clutch lever arm
Old Dec 23, 2006 | 01:10 PM
NgoRX8's Avatar
clutch lever arm
ok, tried to figure this out myself, but i haven't seen anyone post of a similar situation so here it goes
it seems as though i have made a little rip in the panel that the clutch lever arm stopping bracket hits when pushing down on the clutch all the way. i noticed this because it started making my clutch stick a little if the clutch it pushed all the way down. i am hitting padding there, not hard material.
wonder if anyone has had this happen or if anyone can share some insight.
not completely sure, but it does look like my clutch pedal is a lil higher than others i have seen from pics. i thought the stopper is suppose to hit into that rectangular dip, where it is infact hard material.
-danny
Attached Thumbnails clutch lever arm-img_8688-small-.jpg   clutch lever arm-img_8690-small-.jpg   clutch lever arm-img_8689-small-.jpg
Old Dec 24, 2006 | 11:51 PM
NgoRX8's Avatar
bump, no one?
Old Dec 25, 2006 | 12:21 AM
sorry,
did not see this, have you replaced the clutch recently? as my pedal had to be adjusted after the motor install...
also a tsb on the slave cyl could change the pedal height.... and charles hill had a pedal failure..
Old Dec 25, 2006 | 12:39 AM
NgoRX8's Avatar
i knew you'd find your way into here, swoope.
i've never had my clutch replaced though. still on factory clutch at 15k miles. when you had to have your pedal adjusted, was it adjusting the pedal stroke and play movement?
in this pic of omicron's pedal, it look like my pedal is 'vertically' higher. when using the brake pedal as the point of reference in both pics
is that something you or charles had a problem with?
Old Dec 25, 2006 | 01:03 AM
the pedal height is adjustible...
give me a few and i will find the broken pedal thread, and the tsb....
i have to change computers..
Old Dec 25, 2006 | 01:09 AM
NgoRX8's Avatar
thanks a lot swoope!
Old Dec 25, 2006 | 01:22 AM
https://www.rx8club.com/series-i-tech-garage-22/fork-goes-snap-102596/
http://www.finishlineperformance.com...4-06-1641a.pdf
btw, to adjust the height of release all you need is a 12 and a10 mm wrench. one each..
Old Dec 25, 2006 | 01:25 AM
a note.. look under the carpet.. i bet you find a rubber bumper... i dont know that we have on as i have never looked, but the dents in the plastic make me think you fell off.
Old Dec 25, 2006 | 01:57 AM
NgoRX8's Avatar
thanks swoope. ill look into it.
maybe i should get another 8 to do a actual side by side comparison and see what's wrong.
Old Dec 25, 2006 | 05:11 AM
Charles R. Hill's Avatar
Owner of BHR
Take a look at the spot welds that hold the pedal bracket together. If your pedal has started to feel a little "mushy" or sounds noisy when you press it down, the bracket is probably starting to separate. When that happens the spot welds are cracking and pulling apart. My bracket broke most probably because the pressure plate assembly I put in the car stressed it beyond it's limits for the past two years. I won't put the heavy plate back in until I make a stronger bracket to handle the load.
Old Dec 28, 2006 | 09:50 PM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
I just had my slave cylinder and clutch pedal replaced. They said I broke the welds. What is a slave cylinder and how did I brake the welds?
Old Dec 29, 2006 | 10:40 AM
Owner of BHR
The slave cylinder is the part down on the clutch bellhousing that moves the pushrod to move the clutch fork. On one end of the system is your pedal and the other end is the slave cylinder. There aren't any welds on that end, though, just two bolts that hold the cylinder to the bellhousing. The only place there are welds are on the clutch pedal bracket under the dash and that's what I was talking about before.
Old Dec 29, 2006 | 11:51 AM
NgoRX8's Avatar
hmm rodger, can you take a look at my clutch at the next meet and see if i have any symptoms similar to yours?
Old Dec 29, 2006 | 01:45 PM
yea sure....
They said I broke the clutch pedal bracket welds. They also replaced the slave cylinder.
Old Feb 7, 2007 | 11:27 AM
ngo: any update?
Old Feb 7, 2007 | 01:35 PM
NgoRX8's Avatar
i had rotary rasp look at my clutch bracket and it's a totally different bracket than what he has. everything seems fine to him but for some reason my bracket isn't the same as in other rx8s. we compared them one after another and it does seem shorter as shown in my pics. and also the bends are different. in a few of the other 8s we looked at in the meet, mine was the only one that looked different.
i plan to have the dealer look at it (since it is ripping a hole in my rubber footwell cover), whenever i decide to take the car in to the dealer.
Old Feb 7, 2007 | 10:14 PM
NgoRX8's Avatar
thanks for the pic abbid.
yup if you compare my clutch bracket to yours, mine looks shorter after the bend.
theblinkof
Oct 4, 2023 05:24 PM
XianUnix
Sep 29, 2015 03:48 PM
tommy26Germany
Sep 29, 2015 10:33 AM
