7000 rpm "flat spot"?
Old Dec 9, 2006 | 12:51 AM
mwood's Avatar
It seems like my RX8 has a pretty pronounced flat spot at somewhere around 6800-7100rpm...kind of a hitch and then it pulls ok from there to red line. Any comments or experience anyone can share?
Old Dec 9, 2006 | 01:34 AM
dtorre's Avatar
Ultimate ****** Goderator
its the vtec kicking in
Old Dec 9, 2006 | 02:26 AM
how many miles??? that is when the last ports open up... if they are gunked up.. they might open slow..
i would run some b&g 44k... put it in right before a track or autox day... as these ports only get fuel above ~7200 rpm...
Old Dec 9, 2006 | 11:14 AM
Sparky's Avatar
I talk to cones
That's not abnormal. I can't remember exaxctly, but I thinks it's the VDI reconfiguring the intake. Anyway, it's prevalent in the touque curve of all stock engines...yes it sucks...and yes we have to live with. Drive someone elses car to compare before you do anything.
Old Dec 9, 2006 | 12:41 PM
mwood's Avatar
Thanks. That explains it! And, yes, it is annoying...
Old Dec 9, 2006 | 12:59 PM
mine never did that
Old Dec 9, 2006 | 06:09 PM
mwood's Avatar
Originally Posted by TeamRX8
mine never did that
Yeah, but that's because you have the special, limited edition that also allows for over 2 degrees of negative front camber
Old Dec 10, 2006 | 06:10 PM
ehutch91's Avatar
My 2006 does the exact same thing. It feels like the throttle is closing a little and then opening back up. Kind of annoying but I'm assuming its normal.
Old Dec 10, 2006 | 07:21 PM
still haven't figured it out, eh
Old Dec 11, 2006 | 12:14 AM
mwood's Avatar
Mark, I think you know how technically savvy I am...I'm certainly not going to be the one to figure it out...but, give me a clue, at least that way I'll be part way dangerous
Old Dec 20, 2006 | 05:29 PM
CodingParadox's Avatar
Well, first you get a big hammer... And then...
Old Dec 20, 2006 | 07:28 PM
BRGREEN8's Avatar
Old Dec 20, 2006 | 08:25 PM
your parts and state of tune have a lot to do with how severe the power curve drop will be on the intake transitions
same for the camber setting, no hammer required
Old Dec 20, 2006 | 08:27 PM
It sounds like you're cryptically trying to say "I have no caster", but that still doesn't make any sense.
Old Dec 20, 2006 | 08:30 PM
well now that you mention it my caster was in the high-3 to low-4 degree range ...
mdl0209
May 23, 2019 05:46 PM
D13
Oct 1, 2015 07:55 AM
tommy26Germany
Sep 29, 2015 10:33 AM
pjwermuth
Sep 28, 2015 11:36 PM
GK1707
Sep 27, 2015 07:33 PM
