Broken Power Door Locks - Any Ideas?
Old Dec 4, 2006 | 08:56 AM
Booster MPS's Avatar
My car was left at the airport over the weekend, and since I returned to pick it up I have had problems with the power door locks. My locks are completely unresponsive to my key fob. The fob will not lock/unlock the doors nor open the trunk. I tried a new battery in the fob as well as placing the new battery in another fob with no luck. Additionally, I have noticed no other quirks with the electrical system. The only thing that I can say that might contribute to this is that it was fairly cold here in TX over the weekend.
Any ideas?
Thanks in advance for your help.
Old Dec 4, 2006 | 09:22 AM
Did someone try and jimmy your door........airport parking lots are notorious for people trying to steal your ride.....
Old Dec 4, 2006 | 09:33 AM
The car is fine and not damaged at all. I visually inspected the car and it seems clean.
Old Dec 4, 2006 | 09:39 AM
foo77's Avatar
4th batch : Apr 03'
did you check your fuse panel on driver's side?coz i have the same prob,when my interior light fuse got blown
Old Dec 6, 2006 | 02:19 AM
DOMINION's Avatar
I don't buy Kool-Aid
Wow this is interesting. I dont have this prop but Booster, from what I was told by my local Mazda Dealer they will have to replace the motor. I dont know if he under stood what I was telling him but if thats the case then I think you have to have the new motors drilled in to the windows and this can be a real pain in the *** job.
Old Dec 6, 2006 | 02:30 AM
Stavesacre21's Avatar
1.21 Jiggawatts
check EACH and EVERY fuse.
I've found out already that the 8's fuse box seems a lil more quirky then i thought. Apparently, i blew the AC fuse. Well...all the sudden, the AC, stereo, sunroof, heated seats, power windows, LCD display and dome lights didn't work. I checked every fuse and came down to that one being blown. Fixed it, and EVERYTHING else came back on.
seem odd? I think so...especially since the manual stated that it was simply an A/C fuse...without apparent ties to anything else.
My advice is to check the kickpanel fusebox and underhood fusebox for every fuse that can be checked. Sounds stupid, but it saved me a trip to Mazda.
Old Dec 6, 2006 | 06:04 PM
corners's Avatar
An RX ate my baby
Do you have the advanced key system? It sounds like the car lost track of it and it just needs re-programming. The dealer will probably do it for free if you ask nice. You didn't say if the interior switches work or not.
Old Dec 6, 2006 | 06:18 PM
Thanks all for the feedback.
It seems as though the fuses are just fine for the car, nothing was found there. I took the car into the dealer today and they say that new fobs have to be ordered and programed for the car. They had absolutely no explanation why either fob did not work - not even the old one where the batter simply went dead in it. The guy said he has seen this before. In my opinion there has to be a smoking gun and I think the dealership just would rater get new fobs for me rather than track it down.
As an aside, I found out that the harness for my heated seats was never connected at the factory. I recently sat in a friends Mazda Speed 6 and noticed that the light on the heated seat switch actually came on. I got the car in Florida and did not tnink much of it when I flipped the switch and nothing happened - also never had a use for heated seats in FL. Well now with an early winter in Houston I asked the question today. I wonder what else the factory forgot to connect.........
I will post back in when I get the fobs. Thanks again.
Old Dec 18, 2006 | 10:29 PM
A bit of follow up on this one.
The story ends as they ordered two new remotes for me and programmed them. Everything now works fine.
drebbrnator
Dec 27, 2018 07:02 PM
Crazy.8
Apr 18, 2017 03:17 PM
RXeckless
Aug 16, 2015 12:52 PM
RXeckless
Aug 16, 2015 12:51 PM
