Dyno'ed on RotoTest today.
Old Jan 6, 2007 | 03:16 PM
Lasse wankel's Avatar
Lasse wankel
Yes today my RX-8 header system was putting to the test against the stock exhaust manifold. Baseline was 196 hp@8500 rpm with stock manifold. Prototype header made better results: 202 hp@8000 rpm! That's a gain of +7 hp at cranc at 500 rpm lower rpm. Now my "Tig Guru" Peter is making a new one of stainless steel with equal length primaries. I hope to see a solid +10 hp of the "new" header when it's finished. If everything goes the way i plan i will sell the header parts to Usa.
/Lasse
Old Jan 6, 2007 | 03:23 PM
RazzyBRX-8's Avatar
Representin'!
You should really post the dyno sheets. Other members are going to call you out on it. I promise.
Old Jan 6, 2007 | 03:45 PM
Punksux's Avatar
and some pics
Old Jan 6, 2007 | 05:47 PM
peterisurhero's Avatar
peterisurhero
if its true. PROPS ahhah get it going soon!!! im running out of things to put in my car to stay n/a. good luck
Old Jan 6, 2007 | 11:52 PM
a proper log manifold will make just as much performance, be less costly to build, and radiate less heat into the engine bay ...
Old Jan 7, 2007 | 04:03 PM
Lasse wankel
Hi guys! I have all the hard data in the RotoTest computer and i am first gonna do the curves with log manifold and header style. Just be patient i will upload here. I have now driven over 200 km with the new header and it feels stronger every time you floor it! Maybe i am gonna do a second prototype header that my old "piston" guru Roger will try to made for me. I keep you updated!
/Lasse
Old Jan 7, 2007 | 06:49 PM
fwiw, hub type dynos will read high compared to dynos that work off the tire contact face because you lose the wheel inertia and tire friction. Your 202 hp reading would be approx. 192 on a Dynojet, a Mustang dyno would be around 185
Old Jan 8, 2007 | 12:35 AM
Lasse wankel
Ok thank's for the info!
/Lasse
Old Feb 10, 2007 | 06:36 PM
Mikeluvs8's Avatar
whats up with this header any word?
Old Feb 10, 2007 | 07:02 PM
Cody Red's Avatar
always filling [the c]up
yeah, how 'bout them results/pics?
-Cody
Old Feb 10, 2007 | 07:17 PM
Fanman's Avatar
I might be retarded at math, but isn't 202-196 = +6 hp. Not to be nit picky. Those are nice results.I think it's plausible. Other firms have gotten about +3 hp from some standard designs, so +6 hp doesn't sound like a stretch on a custom Renesis unit.
Old Feb 10, 2007 | 08:23 PM
shaunv74's Avatar
Power!!
I think he is comparing the results at 8000rpm for the stock run. The 196 was at 8500 stock. The 202 was at 8000rpm with the header. If my math is correct that should mean he got 195 at 8000rpm. Yep a dyno sheet would be helpful along with how the data was recorded. Is 202 at the wheels with the tires on or at the crank (assuming that is a calculation) or at the hubs?
Old Feb 10, 2007 | 10:39 PM
1stgen8's Avatar
Sounds good but will we be able to afford it? How bout a price.
Old Feb 10, 2007 | 10:49 PM
you aren't listening, it doesn't make any difference
even my manifold doesn't make any power difference except that it drops a chunk of weight off, a big drop of weight is all you can get out of an exhaust on an unported Renesis
the entire OE exhaust system (manifold, catpipe, catback muffler) weighs 79 lbs, mine ways 26 lbs; a 53 lb drop
Old Feb 11, 2007 | 11:33 AM
Brettus's Avatar
Boosted Kiwi
Team , I thought you reported it did make more power with your manifold ?
Old Feb 11, 2007 | 12:00 PM
initially we found that to be true (as Lasse is reporting), but we discovered later that the OE parts can make the same power. I 'm not at liberty to say why/how yet, but I have seen a bone stock RX-8 put out near GrandAm power levels at the rear wheels
I reported way back when that my goal was to lose weight without losing power, I'm down at 2700 lbs with full interior and the original bodywork, unfortunately I'll have to add a few pounds back because the exhaust won't meet the sound limits imposed at the area I relocated to, some extra pipe and muffler(s), still trying to determine the best course of action, I'll be losing a few lbs too on some other mods so it may be a wash
ASH8
General Automotive
2029
Apr 10, 2026 02:06 PM
05rx8mazda
Nov 28, 2015 09:42 AM
BERG
Oct 8, 2015 09:28 PM
ErwinN
Sep 23, 2015 09:29 PM
