Any Ideas for a P0420 cell?
Old Dec 5, 2006 | 09:40 PM
rx8guy86's Avatar
Drive Like you stole it
I have the rotary performance Midpipe with the Hi-flow cat. i have had it for about 6 months now. Everything has been fine. About two weeks ago the check engine light would come on and go off about once a day. While the car was at mazda for warranty work, they went ahead and pulled the code and said that it was from the o2 sensor. Well for the past 3 days it has stayed on solid. Any Ideas??
Old Dec 6, 2006 | 10:56 AM
O'Renesis's Avatar
''P0420 = Catalyst system efficiency below threshold''
It looks as if the ''Hi-Flow'' CAT is not doing its job.
According to the workshop manual the monitoring condition for this CEL are;
1 - ECT = more than 158F
2 - Catalyst converter temp: more than 752F
3 - LOAD = 20 to 50percent (maximum calculated load values varies depending on engine speed)
4 - Time with purge control system does not operate: more than 20s
It also says possible causes are;
1 - Looseness of Front HO2S sensor.
2 - Leakage exhaust gas.
3 - Purge control system malfunction.
4 - VSS malfunction.
5 - ECT malfunction.
6 - Eccentric shaft position sensor malfunction.
7 - PCM malfunction.
I am no expert here so am only quoting the manual, but I would guess that the Hi-Flow CAT is not operating within expected parameters.
Hope that helps.
Old Dec 6, 2006 | 12:59 PM
J'sgr8t8's Avatar
go to autozone and get a spark plug anti fowler kit. the package comes with two. take one and drill out the center with a .5 inch drill bit. screw the one you drilled the hole in into the other anti fowler. then screw the assymbly into the secondary o2 port then connect the o2 sensor ( may take a few times to get the right kit that fits the o2 ) this will hide the increase in exhaust flow from the ecu
Old Dec 6, 2006 | 03:33 PM
dgrx8's Avatar
FN GR8
has anyone else tried this??? i know it's hit or miss w/ most cars...
Old Dec 6, 2006 | 03:35 PM
WRXtoRX8's Avatar
Winning is Everything
That has worked wonders in teh subaru community that I know of. I am getting ready to do that on my gf wrx
Old Dec 6, 2006 | 09:39 PM
rx8guy86's Avatar
Has anybody tried this on a RX8??
Old Dec 6, 2006 | 11:31 PM
it absolutely does not work on an RX-8, do teh s3arch
Old Dec 7, 2006 | 06:46 PM
rx8guy86's Avatar
Jeez, why the F*ck was it even posted then. Sorry TeamRX8. Didnt mean to offend you!
Old Dec 7, 2006 | 07:20 PM
I'm not offended, just letting you know that it doesn't work and the info is well documented on this forum if you care to look for it
Old Dec 8, 2006 | 02:20 AM
rx8guy86's Avatar
Nah, its cool. I just want to figure out what is up with my car!.... lol... thanks htough BEERS!
Old Dec 8, 2006 | 09:22 AM
dgrx8's Avatar
FN GR8
apparently, nothing is documented to really work.
Old Dec 17, 2006 | 02:07 PM
rx8guy86's Avatar
Well, I installed my Canzoomer Stage 1 on friday. No CEL anymore... weird?? But I can see a huge difference with the CZ installed.
Old Dec 22, 2006 | 01:05 PM
VarneyMazda's Avatar
Northeast Pimpin'
was talking to the tech at our store, he said the same as the above "catalyst low effiency"
Old Jan 28, 2007 | 07:01 PM
rx8guy86's Avatar
Well, the CEL did come back with the CZ. I took off the RP Midpipe and no CEL. So its coming from the midpipe. Is that Highflo cat suppose to prevent a CEL? Should it be something that should be fixed from Rotary Performance?
Old Jan 28, 2007 | 07:12 PM
yes,
Old Jan 28, 2007 | 07:13 PM
your cat is shot, not the first one either if you care to search, seems that they have been replacing them
Old Jan 31, 2007 | 07:00 PM
rx8guy86's Avatar
Actually, I talked to Rotary Performance. Last week the got the shipment of new cats in. This week or next week they will begin the testing stage before they ship them out.
92trbolzr
May 18, 2025 09:04 AM
Jazzmeson
RX-8 Multimedia/Photo Gallery
11
Mar 2, 2016 02:25 PM
Digitz0070
Oct 7, 2015 12:43 PM
Zube6115
Sep 30, 2015 12:57 PM
