new front brakes?
Old Jan 4, 2007 | 02:32 PM
2tone's Avatar
The RX-8 is missed
new front brakes?
i have about 38,000 miles and after my last check up was told my front brakes need to be changed. obviously mazda did a great job with the stock breaks, but has anyone gotten aftermarket brakes that perform better? i don't think i can afford brembo...
Old Jan 4, 2007 | 05:46 PM
ca18detsilvia's Avatar
i have carbotech panther plus brake pads and they are awsome, only thing is they chew up the rotors and dust more than stock, but if you can get past that they are freakin awsome, on the track i was able to outbreak brand new CarreraS's w/ slicks, deff a good for the money
Old Jan 5, 2007 | 12:52 AM
BaronVonBigmeat's Avatar
Senor Carnegrande
I have racingbrake 1-piece rotors + Hawk HPS pads. My rotors warped so I just wanted a good stock replacement, and these have been good so far. No noise, far less dust, slight improvement in braking feel, and the rotors stay shiny.
Old Jan 5, 2007 | 10:40 PM
There are no brakes made better than stock. No manufacturer has proved it.
There are ones that way less and fade less on the race track but that's it.
Nothing you will see for street applications.
Old Jan 7, 2007 | 05:13 PM
jd pilot's Avatar
How about those heat dispensing discs? The ones with the grooves in them like these?
http://www.mazdatrix.com/8brakes2.htm
Are these any good?
Old Jan 7, 2007 | 05:44 PM
BoosTED's Avatar
Slotting or drilling rotors weakens the rotors and have been known to crack because of it.
The best recommendation from the majority is to stay with a solid rotor face.
Old Jan 7, 2007 | 05:52 PM
DrDiaboloco's Avatar
Pining for the Fjords
It's also my understanding that slotted/drilled rotors are not slotted/drilled for heat dissipation but for gas dissipation. Naturally the incresed surface area/airflow through and around the grooves and slots will increase heat-related fade resistance, but that is not the primary reason for doing it. Keep in mind, too, that the increased surface area for cooling/gas relief = reduced surface area for pad-to-disc contact and may actually DECREASE braking performance, and improper chamfering of the holes and slots can do the cheese grater treatment on your pads (and increase the likelihood of stress risers in the modified areas causing cracking).
Actually, for street use, the primary reason for slotting and drilling is to make people look at your discs and go "ahhhhh".
Old Jan 7, 2007 | 07:06 PM
I would define lighter, non-warping, more even pad wear, and more finess control at the limit as better
Old Jan 7, 2007 | 07:11 PM
^^ I agree.....I have gone back to my stock front brakes for the winter....cause my snow tire setup wouldn't fit over my BBK...
The stock brakes are good...great even for a street car, but the Racing Brake kit has much better feel, are lighter....and the rotors wear like iron
Old Jan 7, 2007 | 07:31 PM
Originally Posted by dannobre
... and the rotors wear like iron
lol, because they are iron, albeit very high strength iron
Old Jan 7, 2007 | 07:54 PM
ZoomZoomH's Avatar
Mulligan User
the stock pads you buy from the dealer comes with all new hardwares (clips and shims and anti-squeak grease) for a thorough install, i just put on a pair for the fronts on saturday, and is very pleased with the results so far
for street use, can't really beat what you get from the mazda factory brake pad kit.
Old Jan 7, 2007 | 07:56 PM
ZoomZoomH's Avatar
Mulligan User
actually the real reason i bought the stock brake pad kit is because i fubar'd my last brake pad install and had to destroy the old shims in order to remove the old pads
Old Jan 7, 2007 | 08:03 PM
Damn...I forgot the smiley again
Old Jan 24, 2007 | 11:35 AM
Phantom Menace's Avatar
II SOCIETY
This is not necessarily true. ALL motorcycle brakes are X-drilled and will out brake any car. If the rotors are of a quality manufacturer, then it should only help improve your braking--not the "bite" but will decrease the fading during hard braking.
Homemade slots and X-Drilling, sure. That will kill ya--literally. Go with a trusted manufacturer.
Does anyone know who makes the rotors for the RX7 store?
Old Jan 24, 2007 | 02:15 PM
LionZoo's Avatar
road warrior
Motorcycles outbrake cars based on pure physics. It's much easier to stop a 700 pound object from 70mph than it is to stop a 3200 pound one. Check the brakes of any serious racecar and you'll find they aren't cross drilled. If cross drilling offers an advantage, you'd think they'd use them.
Old Jan 24, 2007 | 02:17 PM
Porsche must be completely clueless then ...
Old Jan 24, 2007 | 02:18 PM
II SOCIETY
But you didn't mention that cars have 4 rotors and more tire surface...bikes only have 3 calipers on 3 rotors with much smaller tires. AND, the track on a bike is linear not on four corners...
Old Jan 24, 2007 | 06:41 PM
RoXanneBlack8's Avatar
stop flooding ur engines
"But you didn't mention that cars have 4 rotors and more tire surface...bikes only have 3 calipers on 3 rotors with much smaller tires. AND, the track on a bike is linear not on four corners..."
stop....just stop man........quit while ur ahead.........
a bike weighs 700 pounds and an rx8 weighs 3000 lbs.....are you kidding me bro
porsche, ferrari, lotus, lamborghini, aston matin, audi, for gods sake even hyundai uses drilled rotors.....and the beenefits are worth it, some ferraris and porsche even have optional Carbon Ceramic rotors. they r like a 5k option!....but for absolute RACE, NEVER see the street setup is slotted......case in point.....Super GT (formerly JGTC) race cars, etc etc etc
RXFEVER
Aug 29, 2018 10:14 AM
Kahl
NE For Sale/Wanted
21
Aug 5, 2017 02:49 AM
RXFEVER
Sep 11, 2016 02:51 PM
airlive
Sep 7, 2015 08:32 PM
