more since owning my car and always torque them down to 105 foot pounds and never had a problem with them. This is on the OEM wheels too.
OnebaddRx8
Aug 25, 2019 11:34 PM
airlive
Nov 4, 2016 12:15 PM
Cookingislife1226
Mar 20, 2016 09:51 AM
FubarI33t
Sep 28, 2015 08:45 PM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
