Steering wheel control panel removal
Old Jan 9, 2007 | 09:21 AM
King105's Avatar
Hi,
Anyone has any clue on how to do it (no luck w forum search), or any workshop (mine is PI) that knows? The one on the right is rattling loud, at traffic stops (in D gear). I'm a quite surprised.
Thanks in advance.
King105
Old Jan 9, 2007 | 09:32 PM
Swerve76's Avatar
It might be your engine mounting that has worn out bro which is causing all the rattling sounds when you are stationary.
Its a known problem with the Renesis and mountings need to be changed every so often.
I had the same problem and MM changed mine for free as my car is still under warranty. The car now is smooth as silk and has zero noise & vibrations, even when stationary and idling.
Old Jan 9, 2007 | 09:39 PM
x2
Old Jan 9, 2007 | 11:57 PM
theboy's Avatar
RX8 newbie!
Originally Posted by King105
Hi,
Thanks in advance.
King105
They call it "Recall" in this forum. it is actually a small problem. u do not need to open up the panel. all u need is to grease it. u have to grease it from the holes located between the hood and the windshield. what u hear is the sound of 2 plastic knocking each other without oil. Go Tech section look up at the Issues & problem section.
Old Jan 10, 2007 | 08:29 AM
King105's Avatar
hi,
I am aware of the engine mount thingy - thks. But it can't be - mine's only at 6K mileage! The car does idle rough at stops, but I think it's ok.
Perhaps I should clarify - it's the small blank panel cover on the steering wheel on the right side - the left side is the audio control panel. It buzzes like a bee, of and on.
Cheers.
Old Jan 10, 2007 | 07:46 PM
airspeed's Avatar
Velocity REight
hi,
Cheers.
If you are right-handed and use the downshifters often like me, check the downshifter on the right. Mine is rattling a bit and is loose, unlike the left side. I only hear it rattle when my engine started to vibrate, otherwise I wouldn't know it's loose.
I would think there are some kinda screw at the back of the said panel u mentioned.
Is there? I'm just guessing...
Old Jan 10, 2007 | 09:42 PM
M-ster's Avatar
Yup, I do have some rattling noise too, like some wire came loose from its clip and its rubbing against other surface when ever I'm doing heavy steering (eg parking). Hope some one can advise the 'operation' to access the steering. M only afraid of the air-bag. thus dont really dare to touch it.
Ta
Ugafan97
SE For Sale/Wanted
Apr 28, 2016 03:35 PM
M RX 8
Aug 5, 2015 06:45 PM
04MazdaMan
Jul 15, 2015 08:23 PM
