AEM CAI Start-Up Lag
Old Dec 22, 2006 | 09:31 AM
trainoffools's Avatar
Man of the Year
Installed a CAI a few weeks ago, sounds great but now when I go to start-up the car (cold AND warm) it has a bad lag like it's struggling to catch. Almost like the battery is weak. My new(?) Exide battery is only 10 months old. When I was doing the install I took an overnight break with the battery disconnected and needed to jump-start the car after CAI install the next day---could that have weakened a relatively new battery enough to cause weak start-ups?
Old Dec 22, 2006 | 09:40 AM
Aero8's Avatar
I Installed the AEM around thanksgiving and I have the same issue, but it started well before i put on the intake, so I wouldn't contribute it to the CAI. Just my experience.
Old Dec 22, 2006 | 12:01 PM
Man of the Year
Mine definitely started after the install. Was perfect before.
Old Dec 22, 2006 | 12:22 PM
did you reset the PCM with a scanner so it could learn the new part?
Old Dec 22, 2006 | 12:32 PM
Brettus's Avatar
Boosted Kiwi
If you had to jump start the car your battery has discharged somehow . There is no way it should have done that just from being disconected though .
Recharge & test your battery.
Old Dec 23, 2006 | 06:35 AM
Mazda-Rati's Avatar
the WANKEL made me do it
Did you find a way to plug the nipple behind the throttle body? Maybe that's it. When I had the AEM, I had to figure my own way to plug it. RB send a small red cap with their intake.
Old Dec 23, 2006 | 03:10 PM
Man of the Year
Yes, I used rubber compund to plug the hole. In fact, I got a CEL light right after install. I took it into the Mazda dealer to get the recall done and they reset the light but after a day it was back on. I'm convinced it all has to do with this CAI.
Old Dec 23, 2006 | 04:03 PM
painter1's Avatar
If its notBLACK its wack
When you went to mazda did you get the new starter that was on recall? I had same problem until I got my starter replaced now she fires up fast!
Old Dec 23, 2006 | 05:09 PM
Mazda-Rati's Avatar
Trainoffools, You never mentioned what brand CAI you installed. Did your CAI come with screens?
Old Dec 24, 2006 | 12:12 PM
read the title, it's an AEM the screen doesn't affect startup nor does the CAI itself, you have some other issue such as an unplugged vacuum port, connector not fully engaged, need to clear PCM, original style starter (pre-recall), etc.
it would help to know what the CEL is, it's also not clear if it's cranking slow (which would be totally electrical system) or it cranks fine but takes a long time to actually start running, you need to be more specific if you want good help
Sato Tatsuya
Oct 5, 2015 03:09 PM
Zube6115
Sep 30, 2015 12:57 PM
Forevermore
Sep 20, 2015 01:04 PM
