Opinions- Yokohama IG721 Ice Guard
Old Dec 7, 2006 | 06:49 PM
le85's Avatar
Question Opinions- Yokohama IG721 Ice Guard
Hey,
I just found a guy selling....
Front: 225/45R18
Rear: 245/45R18
(they were used on a g35)
he said they're staggered... (no clue what that means)
will these work on my rx-8. based on other posts i heard that overall 245s might be a little too big, but im willing to take my chances since im getting stuck with other options....
What do you guys think... Staggered is that ok??
Please let me know soon as i plan on going out to pick up the tires on fri afternoon so i need to know to cancel if need be.
Thanks in advance!
Old Dec 7, 2006 | 06:52 PM
STAGGERED typically means that your going with different sized wheels/ tires from the front, wider in the rear. 245'S should fit fine in the rear
Old Dec 7, 2006 | 07:02 PM
zaglo6204's Avatar
mine's better
245 is wide for a snow tire, but you'll probably survive.
probably.
Old Dec 7, 2006 | 07:25 PM
le85's Avatar
thanks guys... anyone ever trying putting the tires inside the rx8, id rather take my car when i go to pick them up... between the trunk and the back seats do they fit
Old Dec 8, 2006 | 10:31 AM
KimiFelipe's Avatar
The fronts will fit, the rears are just too tall - almost 0.7 in taller than stock. You could run them but I wouldnt. You might check to make sure all the suspension components are cleared by the rear tires before you buy them. Check this :
http://www.miata.net/garage/tirecalc.html
I have the contiwintercontact 810s, H rated, and I really like them. They are a little weak-kneed in the dry, but considering they are H-rated and heavily siped snow-tires, they have good dry grip.
LB2739
Jul 9, 2019 02:25 AM
Azki23
Jun 27, 2018 03:48 PM
tigg.z
Aug 26, 2015 09:51 PM
Yayforaddison
38
Jul 31, 2015 11:28 AM
