CEL and symptoms
CEL and symptoms
Got a CEL tonight, doing about 70 on the freeway. Never being one to leave it well enough alone, I drove around to get some symptoms.
No noticeable power loss... yet. It does seem to have jerkier power delivery, but it could be in my head. The only real issue I've had was once it wouldn't rev past 7500 rpm, but I was on a bump with negative g's and low on fuel, so it might have sloshed about the tank and not flowed right. The symptoms are overall consistent with a bad cat, but then, I have a Bonez Supercat. I've also had the starter/battery/plug TSB's done, but not the latest recall. Any ideas anyone?
Not sure what you mean by " The symptoms are overall consistent with a bad cat...", in the context of your statement "No noticable power loss...". Was this a momentary flash of the CEL when you were at speed? If so, it is probably the infamous random misfire that has plagued some owners. Generally, it's nothing to worry about if the performance of your car seems normal.
If you continue to get the CEL, have the dealer diagnose the problem. Could be a bad spark plug or coil, assuming it is momentary.
Originally Posted by TeamRX8
you need to read the CEL with a OBD2 scanner and start from there, guessing isn't going to accomplish anything
Shankapotamus3
Mar 14, 2021 03:53 PM
Evan Gray
Sep 26, 2015 12:30 PM
